Technical Ford 460 Oil Filter Insert/Nipple Too Short??
Discussion in 'The Hokey Ass Message Board' started by insane1, Mar 5, 2024.
  1. insane1
    insane1
    from Ennis TX
    Ok ****** jokes aside........ We have a 57 Ford in the shop that has a 460. The issue is you can only get about a half a turn on the oil filter. We removed the ******, and it looks to be the same one that I can find in every corner of the interwebs.... It is 1-1/4" in overall length. Is there anyone that's ran into this issue, and if you did, how did you fix it? Any info. is appreciated. Thanks
  2. FrozenMerc
    FrozenMerc
    Did the gasket / O-Ring from the previous filter stick to the mount, effectively shortening the ******? I have seen it happen, especially on a freshly painted engine.
  3. What is the number of the filter?
    Desoto291Hemi likes this.
  4. insane1
    insane1
    from Ennis TX
    We have tried 3/4 filters... all the same results.
  5. insane1
    insane1
    from Ennis TX
    No. Newly rebuilt block only ever had one filter since the rebuild, other the other ones we have tried.
  6. RmK57
    RmK57
  7. insane1
    insane1
    from Ennis TX
    I read this same thread, but from my understanding it makes the port bigger but it's still the same length? I was going to call them but that don't have a damn phone number that you can call..... email only. SMH.... I can email I will resort to email if I have too...
  8. Mr48chev
    You do have the correct adapter for a 460 and not one for an FE?
  9. insane1
    insane1
    from Ennis TX
    That is one of the concerns I had but haven't been able to fine a definitive answer on that if there is a difference between the two.
  10. Last edited: Mar 5, 2024
  11. RmK57
    RmK57
    I f that’s the case then it would be female thread for the long hollow bolt which is SAE thread and would never work. I have that style on my Boss Mustang and it takes a 1 1/4” hex socket to remove it from the block. The link I posted is the one you need.
  12. Insane 1
    Insane 1
    from Ennis TX
  13. Beanscoot
    Beanscoot
    Maybe the wrong filter, some have correct thread and gasket but the threaded boss is recessed a bit.
  14. How about a pic of what you have?
  15. So now I hear that Ford even used different oil filter adapters between engine families ?
    I admire you guys for really going the extra mile for your engines .
    Tommy
    loudbang and Desoto291Hemi like this.
  17. RmK57
    RmK57
    Yes it’s awfully complicated, there are two, one for y-block / Fe that bolt-on the side of the block and then the thread on style for everything else.
  18. Is that a 460 block,,,,,good looking (beefy) ,main webs in it .
    The 429/460 engine was one of the best Ford made ,,,,very powerful and sturdy .
    Tommy
    Truckdoctor Andy likes this.
  19. insane1
    insane1
    from Ennis TX
    I couldn't reply on your motor picture, but that is exactly what I need! Thanks for the pic, that was great! Mine is like the one you posted in the Amazon link, so that explains my issue. I knew there was something not right. Now off to find one. I appreciate everyone's help, The HAMB to the rescue again! Thanks Guys!
