Projects Bought a Mercury on purpose
Discussion in 'The Hokey Ass Message Board' started by anthony myrick, Feb 4, 2023.
  1. Leaning towards Lincoln push ****ons. Front only.
    I need the lock mechanism but wondering if I can camo that in the drivers door side trim.
    Probably gonna shave the bezels some more
    And make the call on the bottom radius.
    that’s a killer idea for a hidden door ****on.
    Sancho, Okie Pete, williebill and 2 others like this.
  2. J. A. Miller
    J. A. Miller
    from Central NY
    I like that too.
    anthony myrick likes this.
  3. BamaMav
    BamaMav
    from Berry, AL
    Drivers side, ****on to open fuel door. P***enger side, ****on to open trunk.
  4. This popped up on a random taillight search. No info.
    Probably a European car.
    I like the shape of the original lights.
    I don’t like the bulkiness of the bezel.
    I’m going to trim it down probably at least another 1/8.
    I like this thinner style bezel.
  5. ekimneirbo
    ekimneirbo
    Both ways look good, but I'm thinking that once you pull the bumper up closer to the body, The flat surface of the bumper will compliment the flat surface of the light.
  6. Used 3/8 tape and trimmed down the bezel some more.
    Will probably stop here and build the bucket
    bchctybob, Squablow, 1low52 and 8 others like this.
  7. Dick Stevens
    Dick Stevens
  8. s55mercury66
    s55mercury66
    from SW Wyoming
    For some strange reason, I have always wanted to use Harley tombstone taillights on a '49-51 Mercury.
  9. We might just trim the thickness and length and look at em
    I kinda dig em
    Just too thick
    guthriesmith and Okie Pete like this.
  10. If I were doing that I would terminate the Skirt right at the vertical seam where the lower quarter ends and the taillight extension come together. Then the corner radi needs to match the factory radi, not so squared off as the corner is now. You won't know if it's going to work with the rest of the package until it's done and too late to go back on the skirts.
    Okie Pete likes this.
  11. Eddie
    Eddie
    from Georgia
    Sell those cruiser skirts and make some flush mount skirts. Possibly use a lower section of a Merc. door as contours should be close.
    Eddie
  12. Too late
    We whacked em
    I’m not a big flush mount fan.
    drdave, Okie Pete, williebill and 3 others like this.
  13. It’s just metal
    It’s never too late
    I can’t weld gl*** though
  14. Gonna thin em down a little more and tac the end on to flow with the stainless
  15. I dig em
    it’s just skirts.
    You can change em like shoes
    Moondog13, drdave, Squablow and 8 others like this.
  16. Moriarity
    Moriarity
    SUPER MODERATOR
  17. More fat removed
    shrunk top and bottom edges to flow better
    We ain’t welding em in
    Just wanted something different. I’ll still paint the stock ones. Maybe change em out often.
    theses skirts were $100. The lip that held the seal was bad. Nothing lost.
    the upper portion of the top at the rear will get a slight radius.
    The foward, lower section can be shaped to flow with the door jamb. Just like the originals.
  18. Messed with em a little more. No students today, so I made some notes for them to take care of.
    Need to shrink the top edge a little more to flow with the body. Split the end we cut off and section it to fit the rear.
    Thin down a little more fat to fit the contour of the front quarter panel.
    We bowed the bottom edge to flow with the body contour. That got the skirt off the rear tire. Flows much better
    they ugly but I’m liking it.
  19. bobss396
    bobss396
    Nice progress. The leading edge of the skirt is definitely fighting with the rear door line.
  20. We might change that
    Well get the rear done then check out the front
    Okie Pete and bobss396 like this.
  21. MMM1693
    MMM1693
    Very interesting...
  22. Roughed out a new leading edge
    hammer, trailer hitch ball in a vice and a shrinker/stretcher.
    Just an experiment to see what could be done.
    Kinda like it
  23. Little more work
    drdave, Squablow, Sancho and 6 others like this.
  24. wheeltramp brian
    wheeltramp brian
  25. Looks great! Just make sure when it’s finished, you don’t park on the street in front of the TV shop and find Curt Henderson sitting on the front fender.
  26. It’s already scratched.
    At my speed, the initiation into our club would probably be staying up past 10pm
  27. patsurf
    patsurf
  28. bobss396
    bobss396
    That's what SHE said.... :rolleyes::rolleyes::rolleyes:
