Projects 1939 Ford convertible mild custom.
Discussion in 'Traditional Customs' started by John 79, Sep 13, 2023.
  1. Jacksmith
    Jacksmith
    from Aridzona
    I wouldn't...
  2. John 79
    John 79
    from Sweden
    Got the rear axle dialed in at the right angle and welded the mounts.
    Had a couple of old 2 inch lowering blocks with the steering tap broken of, some drilling and thread and cheap *** me could use them.
    Now the rear axle is bolted in place. 20240303_113728.jpg 20240303_115223.jpg 20240303_101759.jpg 20240303_130229.jpg
  3. Kaptain Kustom
    Kaptain Kustom
    from Finland
    Very cool project! Nice to see it coming together. (Any chance of seeing it in the Wheels meet in Haaparanta next summer?)
  4. John 79
    John 79
    from Sweden
    I live in southern Sweden so Happaranda is a long way from me.
  5. MMM1693
    MMM1693
    Looking good
    John 79 likes this.
  6. John 79
    John 79
    from Sweden
    Got some more of the trunk floor in.
    GordonC, Bandit Billy, mvee33 and 6 others like this.
  7. John 79
    John 79
    from Sweden
    Sandblasted the manifolds and put on some stove polish, also made flanges for the exhaust system.
    Its gettin closer and closer to first start up. grenrör.jpg grenrör fläns.jpg grenrör monterat1.jpg grenrör monterat.jpg
  8. MMM1693
    MMM1693
    Great work!
    John 79 likes this.
  9. John 79
    John 79
    from Sweden
    Som rust repair, bottom of the trunk reinforcments/trunk mounts on both sides got done. 20240309_165941.jpg 20240309_095953.jpg 20240309_132659.jpg .
    GordonC, 40FORDPU, The 39 guy and 2 others like this.
  10. John 79
    John 79
    from Sweden
    Made a "kickup" floor because im planning a small kickup on the frame in the future so i thought it was best to prepare the floor for it.
  11. John 79
    John 79
    from Sweden
    Some progress, got the gas tank mounted and a fuel pump/fuel lines.
    Also made a battery box that i mounted in the trunk instead of the engine bay that was to tight.
    Bought a new generator from https://downtoearthautoelectrics.co.uk/
    These are 12V internally regulated with only two wires.
    Made a bracket to fit the original mounting holes on the 265 manifold.
    I had about 25 different fan belts layin around and guess what, non of them fit... 20240313_164434.jpg 20240315_195240.jpg 20240315_193700.jpg 20240315_195217.jpg
    GordonC, anthony myrick, hfh and 9 others like this.
  12. The 39 guy
    The 39 guy
    I really enjoy watching your progress. The quality of your work is something you be very proud of.
    John 79 likes this.
  13. John 79
    John 79
    from Sweden
  14. John 79
    John 79
    from Sweden
    Got the gas pedal hooked up, used the original parts but moved the linkage to the drivers side.
    Also got my new driveshaft and mounted it.
    Connected the starter and generator so i can start the car with the original push ****on and also got it charging.
    gasstag original.jpg gasstag.jpg gasstag fugge.jpg kardan.jpg kardan monterad.jpg
    GordonC, Okie Pete, 63fdsnr and 3 others like this.
  15. guthriesmith
    guthriesmith
    Loving this build! Thanks so much for the updates. I’m looking forward to how you end up with the car sitting in the rear. I may need to do a similar kick up on my 40 Merc to get it to sit right and still have suspension travel.
    Okie Pete, Outback and John 79 like this.
  16. John 79
    John 79
    from Sweden
    I think it will sit quite level, its a bit low in front so i dont think it will have that taildragger stance yet.
    But i really dont know, its been on jackstands for a long time...
  17. MMM1693
    MMM1693
  18. John 79
    John 79
    from Sweden
    First time moving under own power.
    Whoamel, mvee33, GordonC and 10 others like this.
  19. Okie Pete
    Okie Pete
    It’s alive Awesome
    John 79 likes this.
  20. MMM1693
    MMM1693
    Good on you! Great work throughout your build
    John 79 likes this.
  21. John 79
    John 79
    from Sweden
  22. Looks and sounds great!! You might want to add a second throttle return spring though, for safety.
    Okie Pete and Jacksmith like this.
  23. John 79
    John 79
    from Sweden
    Mounted one rear fenders and tested a fender skirt.
    prez, pwschuh, mvee33 and 16 others like this.
  24. patsurf
    patsurf
  25. Easy to confirm! Killer Car!
    Kelly Burns, John 79 and Okie Pete like this.
  26. ronzmtrwrx
    ronzmtrwrx
  27. F-head
    F-head
    Love it, but then I’m a ****er for 39 convertibles
    John 79 likes this.
  28. John 79
    John 79
    from Sweden
    Its easy to be.
  29. John 79
    John 79
    from Sweden
    Well the 39 is now a driver, i havent updated alot here but i just bolted on the fenders and made a exhaust system and alot of small stuff to get it driving.
    Still alot of stuff to do and it looks way better in photos than in real life. 453723347_3664298723880133_6835404887068384924_n.jpg 453883045_3664298677213471_2191439132512094907_n.jpg 453656332_3664298653880140_966954989511958178_n.jpg
  30. guthriesmith
    guthriesmith
    Looks great to me! :cool: The best part is that you can drive and enjoy it. :D
