Technical ***March 2024 Banger Meet Thread - In Like A Lion Out Like A Banger***
Discussion in 'Traditional Hot Rods' started by Jiminy, Mar 4, 2024.
  1. Jiminy
    Jiminy
    Link to previous month: February 2024 Banger Meet
    Coming Events: (PM Jiminy with additions/corrections)
    April 14, 2024 4 Ever 4 Antique Nationals at Irwindale Raceway in SoCal.
    Stay safe.
    For the HAMB banger newbies, here are some links to a lot of banger info:
    Jim Brierley's book 4-bangers! And me! is a must read book for all banger enthusiasts. US customers send $34.00 all color except for the oldest pictures (includes S/H in the U.S.A.), PayPal welcome, to:
    Jim Brierley, 39480 Colleen Way, Temecula, CA 92592.
    email: jimb4e4@gmail.com
    phone: 951-695-7313.
    A few links to speed equipment companies there may be more
    https://specialtymotorcams.com/index.php#header
    http://www.millerhi-speedheads.com/index.html
    http://www.modelatrader.com/brumfield/brumfield.html
    https://www.hotforhotfours.com/advertisers.htm
    https://www.secretsofspeed.com/speed-parts
    Bert's, Synder's, Mikes affordable also list some speed performance parts.
    Here is a list of most of the prior monthly banger meet links:
    http://www.jalopyjournal.com/forum/s...d.php?t=161498
    Banger basics. another info link list:
    http://www.fordgarage.com/
    http://www.plucks329s.org/index.htm
    http://www.jalopyjournal.com/forum/s...d.php?t=251717
    http://www.jalopyjournal.com/forum/s...ad.php?t=42480
    The link below shows flywheel lightening dimensions
    http://www.jalopyjournal.com/forum/threads/may-bang-er-thread.470853/page-4#post-5212157
    and this link shows the missing image from the above post
    http://www.jalopyjournal.com/forum/...-work-on-bangers.1010716/page-3#post-11427055
    The 4 Banger hot rod picture thread.
    http://www.jalopyjournal.com/forum/threads/the-4-banger-hot-rod-picture-thread.997051/
    Model B rod bearing insert numbers
    http://www.jalopyjournal.com/forum/showthread.php?p=6992484#post6992484
    Engine tuning with a Vacuum gauge
    http://web.archive.org/web/20120415...e.com/tuning-with-a-vacuum-gauge-spg-148.html
    Adjusting dual Strombergs:
    http://www.jalopyjournal.com/forum/showthread.php?p=6638461#post6638461
    Helpful Model A tools and tips:
    http://www.maurer-markus.ch/ford_a/tipps.index.en.html
    Gary in MN's late model Malory distributor conversion for A/B engine:
    http://www.jalopyjournal.com/forum/showpost.php?p=9147025&postcount=109
    Elrod's stuck head tech:
    http://www.jalopyjournal.com/forum/showthread.php?t=218487
    Model A generator to alternator conversion:
    http://ejwhitneyco.com/automotive.html
    Gear ratio / speed and RPM calculator:
    http://www.accuautoparts.com/calculator.php
    Model A master cylinder mounting bracket ideas:
    http://www.jalopyjournal.com/forum/s...73#post4953173
    Go here to read the 1931 edition of Harry Ricardo's book "The High Speed Internal Combustion Engine"
    http://www.scribd.com/full/40610101?access_key=key-w2bcjicdancrnxypd05
    Chevy Banger Stuff
    http://www.jalopyjournal.com/forum/s...d.php?t=463465
    Post 198 starts a great discussion of the shape of a flat head combustion chamber
    http://www.jalopyjournal.com/forum/showthread.php?t=470853&page=10
    T-5 5 speed in a Torque Tube:
    http://www.jalopyjournal.com/forum/showthread.php?t=256226
    Model A & B Style Cast Iron Cylinder Head Compression Ratios.
    http://www.fordgarage.com/pages/headcompressionratio.htm
    meteorpete and Balljoint like this.
  2. winduptoy
    winduptoy
    Testing ..1,2,4 IMG_20240302_130054.jpg IMG_20240302_130039.jpg it seems to always be that three is the problem child
  3. Ugh
    Air compressor candidate?
    J
    winduptoy likes this.
  4. Blinking into the sunlight… first attempt at TIG with a thrown away welder that only works on scratch start - 48ADE4D8-94F5-4DD7-BE83-FD8E3444AAE6.jpeg C245B273-9822-4120-9C7D-0E669B229DD2.jpeg and made myself a header.
  5. Outback
    Outback
    from NE Vic, Oz
    I'm here, nothing much to show but have been working on the RPU just about every day for the last few weeks. We have a local Rod run on & am keen to have the banger there.
  6. Figured out I have an early '28 column in my '29 roadster, hence why my new light wiring harness isn't playing ball. Going to pull the column and see if I can trade it for a '29 and up one.
    The car was put back together out of a couple barns and fields, so I'm thinking its a combo of a couple different years.
      325 KB
      334.2 KB
      418.1 KB
    Okie Pete, mvee33, winduptoy and 2 others like this.
  7. Crazydaddyo
    Crazydaddyo
    Okie Pete and winduptoy like this.
  8. I'd go 2-tooth from a 30/31 if you can - way, way better.
    james1savage, winduptoy and Outback like this.
  9. Balljoint
    Balljoint
    I’m not a banger enthusiast outside of appreciating their mechanical nature, but there is a LOT of knowledge in your post Jiminy, great to see this stuff being shared with others.
    Outback likes this.
  10. winduptoy
    winduptoy
    Sooo, Dan....what do you attribute it to.....
    This is in my buddys car. Not real sooped up but a healthy runner until
    bang... about 5K miles on it.....I've got him a loaner to go in while we sort this out
    Outback likes this.
  11. denis4x4
    denis4x4
    from Colorado
  12. Roadsterguy1930
    Roadsterguy1930
    Hello all. This is my first time on this thread. This is my current project on my 30 roadster. Getting closer to firing it up
    Okie Pete, brjnelson, Jeff34 and 5 others like this.
  13. Dan from Oakland
    Dan from Oakland
    I guess my 1st question would be how much total advance are you running and what's the compression ratio. When I see damage like that, I'm thinking detonation. Did you ever notice any pinging when under a hard pull?
    How does the top ring land look? It does not show in your picture. What brand pistons are these? Does not look like there is alot of support for the top of the piston above the pin, but something caused that top to separate other than just normal running. When the engine was ***embled, were the ring gaps checked? Was there any indication of the engine getting tight or hard to turn over when warmed up? Is there any sign of scoring on the cylinder walls?
    GuyW likes this.
  14. Crazydaddyo
    Crazydaddyo
    These were stock Ford factory pistons. I got the engine well used. I reset the bearing clearances but didn't pull the pistons. I installed my 7.5-1 head, mild cam, and dual Stromberg intake. I probably only ran it for 2-3000 miles until it did this. It didn't owe me anything, so I didn't ****yze the failure that close. I just took it that the stock pistons were not up to what I was making them do. I was fortunate that it gave up while I was idling at a light. When I tore it down, I just cleaned everything, ran a hone through it to break the glaze and installed new Federal Mogal modern style pistons and rings, and ran it until I knocked out the rod bearing babbit at the drags. That set up lasted @ 7-8000 miles.
    Dan
    fur biscuit, winduptoy and Outback like this.
  15. Stovebolt
    Stovebolt
    I'm still here, without any news, just soaking up the sunshine
  16. 282doorUK
    282doorUK
    GuyW and winduptoy like this.
  17. burl
    burl
    from Minnesota
    Been busy making trinkets need to build an engine soon. db1.jpg db2.jpg db3.jpg db4.jpg db5.jpg db7.jpg db8.jpg db9.jpg db10.jpg db11.jpg .
  18. winduptoy
    winduptoy
    22 degrees total advance at about 2800 rpm....we are running around at 7000' elevation and he is as deaf as a post
    ring gap was checked and he believes that the top rings were gapped at .018....
    the engine has 7:1 compression on a Lion II head
    we are thinking it was just a faulty piston and he doesn't recall where he got them but nothing exodic
    no tight turning engine prior to it failing
    no piston wall scoring...and it was being torn down later on because it was using oil....he used a full synthetic during the 'break in period' and the rings never seated
    we will tear into it later
    Okie Pete likes this.
  19. hotrodA
    hotrodA
    Since I have one, I was knocked over with the huge article (13 pgs) in the January Secrets of Speed magazine on the Alexander Racing head and its innovative maker, Colonel Alexander. Lots of old photos of him and the different speed parts he manufactured, including Spin Dizzy small race cars. Thanks to Charley Yapp and author Ken Robertson for filling a big gap in my knowledge of these rare bits of racing history.
    Awesome info for any banger enthusiast.
    SOSS #33-3, January 2024:
    Mine:
    Old Dawg, Six Ball, Okie Pete and 9 others like this.
  20. burl
    burl
    from Minnesota
    That was a great article.
  21. Hey fellas
    Time to move this McDowell 2port head
    The gentleman I acquired it from broke the crank and it has been sitting for 20 years
    No cracks visible
    $3500 takes it
    Shipping available at cost
  22. Dan from Oakland
    Dan from Oakland
    OOH! don't have one of those!!
  23. we can correct that for you.....
  24. Kevin Pharis
    Kevin Pharis
    from Califunny
    If only I hadn’t bought 3 overheads in the last few weeks… and if only I had a model A…!:eek:
  25. Maybe time to upgrade to modern old junk?
    J
    Outback and winduptoy like this.
  26. Dan from Oakland
    Dan from Oakland
    Nah- ya gotta keep and work on the "old" junk, so that when you work on the new modern old junk you can convince yourself that you can work on this new stuff too!!! Phew! did I really say that?
  27. Dan,
    is it work when you can open up a catalog and just order the parts? My wife may not like the credit card tool too often.
  28. Pulled the rods today, second ring on the first piston came out in 2 pieces. Put the rings back in their respective holes and checked gap at a the same depth:
    Dan noted last month that "Ring pack should be .125, .125 and .187 oil. Any scoring on the skirts or ring lands?"
    One:
    #1: 0.045
    Two:
    #1 0.046
    #2 0.058
    Three:
    #1 0.048
    #2 0.052
    Four:
    #1 0.046
    #2 0.045
    did not try to remove the oil wiper ring
    MTFCa says 0.003 x bore to set gap. Seems a bit worn?
    Seems the original builder tried really hard to balance the engine. Happy March! IMG_0467.jpeg IMG_0468.jpeg
    winduptoy, Okie Pete and Outback like this.
  29. Outback
    Outback
    from NE Vic, Oz
    Aye-yai-yai!!!! There is no doubt they went to some effort!
    winduptoy and fur biscuit like this.
  30. Checked the pistons at 90 degrees to pin, on center of the plane.
    Piston - Cylinder bore (U/M)
    #1 3.788 - 3.7910 / 3.7915
    #2 3.783 - 3.7905 / 3.7900
    #3 3.785 - 3.7910 / 3.7920
    #4 3.784 - 3.7910 / 3.7905
    The webernets says to use piston diameter x 0.004 to determine bore? ***ume, as long as bore is smaller than that, all is ok?
    Piston x 0.004 - cylinder bore (U/M)
    #1 3.80315 - 3.7910 / 3.7915
    #2 3.79813 - 3.7905 / 3.7900
    #3 3.80014 - 3.7910 / 3.7920
    #4 3.7991 - 3.7910 / 3.7905
    Can I hone and re-ring this, or will it need to be punched out?
    thank you.
    Outback likes this.
