Projects Mid Life Crisis 62 Vette
Discussion in 'The Hokey Ass Message Board' started by squirrel, May 12, 2023.
  1. e1956v
    e1956v
    Alliance Vendor
  2. ClayMart
    ClayMart
    Is there a filament for 3D printers that can withstand the temps between the intake and the carb?
  3. Johnny Gee
    Johnny Gee
    from Downey, Ca
    “drive away” as in accelerator shot is weak or not there?
  4. milwscruffy
    milwscruffy
    What, no wooden clothes pins on the steel gas line ? :D
  5. Johnny Gee
    Johnny Gee
    from Downey, Ca
  6. squirrel
    It usually starts and idles and runs for a short time, then suddenly dies, and might need to crank for a bit before restarting...and might die once or twice more.
    kind of dangerous when it dies just after you pull out onto the main road.
    SS327, Thor1, scotty t and 1 other person like this.
  7. Moriarity
    Moriarity
    SUPER MODERATOR
    vapor lock?
    porkshop likes this.
  8. squirrel
    It doesn't act like the fuel isn't pumping to the carb. I've had that happen on others...
    Anyways, I'll get the duct thing working and see how it does, and proceed from there. Lots of discussion about this stuff on the early corvette forum, too.
    with the occasional guy way up north who wonders what the fuss is about
    bchctybob, WC145, porkshop and 3 others like this.
  9. 1946caddy
    1946caddy
    from washington
    Had a 68 Corvette that would do 100 mph on the freeway but would die going over a steep hill at a low mph.
    Would also not want to start after sitting for a few minutes but was OK after about a ten minute wait.
    Turns out it was a partially plugged inline fuel filter at the tank. Replaced fuel filter and problem solved.
    Beanscoot likes this.
  10. Moriarity
    Moriarity
    SUPER MODERATOR
    Mine doesn't do it, It gets 100 degrees here at times, but I don't run corn gas and I have the heat risers blocked and it has 4 carbs. When I first got it I had some trouble with vapor lock. right or wrong I added an inline elect fuel pump on a switch and the few times it vapor locked after that the elect fuel pump overcame it
    bchctybob, porkshop, Thor1 and 2 others like this.
  11. Johnny Gee
    Johnny Gee
    from Downey, Ca
    That describes what I was experiencing.
    porkshop and squirrel like this.
  12. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Forgot to mention. I had percolating of fuel post fuel pump. Something to look for with… IMG_1960.jpeg
    Once I knew all was doing well again I went back to an all steel filter like yours.
    bchctybob likes this.
  13. I've got a 62 Vette 340 hp aluminum intake that's ugly enough to be dirt cheap if you want it.
  14. squirrel
    I still have to send you a box of brake parts, too....it's sitting in the garage waiting for me to mail it.
  15. Deuces
    Deuces
    Pictures please.....
  16. Jim has dibs on it, if he doesn’t want it i’ll gladly send you some pics
  17. bobss396
    bobss396
    Is it possible that this is a heat-soak electrical issue? IIRC you run points, but a condensor or coil could break down when hot. Both are easy and cheap to rule out.
    porkshop, squirrel and Aaron65 like this.
  18. squirrel
    did the same thing with two different distributors....not likely.
  19. KoolKat-57
    KoolKat-57
    from Dublin, OH
    How about a filter with a return line to the tank.
    I have one on my '64 Avanti, it was a factory fix for the same problem
    KK
    Randall, Deuces, loudbang and 2 others like this.
  20. squirrel
    Getting to the tank to add a return line is kind of a pain on this car...but that is one of my last resort tricks.
    bchctybob, winduptoy, Deuces and 3 others like this.
  21. tjet
    tjet
    I got a phenolic spacer from this guy.
    https://www.ebay.com/itm/2354088477...gISxgvHZbcCQLjrT5MnepIbWt6|tkp:Bk9SR_6h7aPFYw
  22. Oneball
    Oneball
    I have a return line on mine and it still did it, spacer fixed the issue.
    squirrel likes this.
  23. squirrel
    Deuces, porkshop and tjet like this.
  24. SS327
    SS327
    Cheep *** me would have just cut one out of some plywood.
    bobss396, impala4speed and squirrel like this.
  25. Moriarity
    Moriarity
    SUPER MODERATOR
    is it possible the heat riser is stuck shut sending all the exhaust from that side thru the intake and heating the carb?
    porkshop and guthriesmith like this.
  26. squirrel
    The heat riser is stuck open...
    winduptoy, Deuces, porkshop and 3 others like this.
  27. Dick Stevens
    Dick Stevens
    Time for a set of fenderwell headers! :D
    Deuces, bobss396, SS327 and 2 others like this.
  28. When I had my last 340hp '62 45 years ago I ran a phenolic spacer and blocked the heat riser ports to the carb base and got rid of any vapor lock problems. No electric pump or clothespins.
    porkshop, Thor1 and squirrel like this.
  29. squirrel
    I wish I could buy some 45 years ago gas!
    41 GMC K-18, porkshop, Thor1 and 8 others like this.
  30. Beanscoot
    Beanscoot
    100LL aviation gasoline is probably pretty close...
