Folks Of Interest The Glory that is the Hemi, picture thread
Discussion in 'The Hokey Ass Message Board' started by Flogknaw, Sep 11, 2018.
  1. Sky Six
    Sky Six
    from Arizona
  2. Jalopy Joker
    Jalopy Joker
  3. 65pacecar
    65pacecar
    from KY, AZ
  4. 65pacecar
    65pacecar
    from KY, AZ
    Deuces likes this.
  5. 65pacecar
    65pacecar
    from KY, AZ
  6. 65pacecar
    65pacecar
    from KY, AZ
  7. 65pacecar
    65pacecar
    from KY, AZ
  8. RodStRace
    RodStRace
  9. 65pacecar
    65pacecar
    from KY, AZ
  10. 65pacecar
    65pacecar
    from KY, AZ
  11. DDDenny
    Just to stir the pot a little!
    das858, enloe, Jalopy Joker and 2 others like this.
  12. Deuces
    Deuces
    Bird's eye view of a 426 HEMI without the intake manifold.... 20240315_083123.thumb.jpg.d0424768397f3509f6f5477b34f371d4.jpg 20240315_083128.thumb.jpg.aa8d857f8838673b1e9eaf394a9d443f.jpg
    das858, rod1, enloe and 6 others like this.
  13. 34Larry
    34Larry
    Mine is in this m*** of pic's somewhere and I miss working with it and giving it some love. Edit: Found it on page (2)
    So..................... I've been thinking about, (oh no, oh no):eek::eek::eek: increasing the compression ratio with new pistons. I have no idea what they are now as I didn't do the last rebuild, but I did have the cam reground last time around thatI had it apart, so all that would have to be rediscovered all over again. I do not want to pull the motor, clean the cylinders up as they were good at that point. I'd of course check the inserts and mains, and seals etc. go with new gaskets and all and pretty much just enjoy myself. I'd maybe go with a larger cam also from the same Delta guys here in Tacoma, something streetable to match what they would recommend with the compression ratio choice. I am aware of valve piston clearance ofCourse and wrist pin cautions Now it is your turn for advice to this 85 year old what to do and if it's a smart move. I'd be taking my time; I like building much better than driving and this would most likely be my last time inside this guy I'm thinking.:( Then also I have my back up man, Jim who helped me put this on the road back in '17 and has his own stable of Resto rides, (5), he rents out on the weekends through Hemmings.
    Deuces and slayer like this.
  14. slayer
    slayer
    This is just a heads up so you can plan accordingly if you should decide to go ahead with this project. If you need pistons that aren't off the shelf parts, you better plan ahead for the looooong lead time. I don't know if things have gotten better in the last year, but last year lead time was between 6 and 9 months.
  15. 34Larry
    34Larry
    Thanks for the heads up slayer. My partner in crime at our regular neighbor Saturday morning breakfast asked "Why would you do this to a perfectly tuned and running motor? I just said, "Cause I love It" He said " "Your nuts.:eek: This from a guy who has a full stable of rentable Resto rides.
    I'm going on line to check into this as I post this now.:)
    enloe and slayer like this.
  16. 65pacecar
    65pacecar
    from KY, AZ
  17. 65pacecar
    65pacecar
    from KY, AZ
    Happy 4/26 Day.
    das858, slayer, Deuces and 3 others like this.
  18. jnaki
    jnaki
    1959 Lions Dragstrip SOUND
    Versatility in all aspects of hot rods/drag racing/boat racing, etc is something to be in admiration. From Lincoln MEL motors to the twin Hemi motors is a comparison in styles. Not many made the transition from one to another...
    twin hemi motors on a hydro hull
    Hello,
    One hot summer, we had heard about the Championship Drag Boat Races to be held in the Marine Stadium in Belmont Shore area of Long Beach. We knew where this was due to it being in the hot rod cruising area during our teenage high school years. Although it was in another high school’s proximity, we still drove around when we frequented Belmont Shore.
    Then in college, the campus was within a mile or so of the stadium. Back then, the campus had views toward the ocean and the Alamitos Bay that the Marine Stadium connects for ocean access. So, with that in mind, the water’s edge was cooling and the place was packed with fumes in the air. It was like being in the Lion’s Dragstrip pits area with the multiple drag boats motors being fired up for tuning and getting prepped for a run down the normally smooth waters of the Marine Stadium.
    Jnaki
    Some of the top drag boat racers in the So Cal region and some from out of state were in the compe***ion runs. It was hot and crowded. But, the action in the pits area and in the water were outstanding and well worth the “hot” environment by the water’s edge.
    Note:
    Here is an unusual way to start your 671 supercharged Hemi motor while steering.
    https://www.youtube.com/watch?v=ogxLni4mLG4 Marine Stadium Belmont Shore, Long Beach
    Compare that to starting at the motor in various hot rod/drag race, tune up operations.
    das858, enloe and slayer like this.
  19. 65pacecar
    65pacecar
    from KY, AZ
  20. patsurf
    patsurf
    Deuces likes this.
  21. Sky Six
    Sky Six
    from Arizona
  22. Sky Six
    Sky Six
    from Arizona
  23. Sky Six
    Sky Six
    from Arizona
    Restored Frantic 4.
    das858, enloe, slayer and 6 others like this.
  24. HOTRODPOWELL
    HOTRODPOWELL
    Barn find
    Originally out of Cali. (Built by the late Walter Ott ) Mag 871 555 heads with awesome port work Aluminimum rods Donz 12 quart pan super cool piece
    osage orange, enloe, slayer and 2 others like this.
  25. j hansen
    j hansen
  26. j hansen
    j hansen
    Hmmm,never seen a "safety brake"like that!:D
    slayer and Sky Six like this.
  27. 65pacecar
    65pacecar
    from KY, AZ
  28. Sky Six
    Sky Six
    from Arizona
  29. Sky Six
    Sky Six
    from Arizona
