Projects Mid Life Crisis 62 Vette
Discussion in 'The Hokey Ass Message Board' started by squirrel, May 12, 2023.
  1. Deuces
    Deuces
    Perfict!....:)
    Algoma56, scotty t and 41 GMC K-18 like this.
  2. snoc653
    snoc653
    from Iowa
    Those girls may be ***y, but that little red corvette is ***ier than the three of them combined. That is a nice ride!
  3. ricky_tbird
    ricky_tbird
    I have a question if you don't mind. I am only up to page 20 so may have been discussed. Looks like you used a front mount on your 327 and a rear mount on the 4 speed and no mid-mount on the bell housing. Any problems? Putting together an old 54 that will have an sbc and 4 speed and trying to figure out if I need an early bell with the mid-mounts. Thanks!
  4. squirrel
    The early Corvettes were built that way...front mount (at the water pump bolts), and rear mount at the transmission tail housing. They had aluminum bellhousings with an open bottom, too! They don't seem to have any problems because of the mount setup. Except that you have to keep the water pump bolts tight! or it starts leaking, then later the engine falls out.
  5. My wife keeps a hat in my 57
    enloe, Truckdoctor Andy and Deuces like this.
  6. Jiminy
    Jiminy
    Just to remind you of how Grace Kelly pulled off the scarf look [​IMG]
    enloe, thehazguy, Deuces and 10 others like this.
  7. stingbean
    stingbean
    enloe, Thor1, impala4speed and 3 others like this.
  8. squirrel
    Meanwhile....
    The boiling fuel issue is still here, maybe it's the winter gas and slightly warmer weather that's doing it. Stop for a few or a lot of minutes for gas or shopping or whatever, get back in, it might start right up, then die, or go a short ways and die. I tried a computer fan blowing through the heater intake hose last summer, it helped (I had the hose disconnected from the heater, and wired the open end in place next to the carb). But now that it's still heater season, that won't work.
    These cars have another hole in the radiator support on the drivers side, for the fuel injection air cleaner intake. I decided to use that to run another duct hose, to blow on the carb. I added the computer fan, and used a magnet to stick the duct to the air cleaner base. I ordered an adjustable thermal switch, which I'll mount near the carb, and it will ground the fan when the temp is too high. The fan only draws a quarter amp, so it won't run down the battery if it runs for a while.
    I had to remove the hood to get in there to work on it, but the hood is back on now.
    Tow Truck Tom, enloe, brEad and 14 others like this.
  9. squirrel
    I'm not into trying to find special fuel to run my old heaps...I have enough trouble just keeping them running! :)
    enloe, Thor1, scotty t and 3 others like this.
  10. y'sguy
    y'sguy
    from Tulsa, OK
    I solved my similar fuel issues with an old school Airquip inline fuel pump. it's wired so I can turn it on before I try to start up. It has really helped for quick starts under just the conditions you speak of. Also it has saved me a few times in the hot summer months with vapor lock or boiling.
    enloe, Thor1, Chief 64 and 3 others like this.
  11. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Carter M6900 made a huge difference in the red 56. So much so I’ll be doing away with the electric fuel pump and this set up in the 57 soon. IMG_0691.jpeg IMG_0692.jpeg
    enloe, Thor1, scotty t and 7 others like this.
  12. Deuces
    Deuces
    L-79 intake swap?????..... And, or a cool can???....
    enloe likes this.
  13. squirrel
    There are a few more tricks to try...blocking the heat riser p***ages, insulating spacer under the carb, etc
    If I find an old aluminum intake I'd like to try that, too. If it's the right one...dual plane, old, but a decent design. The factory one would be good. Or an old aftermarket.
    enloe, Thor1, SS327 and 6 others like this.
  14. Deuces
    Deuces
    A 160° thermostat usually helps also....
    enloe likes this.
  15. squirrel
    the engine temps have been cool, but the fuel issue happens.
    enloe likes this.
  16. Deuces
    Deuces
    Ok, are fan pulleys all the same diameter for small block chevy???? I know I won't be able to talk you into a clutch fan....:rolleyes::oops:
    enloe likes this.
  17. squirrel
    It has a fan clutch,, shroud, pulleys are original size, etc. The radiator is too small (it's the original size). But the fuel percolation problem happens when the engine is running cool.
    enloe, Thor1 and Deuces like this.
  18. I was going to suggest a phenolic spacer but I didn't think you had room for it.
    enloe, warbird1, Deuces and 1 other person like this.
  19. Oneball
    Oneball
    My Vette did the same, you could hear the fuel boiling in the float chambers, I was sceptical at the suggestion but a half inch plastic carb spacer cured it.
    enloe, Jokester, Deuces and 2 others like this.
  20. squirrel
    The air cleaner was on the car before was almost touching the hood...but I found a stock one and now it has enough room. I ordered a spacer a couple days ago. I'll need to block the heat p***ages under the carb before I install it, either by changing intake gaskets, or plugging the two holes in the carb flange.
    enloe, Thor1, Deuces and 4 others like this.
  21. Aaron65
    Aaron65
    from Michigan
    It's cheesy, but I've had good luck for years with a Mr. Gasket "Gasket Stack." It has something like three gaskets with aluminum plates in between. Up in Michigan, I don't like blocking the heat riser p***ages because I like driving my stuff as much as I can and they get pissy without the extra heat when it's cold. I'm using them on my '63 Riviera and my '65 Skylark. About every 10 years, I'll replace the lowest gasket because it gets a little coked up by the exhaust p***age, but I've been running it on the Skylark for over 20 years. It made a big difference, and the stack only ends up being a quarter inch tall (or maybe three eighths).
    Thor1, Deuces, rumblegutz and 2 others like this.
  22. squirrel
    I have one of those gasket stack spacers, I was looking at it...but of course it's for a normal carb, not the WCFB with it's small throttle bores. I was thinking about how I would go about making one, I have a chunk of sheet aluminum the right thickness, but it looked like a lot of work, so I just got on the internets and found a guy making the phenolic one, and ordered it.
    enloe, porkshop, Thor1 and 5 others like this.
  23. Ventilate the hood. Know anyone with a louver press and some experience pressing fibergl***? ;)
    enloe, WC145, '28phonebooth and 5 others like this.
  24. e1956v
    e1956v
    Alliance Vendor
    Jim can you post a link for the WCFB phenolic
    Spacer?
    enloe likes this.
  25. SS327
    SS327
    A tunnel ram would keep the carbs cool. :oops:
    porkshop, Deuces, 427 sleeper and 2 others like this.
  26. squirrel
  27. squirrel
    that's been on my mind, just wondering how it would work out with the gearing I have....and I have couple road trips planned this year.
    porkshop, Thor1, Deuces and 1 other person like this.
  28. AmishMike
    AmishMike
    Work on hood lock down so remains open one inch while you drive but still tight. One inch gap to let hot air escape
  29. squirrel
    It's just fine when I'm driving, it only is a problem when I park, shut it off, then start it up and drive away after several minutes. Opening the hood all the way does help, but I don't always remember, and it's a little bit of a nuisance.
    porkshop, Thor1, Deuces and 3 others like this.
