Technical Death wobble
Discussion in 'Traditional Hot Rods' started by Hildy56, Mar 1, 2024.
  1. DDDenny
    Dead perch.
    Kevin Ardinger, Lil32 and dana barlow like this.
  2. 2OLD2FAST
    2OLD2FAST
    from illinois
    Don't believe that's necessarily the cause of the man's
    DW , wandering , yes !
  3. flynbrian48
    flynbrian48
    He took the dead perch out, so without that it has to have a Panhard bar. Or, put the dead perch back in, one or the other.
  4. Joe H
    Joe H
    Can you explain Dead Perch? I think I know what it is.
    Also roll the car forward at least one or two tire rotations before you check toe-in, it makes it " as driven " removing all slop in all joints.
    alanp561 likes this.
  5. alanp561
    alanp561
    Borrowed from @Frames. No shackle on one end of the spring.
    flynbrian48 and Boneyard51 like this.
  6. Boneyard51
    Boneyard51
    Ok, just the facts! To quote Jack Webb! If you have a straight axle and get the wobble, the very first thing you need to do, is check for worn suspension components. With worn suspension components,alignment means nothing! Once you insure all your suspension components are in good shape, set your alignment to specs! This needs to be done anyway! If you still have the problem, check to make sure your wheels and tires are round, in line and balanced! If you still have the wobble after all this and everything appears to be perfect, take out, or put in a few degrees caster toward the edge of specs or even a degree or two out of specs. This will stop the wobble!
    Trying to fine the cause of the wobble, can be impossible! Believe me it can hide! But the above procedure will stop the wobble! After you stop the wobble, then add the dampner for insurance! Never put one on to stop the problem, fix the problem first!
    Bones
  7. twenty8
    twenty8
    That's unusual. It is not often that scrub radius is described using a diagram showing positive camber...:confused:o_O
    X38 and AccurateMike like this.
  8. Budget36
    Budget36
    So crosssteer needs a pan hard rod?
    Early Fords didn’t use them, I think maybe until ‘39 or so. Were the earlier ones subject to wobble?
  9. twenty8
    twenty8
    Budget36 likes this.
  10. Johnny Gee
    Johnny Gee
    from Downey, Ca
    There’s not too many images that I could find so I cut out a portion of the original image because there wasn’t many, make if any illustrations showing a solid axel. Just concern one’s self with king pin center line in relation to center line of the tire where it meets the pavement.
    alanp561 and twenty8 like this.
  11. twenty8
    twenty8
    Yep, I know how it works. Just don't see it illustrated as positive camber often.
  12. don colaps
    don colaps
    But seems legit since we’re talking Model A Ford
    twenty8 and 427 sleeper like this.
  13. don colaps
    don colaps
    I’d say Ford introduced panhard rods when they changed the spring design from preloaded to non preloaded? Or just when they went from side steer to cross steer in 1935?
    twenty8 likes this.
  14. 1946caddy
    1946caddy
    from washington
    Bought a wrecked jeep (sheet metal) and installed a 4" lift kit along with 12" wide wheels and tires. Couldn't get over 20 mph without a horrible death wobble.
    Took it into the alignment shop and he couldn't find anything wrong. All the tie rods ends were tight and steering dampener was good. Good alignment.
    I replaced every tie rod end and a new steering dampener. I couldn't find a problem with the old parts.
    Put rig back on the ground and took off down the road, hit 20 mph and no more death wobble. Up to 60 mph, no problem. I can drive up to 70 plus mph without any problem.
    2OLD2FAST likes this.
  15. Budget36
    Budget36
    I don’t know. I had a ‘39 rear, clutch brake pedals in a ‘36 PU. Also in the bed was the front bar as well, so I’d just ***umed it all came from the same vehicle, hence why I mentioned ‘39. But I’m no expert at all.
    don colaps likes this.
  16. don colaps
    don colaps
    I’m no expert either, for sure. I edited my post tvough
  17. Johnny Gee
    Johnny Gee
    from Downey, Ca
    This is why I asked if toe “out” would get worse if one were to roll the axel back for more caster.
    Op has said he never checked his toe.
  18. ronzmtrwrx
    ronzmtrwrx
    My 39 never had a panhard bar. Front or rear. I thought they came along in 41, but I'm no expert either. lol
  19. Budget36
    Budget36
    lol. Like I mentioned, the PU I had was with ‘39 parts and the bar was in the bed.
    So I did the ***UME thing, obviously I was the ***. ;)
    alanp561 and ronzmtrwrx like this.
  20. Kerrynzl
    Kerrynzl
    Early Fords had Triangle Shaped ["A" shaped] bones., not split bones
    And also the correct shackle angle
    As soon as the wheel gets "re-invented" by splitting the bones, and reverse eye the crossleaf [so the eyes are on the outer side of the arch] the problems start.
    Scrub radius is a factor of king pin inclination not camber. Smaller rolling radius increases scrub radius unless positive offset wheels are used to counteract this
    A dead-perch is a cl***ic example of "Silver wiener syndrome" [If a winning racer glues a silver wiener to his car, all the Hot Rodders and Street Racers would do the same.]
    The dead perch was an early Sprintcar and Midget technique where they're are constantly fighting a losing battle with weight.
    The Cross leaf doubled as a panhard bar, and used in conjunction with cowl steer so it didn't cause bump steer..
    On left turning cars the dead perch was always mounted on the L/H side to keep the leaf under lateral tension. This also cause the L/F wheel to "grab air" which didn't matter.
    R/H dead perches would result in an undesirable jacking effect on L/H corners.
    A dead perch is not overly desirable with cross steer, because it is almost impossible to engineer out mechanical. bump steer. The axle will arc basically 1/2 the spring width. whereas the drag link is much longer.
    If somebody insists on a dead perch, the perch must be on the opposite side of the steering box [p***enger side]
    A L/H dead perch with a L/H steering box causes the axle and steering to arc in opposite directions.
    A panhard bar is far superior with a cross steer because it can mimic the arc of the drag link..
    Any driver who is capable of driving at the limit of tyre adhesion would certainly notice the flaws in a dead perch / cross steer combination.
    Tim kerns, flynbrian48, rod1 and 6 others like this.
  21. DDDenny
    Which always begs the question "is that sitting in the driver seat or facing the front of the engine"?
    Now that I think about it....is it LHD (normal):eek: or RHD (across the big water).
    What say you @Kerrynzl
  22. 4bangerbob
    4bangerbob
    from AB, Canada
    ford introduced the panhard bar in 1942. Cross steering in 1935.
  23. Johnny Gee
    Johnny Gee
    from Downey, Ca
    The real answer is from the drivers seat facing forward naturally.
    RodStRace, rod1 and clem like this.
  24. Kerrynzl
    Kerrynzl
    Across the big water, steering on the Right side .... is the right side But in the USA steering on the Left side .... is the right side :D:D:D
    But to add to the confusion
    Driving on the left side .... is the right side But in the USA driving on the right side .... is the right side
    It is a simple concept to overcome, Just get a single seat open wheeler and apex the corners [road rules don't matter]
  25. X-cpe
    X-cpe
    Was always taught that L/H vs R/H was determined with your **** parked in the driver's seat. Told my students that when dealing with customers, use drivers side or p***enger side because most customers were smart enough to not screw that up.
  26. DDDenny
  27. Johnny Gee
    Johnny Gee
    from Downey, Ca
    on my part. ;)
  28. ronzmtrwrx
    ronzmtrwrx
    Ha haa, I wouldn't have argued with you either way. Looks like we both learned something.
  29. DreamerJ
    DreamerJ
    Try an Adjustable spring perch after your measurements are correct and it still occurs. I believe they allowed my spring to travel in more up and down path than a fixed perch.
  30. X38
    X38
    Left or right doesn't matter where the driver sits. It's left or right as the car faces forward, same as a person.
    29A-V8 and 26 T Ford RPU like this.
