Projects All The Twos: 1962 Mercury, 352cui, 2bbl, Too Many Doors.
Discussion in 'The Hokey Ass Message Board' started by Oneball, Oct 28, 2023.
  1. Oneball
    Oneball
    Thanks Jeff
    Jeff Norwell likes this.
  2. Oneball
    Oneball
    Valve gear all in, couldn’t get the drip rails in with this intake so had to leave them out
    Exhaust manifold on too
  3. Oneball
    Oneball
  4. Flatrod17
    Flatrod17
    Looking real good Tim!!
    Oneball likes this.
  5. Oneball
    Oneball
    Thanks Dennis. Was hoping to get it in and started this weekend but I’ve just noticed the new water pump shaft is bent :mad:
  6. Oneball
    Oneball
    I’ve straightened the pump with a hammer. Will see how it holds up. About to get started.
  7. Oneball
    Oneball
  8. Jeff Norwell
    Jeff Norwell
    MODERATOR
  9. Pontmerc
    Pontmerc
    from Finland
    Looking good!
    Have you noticed that fe sits more towards p***enger side..
    Oneball likes this.
  10. Oneball
    Oneball
    No, but Vettes do too so it probably just seems normal to me!
    Have you ever changed the shifter seal on a Ford-o-matic?
  11. Pontmerc
    Pontmerc
    from Finland
    Yes i have change shifter seal on a multi-drive transmission.need advice? Picture of dissambled one or something? No problem.
    Oneball likes this.
  12. I love the color of your valve covers! Awesome work and cool project.
    Oneball likes this.
  13. Oneball
    Oneball
    Just wondering if there’s anything tricky, I’ve got the factory workshop book, the new seal I’ve got for the throttle shaft is an o ring but the pic in the book looks a bit more substantial
  14. Oneball
    Oneball
    Most people go for the HiPo gold but I thought that might not look right on a gold car. The original colour was bluey green so I went to paint shop a picked a colour I liked. It pops even more in real life.
    Need to do an air cleaner too. I tried the carb and air cleaner last night. It’s really close to the hood so need to find some plasticine or something for a proper check.
    Truckdoctor Andy likes this.
  15. J. A. Miller
    J. A. Miller
    from Central NY
    A loosely balled piece of aluminum foil works well for checking clearances on things like that.
    I enjoy watching the progress you are making on this Mercury.
  16. Oneball
    Oneball
    Thanks, will have a go at that.
    bobss396 likes this.
  17. bobss396
    bobss396
    Or if the clearance is close, try something like a grilled cheese sammich...
  18. Oneball
    Oneball
    Does it still work without the cheese?
  19. Pontmerc
    Pontmerc
    from Finland
    For The kickdoewn shaft seal, its doable under the car but shift shaft seal....well, never donit under the car.detent spring and ball might be mission impossible to keep in their bore during installation.
    Oneball likes this.
  20. Oneball
    Oneball
    Almost but not quite. :(
  21. Oneball
    Oneball
    Don’t you hate being right. I knew the surface finish on the heads wasn’t acceptable, they’re ******* water out without even being run. FFS!
    It did look like this but won’t for long.
    bobss396 and oldiron 440 like this.
  22. ClayMart
    ClayMart
    "Cracking toast, Gromit!" :D
    deadbeat and Oneball like this.
  23. Pontmerc
    Pontmerc
    from Finland
    I bet you are so upset, that you must drink rather large cup of strong tea!
    Oneball likes this.
  24. Pontmerc
    Pontmerc
    from Finland
    When you get those heads out, check the guide rings for bottoming out.
  25. Oneball
    Oneball
    Will do. I didn’t check them as there wasn’t much showing above the gasket so they should be ok but will double check.
  26. ClayMart
    ClayMart
    Is it leaking between the head and the block or from around the exhaust manifold bolt? Are the manifold bolt holes blind or do they go into a coolant p***age in the head?
  27. Oneball
    Oneball
    Head and block, the bolts are blind. It’s clearer where it’s leaking from in person. The other side is leaking in more than one place. I’ve drained the block so hopefully it’s not filled the bores up. Have got the day off work tomorrow so will try and pull the head. I’m a little worried I might not be able to pick them up over the fender, since my accident my left arm isn’t very strong.
  28. Oneball
    Oneball
    Quite glad the intake is aluminium now
    williebill likes this.
  29. bobss396
    bobss396
    That is more serious than a head-surface finish thing. You will get to the bottom of it.
  30. Oneball
    Oneball
    I’ll show you the pic in 5 minutes. I’m pretty sure it’s head surface, just having a cup of tea
