Technical What are you working on?
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 18, 2022.
  1. squirrel
    Older Airstreams have the separate cable setup....
    Truckdoctor Andy likes this.
  2. Airstreams are cool! I didn’t know they did that! I just copied tractor trailers.
  3. Bandit Billy
    Bandit Billy
    Heaters are on, music is on, a weekend of detailing ahead of me.
  4. chevyfordman
    chevyfordman
    Finished up putting a carb kit in the old 97 so it's ready to go. IMG_2037.jpeg
  5. Helping the kid with his newly acquired $40 aluminum hard top IMG_7668.jpeg IMG_7666.jpeg
    Jeff34, enloe, orbitup and 21 others like this.
  6. guthriesmith
    guthriesmith
    Finally getting around to finishing up the brake job I started a few weeks ago. Traveling for work and starting a new job have kept me busy enough I haven’t had much spare time. And, I had to order lots of new parts so that also slowed me down. Oh, and I am also building a couple awards to give away at the SWMO Hot Rod Hundred that will be the first long trip for the car I am working on that it has been on in years. :cool:
  7. Dave Mc
    Dave Mc
    My son washed two of mine, the 29 pickup and 48 Ford coupe, checked oil, water and brake fluids etc. ready for spring if it ever shows up .
    enloe, mad mikey, Okie Pete and 13 others like this.
  8. jimmy six
    jimmy six
    After making sure our grandson wanted to return to Bonneville and securing 2 rooms for SpeedWeek on Monday it was time to install the GMC back in our XO Gas Roadster. A new solid clutch disc was found and installed along with general Bonneville clean up.
    New for 2024 is the Long V-Gate style shifter for the old Tex-101 now serviced by G-Force Transmissions.
    Belts and helmet have 2 years left and the fire bottles were serviced last year so we have 1 year left.
    Now if I can just figure how this puzzle goes together. :rolleyes:
    enloe, 29A-V8, chevy57dude and 17 others like this.
  9. Cleaning up filthy trans parts
    Except that main shaft and couple odds and ends. Those were super clean
    Thanks @Hillbilly Werewolf
    Son is building patch panels for his Jeep
    enloe, mad mikey, Okie Pete and 10 others like this.
  10. HOTRODNORSKIE
    HOTRODNORSKIE
    Built my olds 303 20 years ago and never fired it so I decided to make some changes and tare it down to check some things out. Had Tony make me a roller cam and bought a duel roller chain and some better head gaskets from him.
    enloe, mad mikey, Okie Pete and 11 others like this.
  11. 57 Fargo
    57 Fargo
    Spray bombed some primer on the rear wheels for the Barracuda project, I re-hooped and reversed the wheels so I had 14x6” small bolt mopar wheels
  12. choptop40
    choptop40
    Got a set of LED strip lights and holy cow they sure are bright . Saves alot of money as they use next to nothing in energy..... A0FA6FF7-4A5A-4D45-9A5B-76DDAA8A8FC3.jpeg 27A13718-02F3-4F21-AD9F-1605AD326222.jpeg
  13. Sandcrab
    Sandcrab
    I have spent a couple weeks searching for the dust cover for the 215 Buick with no luck, so today I metalworked an SBC cover.
    rod1, mad mikey, Okie Pete and 11 others like this.
  14. nochop
    nochop
    from norcal
    Heater for my 5 window IMG_6616.jpeg IMG_6617.jpeg 73172315163__D8A91BF6-6D2C-4430-B608-ECACD1D3C03F.jpeg
  15. 319 ***embly.
    Gaskets will be in tomorrow
  16. Hmmmm
    The book shows a washer between the rollers and thrust washer
    an online one shows it without them
    I’ve got one with em. And one that didn’t have any when I removed the cluster. Took the cluster back out after I looked at the book.
    This is the washer
    from another trans.
    Hmmmmmm
  17. swade41
    swade41
    from Buffalo,NY
    I got 2 out of the 3 brake parts ordered delivered today, just waiting on the new manual master cylinder, but got the Hurst line lock and the Wilwood proportioning valve in.
    Pulled the master cylinder off I just made everything for, but after putting it all together I realize it will not work, the mounting holes might be off an 1/8 on this new one coming in.
    Since it reached 50 degrees I decided to tackle the daily's lift gate switch and rear gl*** ****on out in the driveway, these new car engineers need to turn wrenches on this **** they design, holy hell.
  18. saltflats
    saltflats
    from Missouri
    Working on the rear brakes on the 1 ton ramp bed, ugh.
  19. swade41
    swade41
    from Buffalo,NY
    Got all the pieces and roughed in the mounting holes for the new master cylinder that came in right before I left for the cardiologist, I need something easier than a rat tail file to slot half inch thick brackets.
    Tomorrow I'll dress up the oblong holes in the bracket and map out the placement for the line lock and adjustable proportioning valve.
    I need to swing over to napa and pick up brake line and a battery since now I'll have the J and the truck both out this summer, no more sharing one.
  20. guthriesmith
    guthriesmith
    Finally finished my brake job and was starting to think I was making progress so went for a drive around town including a few 7,000 rpm blasts through the gears. Anyway, got back to the shop to find oil dripping from several areas and I have yet to find the big leak. Gotta love this stuff… :(
    rod1, mad mikey, Tickety Boo and 10 others like this.
  21. choptop40
    choptop40
    De - Frenching the bug eye look on the 50 Desoto...They were not frenched , actually extended out...First thing I thought about redoing when I got the car.... 0839907C-8BCC-4B5E-B460-08AC1FF19F54.jpeg 058861F0-DB75-4E00-8166-3D66D2239CED.jpeg 476C3785-DD57-49F3-8BD4-F765432CFEB6.jpeg
  22. 67drake
    67drake
    from Muscoda WI
    IMG_0957.jpeg Just warm enough to spray paint yesterday. So stopped at the Hardware and got some paint. They had a Rustoleum 2000 degree paint. Never used this before, but it only came in flat black and white.
    So sandblasted, and threw a couple coats of paint on yesterday. They turned out OK. Beats them looking out of place on a clean rebuilt engine.
  23. snoc653
    snoc653
    from Iowa
    Spent most of the day drying and moving tools, manuals, and parts. The shop addition ****s up against the old shop. Contracted had to cut the roof back to put the wall up and cut it back past flush. It rained last night and the water ran down and into the shop all over everything. The addition was supposed to be done prior to the roof coming off the old part.
  24. Sandcrab
    Sandcrab
    I removed the heads from one of the 215 Buicks I picked up recently and ended up pulling the threads from a couple of the head bolt holes. I needed to Helicoil them so I made a drill and tap guide to ensure a square and properly spaced hole. I made one row for the drill, and the other for the tap with the shorter spaced holes for across the deck.
    simplestone, rod1, mad mikey and 12 others like this.
  25. Gastrap
    Gastrap
    Finished converting the '50 Chevy truck from vacuum to hydroboost brakes. Should have done this from the start. The '85 truck boost unit works great with my 70's era disk/drum setup, using the same Firebird master and valve.
  26. choptop40
    choptop40
    Getting the p***enger side De- Frenched……stock bezel in place to compare .. AADB7621-A9C6-46EC-ABC5-373ACF55BA8C.jpeg 436970EA-E4B1-443F-A82E-B82BDEE405C2.jpeg
  27. squirrel
    Plugged the exhaust holes to the carb base, installed an insulating spacer....
    Okie Pete, enloe, Johnny Gee and 17 others like this.
  28. Got the 319 back together
    had leftovers :)
    used a nice low mile 318 guts in an extra OD case. Used the OD parts from the busted 319 I started out with.
    Okie Pete, enloe, mad mikey and 5 others like this.
  29. Got to do the same with the Saginaw now
    OD case on the right. Only difference is the reverse lock out hole
    Okie Pete, enloe, mad mikey and 4 others like this.
