Projects Building My First Roadster in San Francisco
Discussion in 'Traditional Hot Rods' started by J.Ukrop, Sep 7, 2020.
Tags:
  1. Tim
    Tim
    from KCMO
    Zerk
    Six Ball likes this.
  2. Outback
    Outback
    from NE Vic, Oz
    Who are you calling ZERK! hahaha
    Six Ball and Tim like this.
  3. Six Ball
    Six Ball
    from Nevada
    So there is no thread about the non-threaded zerks? Are the non-threaded zerks covered in the thread about the threaded zerks?
  4. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Great advice on the shims. They came in handy as I put everything together.
    Yes! I'll be painting the frame ch***is black and making the exterior of the rails match the body.
    You and I both. I still have a whole lot of fun planned for this car, so don't worry.
    You never know! I've had some "almost" moments on a couple of different body styles. Right now the focus is 100% on getting 2.0 on the road. We'll see what will fall into place for the 'banger components.
    Hahahha neighbors will love it!
  5. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    That thing is super cool. It almost looks like it's AI generated. An, er, AI generated A generator!
    Yes! That was me. In January, I made the trip north in the rain and met David up there with his roadster. For the full account of the adventure, check out "The High Watermark" on the Jalopy Journal here.
    Thank you for the offer! David ended up having an extra that we used, but I really appreciate it!
    pprather, 41 GMC K-18 and Tim like this.
  6. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    It's been a busy weekend with lots of good progress, so I figured I'd post the beginning of my update before I go to sleep. We'll start with this excellent film photo from @Kevin Carroll on Portra. I love how it captures the motion and excitement of driving an early Ford through the city on a Saturday afternoon. B29DF836-FF1D-4B4E-9B91-3444884DDBCF.jpg
    I'll be back with the rest of the update soon!
  7. JalopyJimbo
    JalopyJimbo
    from NE Alabama
    Smiling like the cat that ate the canary haha
    Outback and Six Ball like this.
  8. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    On Saturday morning, I jumped in the truck and motored north to Petaluma. As I drove across the bridge, I talked to my parents on the phone. "What are you working on today?" my Mom asked. "We're setting up the kingpins, spindles and the front brake backing plates," I said. "And whatever other fun projects we can find!"
    Walking up to the shop, I greeted David out front. The first order of business was to turn on the parts cleaner and then check out the results.
    "No matter how many times I do this, it's always exciting," David said as we sifted through the resin in the back room. I couldn't believe how everything looked brand new.
    Although I may look a little crazy here, it's because I was captivated by the magic of the process!
  9. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Next, I turned my attention to the front end. I spent the latter part of the morning cleaning the necessary surfaces and test fitting everything. Then it was time for lunch. The rain had stopped, so naturally we took the roadster. (We would have taken it regardless.)
    Back at the shop, I'd try one shim, then shake the spindle. It would move ever-so-slightly. I'd ask David and he'd offer advice. By the end, I got the hang of it and had both sides looking and—most importantly—feeling right.
    David has the right tool for every job. Here he cleans up the kingpin locking pin hole with a straight reamer. We each tackled one side of the axle. IMG_0991.jpg
    He also gifted me this amazing little micrometer, which I used to measure the shims. Can't wait to use it on future projects.
    Oh, and remember when I said we were able to find a 90-degree zerk? This is where it came from. "This jar of chili peppers was pre UPC," David said.
    We also tuned up the backing plates to fit the spindles. They needed a little bit of finessing, but now they click together perfectly. Before leaving, I had to mock everything up.
    Note the original steering stops. David felt that they would better fit the style of the build. I couldn't agree more. Old chrome, old parts and white paint. It's exciting to see it all come together.
  10. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    On Sunday morning, I made the most of the weather and got right to work. I set up shop in the driveway, cued up some Grateful Dead and dove into all the taping, sanding, priming and painting.
    I cleaned up the wishbone a little bit too.
    Bad lighting, but I was happy with how the perch pins turned out.
    Bronze bushings by our friend Jerry Larochelle!
    Tonight I got some paint on the wishbone. I plant to hit it with a few more coats when it's not dark out. That's all for tonight. More updates happening later this week!
  11. Outback
    Outback
    from NE Vic, Oz
    So cool!
    J.Ukrop, Six Ball and rod1 like this.
  12. Tim
    Tim
    from KCMO
    Perfect :)
    J.Ukrop and Six Ball like this.
  13. Jeff34
    Jeff34
    Lookin good Joey!
  14. CA. 280
    CA. 280
    If you can make it to Petaluma then join us this Sunday the 10th for a Cars and Coffee at the
    Napa Valley Premium Outlets parking lot. 8-10AM, just off HWY 29. We have to be gone befor the stores open.
    Usually 60-70 cars, lots of Napa Valley Cruiser folks but definitely an eclectic mix. Actually
    we get together on the second Sunday of every month. And yes there is a coffee shop.
    J.Ukrop and 41 GMC K-18 like this.
  15. Six Ball
    Six Ball
    from Nevada
    Very nice! Could you explain the parts cleaning process? What is the green stuff?
    J.Ukrop likes this.
  16. RodStRace
    RodStRace
    If it's like the tumbler that I used at work, that is ceramic pellets. You have a big vibrating bucket (rubber lined or plastic) with the pellets in it. You add in some water with or without a cleaner. Put the parts in and set it to rumble (ours the bucket was 2X2X4 feet and could be felt throughout the shop), and 10-30 minutes later, the parts are degreased (best to get as much off as possible before), smoothed of burrs and uniform surface finish. They must be rinsed off after, because any surface muck is now a film over the whole thing. There are various sized pellets, they last quite a while. The liquid should be changed at least once a day and drained after use.
    Here are smaller ones
    https://www.mcmaster.com/products/********y-cleaners/
    More description
    https://www.kramerindustriesonline.com/product-category/********y-finishing-systems/
    P.S. you really don't want pellets smaller than any deep holes in your parts, especially blind holes.
    Ragged Edge, J.Ukrop, Outback and 3 others like this.
  17. Hitchhiker
    Hitchhiker
  18. 41 GMC K-18
    41 GMC K-18
    Hey @J.Ukrop
    Dude, all of the progress you are making as seen in the photo's, is simply amazing!
    But I gotta tell ya, the picture of the very cool, Del Monte Hot Chili Pepper jar with the cool Mexican, in the Sombrero, and the Zerks in the bottle, held by the hand with the signature stains of experience, to me is perfect for a T-shirt design or possibly a laminated place-mat !
    Who knows where true inspiration comes from !
    It's even more cool that the label says,
    " Distributed in San Francisco "
    Thanks for posting these cool pictures.
    Thanks from Dennis.
  19. Six Ball
    Six Ball
    from Nevada
    OK, I get it and I thought I was so clever using my large reloading br*** tumbler the clean parts. Just had never seen the greed stuff. :oops:
    Del Monte used to make a lot more cool stuff like Sour Pickles that would make you pucker just thinking about them.:eek:
    Ragged Edge, J.Ukrop and 41 GMC K-18 like this.
  20. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Thanks everyone! Taking it one step at a time. When I got home from work today, I was greeted by a box from All Ford Parts on my doorstep. Inside, I found two NOS rear wheel bearings, clips and seals. I'll share some photos tomorrow. In the meantime, here's some A-V8 inspiration!
  21. Six Ball
    Six Ball
    from Nevada
    Will you have the retainers that keep the wheel on when you break an axle?
  22. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Yes! I actually bought a set way back when I was going to race at the RPM Nationals in 2022. They've been patiently waiting in the back of the garage for this moment.
  23. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    HUGE news. Today I got a text from David saying Jeff from Moose Motors dropped off my brakes. It still hasn't sunken in. Drums turned, shoes arced, bearing races repaired, drums blasted—Jeff gave them the full treatment. Saying I'm excited is a major understatement. IMG_4456.jpg
    If that weren't enough, I also received my NOS rear wheel bearings from All Ford Parts in Campbell.
    Some major pieces of the puzzle coming together!
  24. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Oh, one more thing. The other night, I went to go install my freshly painted, early-style oil pan and—you guessed it—it didn't fit. My engine has an 8BA pump, which interfered with the baffles on the earlier pan. Confused, I called Mac Van Pelt and he said running a different pan without a baffle shouldn't be an issue as long as I'm not weaving through a slalom course. I don't plan to (for the time being). So, rather than cut up a super nice pan, I found another one. Enter oil pan number four.
    The best part? It fits! I've scuffed the Ford green, and it's time for primer and paint. I'm getting pretty good at this process!
  25. winduptoy
    winduptoy
    .....glad things panned out for you.....
  26. Tim
    Tim
    from KCMO
    Joey made an efforted update last night, sadly
    the post was widely panned.
  27. Six Ball
    Six Ball
    from Nevada
    But it looks like the pandemic may be over.
  28. Jeff34
    Jeff34
    Ba Dum Tish!
    Outback and 41 GMC K-18 like this.
  29. RodStRace
    RodStRace
    Joey, I guess this is your attempt to prove all those 'aftermarket stuff doesn't fit' threads applies to Genuine Ford Parts too!
  30. Outback
    Outback
    from NE Vic, Oz
    That's Gold!
    J.Ukrop, RodStRace and Six Ball like this.
