Hot Rods My first flathead
Discussion in 'The Hokey Ass Message Board' started by flying53gmc, Mar 11, 2024.
  1. flying53gmc
    flying53gmc
    from M-boro, TN
    Bought a 28/29 roadster last week. It needs some rough stuff massaged and replaced but it’s a good start. It does have a sweet running flathead in it. I was told 49-53? With a 3 speed ford box and a banjo rear end. The steering arms and tie rod need immediate attention also and I could use some guidance. What are these spindles and what arms do i need to get the tie rod above split bones? Thanks guys.
    big duece, Balljoint, Jeff34 and 4 others like this.
  2. Jalopy Joker
    Jalopy Joker
    lots of fun ahead
    continentaljohn likes this.
  3. Hillbilly Werewolf
    Hillbilly Werewolf
    Looks like a perfect roadster to me!!
    I dont know about the suspension stuff, but the V8 does look like a '49-53 unit.
  4. wheeltramp brian
    wheeltramp brian
    Looks like you've got the early 39 to 41 Ford spindles with After market bolt on steering arms. It looks like they have the medium drop to them. You could perhaps get arms with more drop or just get regular flat type arms and go above the wishbones, as it looks like you have room.
  5. X38
    X38
    Johnny Law etc. axle. I'd throw that in the danger Will Robinson dumpster asap. Which makes me think there may be more to study on this car in the way of not-so-good building practices. Including parts sources.
    Be careful.
    Balljoint and anothercarguy like this.
  6. alchemy
    alchemy
    Yes, get rid of that axle ASAP. Spindles are repro 37-41. Most vendors arms should bolt up. I highly recommend using real tie rod ends rather than heims.
  7. Hillbilly Werewolf
    Hillbilly Werewolf
    I noticed that the front tires are temporary spares, probably not what you want to keep on it once roadworthy.
  8. TCTND
    TCTND
    Agree 100% about that axle; cut it up so no one else gets killed behind it. If you put the tie rod above the bones you might have frame interference issues. Nice bit of raw material with lots of potential; keep at it.
  9. Hillbilly Werewolf
    Hillbilly Werewolf
    I was unfamiliar with "Johnny Law" axles, but found this: Screenshot_20240312_121459_Drive.jpg
  10. flying53gmc
    flying53gmc
    from M-boro, TN
    I was afraid that axle was junk. I have a couple of stock model a axles around here somewhere. May need to send one to Okie Joe to drop. Unless someone in
    Thanks for the info. Real tie rod ends and a new axle are in the plans.
    Hillbilly Werewolf likes this.
  11. flying53gmc
    flying53gmc
    from M-boro, TN
    Right you are. It will get 15" bias up front after I locate some wheels.
  12. flying53gmc
    flying53gmc
    from M-boro, TN
    I picked up both of these axles. The black one is an original dropped ford. The chrome axle is dropped more. I’m not sure of its lineage? Any preference to one more than the other?
  13. alchemy
    alchemy
    Looks like the black one is a dropped A or a 33-36. The chrome one looks like a dropped 37-40. The later one probably won’t work with the spring you have.
  14. flying53gmc
    flying53gmc
    from M-boro, TN
    The chrome one came with a brand new spring as well
