Hot Rods Chevy 283.....
Discussion in 'The Hokey Ass Message Board' started by Chev63, Mar 4, 2024.
  1. Chev63
    Chev63
    Gents,
    I have what I believe is a 1963 built 283, (block casting # 3794226) it has a 'hub' as opposed to a harmonic balancer..... What I need is the part numbers for the crankshaft and (short) water pump pulleys.
    Any help very much appreciated!
    tractorguy likes this.
  2. Chev63
    Chev63
    Deuces likes this.
  3. henry29
    henry29
  4. Chev63
    Chev63
  5. 1934coupe
    1934coupe
    Where are you located? Do you need a balancer?
    Pat
  6. Chev63
    Chev63
    All good thanks.
  7. Chev63
    Chev63
    If anyone knows the era correct OEM part numbers that would be great....
  8. henry29
    henry29
  9. henry29
    henry29
  10. Mr48chev
    That "hub" was it on a 283. Those pieces shouldn't be hard to find and the 95 buck asking for what many on here would think asking 10.00 for would be high will have some digging in the junk pulley box.
    1934coupe likes this.
  11. PackardV8
    PackardV8
    FWIW, a highschool friend had a '60 283" with that single pulley setup and every time he wound it tight, the belt would turn inside out.
    I notice you are running an alternator with a notcched belt, so maybe yours will stay straight.
    jack vines
    1934coupe and Desoto291Hemi like this.
  12. Kerrynzl
    Kerrynzl
    Probably because it had a replacement short water pump [Corvette pump]
    Alternator and Generator engines have a slight difference in depth of the water pump pulley flange
    The easy fix is to remove the back cover and press the flange down a bit more
    All replacement pumps are the correct depth for Alternators only
    rod1 likes this.
  13. Chev63
    Chev63
    Any idea what the 'BC' after the part number means?
  14. blue 49
    blue 49
    from Iowa
    I just cleaned up the pulleys from a '64 283 I'm hoping to save and the crank pulley is 6 3/4" and looks like yours. It doesn't have any numbers stamped in it and was bolted to a small, stepped dampener,also without numbers. This is a "D" code 2bbl, power glide engine.
    Gary
  15. Chev63
    Chev63
    Any numbers on the top pulley?
  16. squirrel
    3755820 crank pulley
    3905995 water pump pulley
    this is from the 1964 Chevy parts book
    Chev63 likes this.
  17. Chev63
    Chev63
    Cheers!
  18. blue 49
    blue 49
    from Iowa
    Pics of my dampener and pulleys. No numbers on any of them that I can see. The last pulley was piggybacked on the crank, maybe for power steering that I won't need.
    Gary
    Chev63 likes this.
  19. 05snopro440
    05snopro440
    I bought the Summit pulleys for my 283 and for a 350 in my '62 Bel Air that I was converting to short water pump. I found the Summit water pump pulley was too big and would have slowed down my water pump. I used a stock 70's long water pump pulley on my short pump, it perfectly aligns with the alternator and crank pulley and is smaller diameter than the big summit unit so it doesn't slow down the pump.
  20. squirrel
    that's exactly what it's for.
    Cars with AC got a two groove main pulley. Cars with PS got the added one in front.
    Chev63 likes this.
  21. -Brent-
    -Brent-
    I need the whole shebang for my 327, pulleys brackets, etc.
