Customs Yes, it's a '56 Ford!
Discussion in 'The Hokey Ass Message Board' started by 1stGrumpy, Sep 26, 2020.
  1. I finally got around to rebuilding the front end last week and installing the Aerostar front springs that I had bought over two years ago. Got the drivers side done, replaced the upper and lower control arm bushings and upper and lower ball joints and installed the Aerostar spring... IMG_20240212_143934.jpg IMG_20240221_163320_6CS.jpg
    ...new spring compared to the original...
    ...and then moved around to the p***enger side. Unforunetly things didn't go as smoothly as the drivers side, had to break out the torch and cut off two of the four bolts holding the backing plate on and then cut the lower ball joint in half in order to remove the lower control arm. Finally got everthing off, I don't think that any of this stuff had been apart since 1956! The lower control arm is junk and will need to be replaced...
    Once again, I am waiting on parts!
  2. y'sguy
    y'sguy
    from Tulsa, OK
    That can be a tough job. When I di my 55 thunderbird, I was warned and complied to drop a length of heavy chain down thru the spring before trying to breaks these apart. It worked. Immense amount of power contained in that spring.
    So are you able to get a new or good used A arm reasonably?
    drdave and 1stGrumpy like this.
  3. Yes, I found a good used one for $50.00 plus the shipping. I have dealt with this guy in the past, parts are always as he descibes if not better. The only negative is he is in Idaho so shipping is a little higher.
    When I am going to separate the control arms I always place a floor jack under the lower control arm and leave about half an inch space between the two, loosen the nut on ball joint about the same distance and then use a pickle fork to loosen the ball joint and then lower the control arm with the jack.
  4. drdave
    drdave
    Well now that you are fresh on your skills with front end work, wanna come put the new A arms on the Chevy for me? lol
    Looking good Jim! How much did the new springs bring the front end down?
    Sancho and guthriesmith like this.
  5. Gee, you should of said something sooner Dave. I went to Little Rock Tuesday, I could of stopped by and replaced them for you on my way back home!
    I haven't gotten it back down on it's wheels yet but, if I remember correctly, it should drop it around 3 inches. I'll post some pictures of it when I get it done.
    Sancho, guthriesmith and drdave like this.
  6. Finally got it back together and back on its wheels. The control arm that I bought out of Idaho didn't fit, the bushings were too big for the arm so we repaired my old one and I used it. Now I have to see if I can get my money back without a lot of h***le. Fingers crossed!
    I like the stance a whole lot better than before, must be a west coast thing...
    I'll get some better pictures this weekend once it stops raining.
    Sancho, guthriesmith, drdave and 5 others like this.
  7. What they call a "California Rake" and what I call the "perfect stance"! lol Just need to get the alignment done...
  8. drdave
    drdave
    Nice!!!! Love it Jim!!
    Sancho, guthriesmith and 1stGrumpy like this.
  9. Thanks Dave! I'm looking forward to seeing the '58. Are you going to take it to Dewey?
  10. drdave
    drdave
    Yes. Got it home Wednesday, but have been gone the rest of the week, so haven’t been able to mess around with it. Will make its Conway road debut tomorrow going to work. Lol
  11. Kool! Let me know if you want to run up together...
    Sancho and drdave like this.
    loudbang, Oneball, Tim and 4 others like this.
  13. straykatkustoms
    straykatkustoms
    Looking too kool!
    1stGrumpy and Sancho like this.
  14. drdave
    drdave
    Looks great Jim!
  15. guthriesmith
    guthriesmith
    Yep, what Mick and Dave said. :cool:
  16. MMM1693
    MMM1693
    I like it!
    1stGrumpy likes this.
  17. At a local car show this past Saturday... 447975709_8431738436840703_1272993021268866975_n.jpg
  18. straykatkustoms
    straykatkustoms
    Too kool! Great job of power parking your kustom. Lol!
    1stGrumpy, Dos Cincos and Sancho like this.
  19. drdave
    drdave
    Looking good Jim!
    Sancho and 1stGrumpy like this.
  20. Somebody had to do it!
  21. 1SAWB
    1SAWB
    love it
    what did you end up doing with the skirts?
  22. @1stGrumpy wheat year areostar springs did you use?
  23. They are Moog CC850 and fit 1986-'97 Aerostar.
    Hot Rod Ron likes this.
  24. Thank you. I sold the skirts.
