2.25" wishbones on a 2 inch axle?
Discussion in 'The Hokey Ass Message Board' started by Rocky, Jun 28, 2011.
  1. Rocky
    Rocky
    Classified Editor
    I bought a pair of split 'bones represented as 36 ford units to use on my dropped heavy 32 axle. Both 32 and 36 axles and bones should be 2 inch but when the 'bones arrived they measured out at 2 and 1/4 inches. I believe they're a split model A wishbone. I have no first-hand experience trying to insert a 1/4 inch spacer to make the split bones fit a 2 inch axle but don't see why it wouldn't work. I'd like to keep these split bones as they're really nice.
    Anybody tried using a 1/4 inch spacer to make this work? Any problems?
    hrm2k likes this.
  2. el Scotto
    el Scotto
    from Tracy, CA
  3. roundvalley
    roundvalley
    spacers are common fix. Have never heard of a problem. There should be a big difference in the length of the bones. I.E. Model A compared to '35. What is the length??
  4. i have done it and it works just fine
    i actually think mcmaster car sells a thick washer that is perfect...if you dont want to go the speedway route
    tk
  5. Atwater Mike
    Atwater Mike
    That's right, common fix. (Most axle mfrs. offered these spacers when they only had axles with 2" bosses...)
    Spacers go on the BOTTOMS of the axle bosses.
  6. RICH B
    RICH B
    I just cut a slice of 1-3/8" round stock and made a spacer that more closely matched the diameter of the wishbone yoke. Blends in and is not very noticeable.
  7. oldskoolflyer13
    oldskoolflyer13
    May have a proposition for ya...i bought bones represented as 2.25....and well they are 2".....and damn near perfect bones. My '32 heavy duty style (from CE) is a 2.25, did you opt for a 2"?
  8. oldskoolflyer13
    oldskoolflyer13
    I also have some 32?? split bones that are 2" axle boss.....not as smooth as the ones above. If you want pics of the 32? bones or wanna work something out...let me know
    Whats the length of the ones you have?
  9. xix32
    xix32
    besides being 2 1/4" wide at the perch yoke, the model "A" wishbone doesn't seem to have as much ( if any) positive caster built into it as the `32-`34 does.
    you might want to cut the tube apart at the factory weld to the yoke forging and cut a pie section out and reweld it back together with more caster.
  10. HotRodMicky
    HotRodMicky
    Maybe 37-41 bones.
    They are 2 1/4
    Michael
  11. Auggie Dawgie
    Auggie Dawgie
    from New Jersey
    Has anyone ever heat and bent the yolks? on a 2.250” wishbone to match the 2” axle? I bought an old hot rod with a 32 axle and model a bones, and the wishbones “yolks” (front part) are bent to 2” in the back and 2.125” in the front so the spacers I bought won’t work. I was thinking of just bending the front to 2” to get them to work.
  12. doctorZ
    doctorZ
    I have never seen this but the ends are forged so I ***ume it is possible and that someone has done it. That being said, it would be tough to keep the eyes parallel when bending them. IMO, the spacer is by far the easiest way to go.
  13. Auggie Dawgie
    Auggie Dawgie
    from New Jersey
    haven’t checked the Hamb in a while, but if anyone will check this down the road, my friend and I ended up heating them back within 0.010”.
    We c clamped the yokes together and heated the top part of the yoke and then slowly pulled in the c clamp. Worked like a charm. It wasn’t necessarily bending the metal just heating it up within the fixed c clamp to allow the metal to “relax” back to the 2” spacing.
    We went too far and used vise grips that push outward and brought it back into spec using the same process but in reverse. I used calipers to measure the backside and frontside of the yoke.
    19Eddy30 and Budget36 like this.
  14. nobby
    nobby
    Fyi. 35 and 36 bones are 2 inch
    They look similar to 37 up, which are 2 1/4
    Just bought a drilled so cal axle at 2 quarter, and need to use the unsplit 36 bone for 2 inch
    Worth noting. Perch pin bolt lengths. 5 inch long 4.5 under head
    5/8ths
    16mm just a tad bigger if wobbly
    Socket cap screw, milling the taper washers
  15. Budget36
    Budget36
    Just curious (I’ll most likely never need to) is the top and bottom shimmed, or top or bottom, or makes no difference?
  16. Auggie Dawgie
    Auggie Dawgie
    from New Jersey
    The shims I bought on Speedway (think they were in the beginning of this thread) gave me 4x 0.125" shims so I am ***uming they go top and bottom. That being said, I read in the vern tardel book that if you do use shims they go on the bottom.
    Looking back, I should've just made the spacers myself on a lathe and made 2x 0.250" spacers out of stainless, but I didn't need to after straightening the wishbones I had.
    Budget36 likes this.
