Technical The upholstery thread to end all threads
Discussion in 'The Hokey Ass Message Board' started by Roothawg, Jan 5, 2021.
  1. Sporty45
    Sporty45
    If it wasn't for the worn area in the drivers side and the musty/mildewy smell, I think I would just recover this bench seat in my 47 Olds! It is in pretty good shape otherwise. The springs (all coils) seem kind of weak too, but not sure if there is anything I can do about that. There aren't any broken ones, but I would prefer a firmer seat. Any ideas to firm it up? I can take more pictures if needed.
    osage orange likes this.
  2. safetythird
    safetythird
    I've replaced springs with high density foam and been happy with it.
    lemondana and Sporty45 like this.
  3. Sporty45
    Sporty45
    I really don't want to replace the springs, just would love to figure out how to firm it up some. Maybe replace all the original matting with a piece of medium firm 2" foam? High density is definitely a must!
  4. Doublepumper
    Doublepumper
    from WA-OR, USA
    Question.
    I inherited a Husqvarna Viking Designer 1. Briefly looking through the manual, I saw where it states it will sew leather, vinyl and denim. It has many, if not all the accessories, including the embroidery and quilting gizmos. Anybody familiar with these? Is it worthy...?
  5. safetythird
    safetythird
    I can't tell you that, but I can tell you it's worth about $400.
  6. Tightly roll sheets of foam and stick them inside the coil springs, then wrap the springs in burlap. Stiffens the springs, helps hold them in place and doesn't take much material to do the entire seat.
  7. Sporty45
    Sporty45
    That sounds like a great idea. The springs are already wrapped in burlap, so I will just need to stuff some foam into them. Can probably pick up some 1/2" foam fairly cheap to do it with, too! Thanks for the help :cool:
  8. Whoamel
    Whoamel
    from So Cal
    That is a really great tip. Thanks for sharing that.
  9. jakesbackyard
    jakesbackyard
    from ND
    Finished up that roadster seat a couple weeks ago and it’s in the car…
    jeepster, dana barlow, SDS and 16 others like this.
  10. Roothawg
    Roothawg
    Very Nice!
    jakesbackyard likes this.
  11. patsurf
    patsurf
    ok-now let's see the ranchero interior!--beauty there sir!
  12. jakesbackyard
    jakesbackyard
    from ND
    I probably posted way back, but here you go…
    You can find many detailed pics of it in the build thread below.
    Squablow, brEad, Super88 and 6 others like this.
  13. jakesbackyard
    jakesbackyard
    from ND
    Looking through some pics reminded me of these…
    Only a small portion of it is upholstery. I cut up 55 gallon soup barrels, painted, detailed and upholstered these last year. Working on a couple more right now. Just fun stuff to do in retirement. A guy has to have something to keep busy.
    rod1, brEad, uncleandy 65 and 9 others like this.
  14. G_Don
    G_Don
    I did the seat on my tub with a sheet of plywood, foam, vinyl, batting and a staple gun (cant afford nor have room for a sewing machine, so this will have to do for now.. I was hesitant to move the backrest on the tub so its only just foam with no plywood or anything else back there. But i fit well with no plywood so I think itll do. Atleast for now.
    I did have a question though. The snaps i purchased just keep breaaking because I rolled over the viinyl on the backrest and it gives it a nice(r) look than if I were to just cut it. Anyone have any recommendations for strong snaps? I got pliers on amazon that are kinda like vise grips and they work good but Im not happy with the qualiity of the snaps themselves.
  15. jakesbackyard
    jakesbackyard
    from ND
    Not sure if they’re sold on Amazon, but you can get the ****on top with a longer shank for greater thicknesses of material. I get them from an Uph supplier. Use the same tool.
    G_Don likes this.
  16. Sporty45
    Sporty45
    I have the front seat lower cover done. Just need the foam to show up before I can attach it. It took me about 3 days to get done, but I'm pretty happy with the results!
    Squablow, brEad, Whoamel and 4 others like this.
  17. Whoamel
    Whoamel
    from So Cal
    I just got my very first seat done, as well. There is a bit of wonky in it, but for first try, it came out a bit better than I thought it would..
    Everytime I try something like this, I learn a little bit more..
    Squablow, reagen, brEad and 8 others like this.
  18. Sporty45
    Sporty45
    Looks great to me! This is my first attempt at upholstery too, and I can see all my "wonky" spots too, but ya gotta look close :cool:
    brEad and Whoamel like this.
  19. willys36
    willys36
    Yours is an old post and I tried to start a thread covering center consoles that got erased but here is what I did before it gets erased! Wanted a center console for my '40 Plymouth. Made it of plywood then decided not to try to upholster it. I covered it in fibergl***, body finished the surface then painted it body color.
  20. topher5150
    topher5150
    I ended up going a different direction with an 08 Sebring. I took the HVAC knobs out and put the gauges in. I'm going to fill in the shift hole and put a kill switch and a trunk popper behind the little cubby door.
    brEad and willys36 like this.
  21. willys36
    willys36
    nice!
  22. Whoamel
    Whoamel
    from So Cal
    Absolutely love the barrel seats. Great idea and better execution. Bravo, sir!
  23. Sporty45
    Sporty45
    Got more work on my front seat done. I have the front section of the split seat backs done. Still need to do the backsides.
    A little before and after pic,
    And both sides done!
    brEad, snoc653, JD69 and 2 others like this.
  24. jakesbackyard
    jakesbackyard
    from ND
    A couple more barrel chairs added to the fleet…
    drdave, dana barlow, brEad and 3 others like this.
  25. Sporty45
    Sporty45
    Getting there. Still waiting on foam for seat bottom to come in before I can attach the upholstery to it. I'm pretty happy with it so far.
    drdave, 3quarter32, brEad and 4 others like this.
  26. jakesbackyard
    jakesbackyard
    from ND
    One more barrel chair to go with my Ranchero…
    brEad, drdave, GuyW and 6 others like this.
  27. SDS
    SDS
    On a 32 Ford Roadster door, there is a "bead" around the perimeter of the door on the inside (sides and bottom).
    I've seen examples of both online, but is the interior door panel suppose to sit inside that bead, or on top of it?
  28. nrgwizard
    nrgwizard
    from Minn. uSA
    The windlacing - what you call "bead" (I think it's about 5/8" dia +/-), goes inbetween the door panel & the upholstered panel. Seals the gap(s) twixt the door edges n body. Also hides the gaps when looking from the inside to outside.
    Marcus..
  29. Sporty45
    Sporty45
    Seats are done. I'm pretty satisfied with the way they turned out, not perfect by any means, but a tad better than what I started with! I have an issue with the drivers side seatback. It doesn't seem to fit into the back cover as well as the p***enger side does. I've tried several times to get it to fit better, but no dice. Not sure what is wrong. Take a look at the pics and you'll see what I'm talking about. Any ideas?
    brEad, SDS and Whoamel like this.
  30. alchemy
    alchemy
    Most have the panel sit inside the bead.
    SDS likes this.
