Projects All The Twos: 1962 Mercury, 352cui, 2bbl, Too Many Doors.
Discussion in 'The Hokey Ass Message Board' started by Oneball, Oct 28, 2023.
  1. Oneball
    Oneball
  2. patsurf
    patsurf
  3. Oneball
    Oneball
    I think the problem is those grooves are not only deep but have a very sharp point so can’t make a seal.
    I’ve dropped the heads back, the guy who did them isn’t in till Friday
  4. On a slightly positive take, at least it's only the head surface and not the block too.
  5. Oneball
    Oneball
    I guess so. I didn’t actually ask for the heads to be skimmed. They didn’t need it
  6. Well, that's not good then.
  7. Pontmerc
    Pontmerc
    from Finland
    Now it would be great time to resurface those exhaust manifolds and head exhaust surface and leave those prone to leak gaskets out.
    Would you like some more tea?
  8. Oneball
    Oneball
    They were done. That was the real reason I took the heads off. But when I took the valves out it needed guides so I asked for new guides and to skim the exhaust.
    The surface finish on the exhaust face is fine, so **** knows what they were doing with the head to block face. They’ve not actually agreed that anything is wrong yet though.
  9. Oneball
    Oneball
  10. Pontmerc
    Pontmerc
    from Finland
    If im not totally wrong informet, you need 60 or finer surface ra.
    Roughness average..
    With stamped steel gasket.
  11. Oneball
    Oneball
    It’s nowhere near what you need for any sort of gasket. In 30 years of building engines I’ve never seen a mating face like that. The valleys are thousandths deep. You can’t run your fingernail over it.
  12. bobss396
    bobss396
    That should be a lot smoother than that. Any head I have gotten back, I just run my biggest flat file over the surface and call it done. That is a speed and feed issue.
    Oneball likes this.
  13. Oneball
    Oneball
    Got the heads back from the shop and they’ve machined them again, much better.
    Heads back on and torqued
    I got some different exhaust gaskets from Remflex but they’re the wrong ones, so it will go back with the steel and graphite ones.
    bobss396 likes this.
  14. T. Turtle
    T. Turtle
    Well at least there was no arguing about it and you could get something done. My machinist is a 72 years old prima dona with more whims than Naomi Campbell. Good, but mad.
    Oneball likes this.
  15. Oneball
    Oneball
    Beer time, hope the China wall seal at the back is ok!
    Truckdoctor Andy and Aaron65 like this.
  16. Aaron65
    Aaron65
    from Michigan
    That's frustrating. We all hate doing a job twice.
    Oneball likes this.
  17. Oneball
    Oneball
    I’m not 100% happy with the wall gasket at the rear so hopefully not going to be 3 times!
  18. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Tim..I always use the Permatex material called the "Right Stuff" on the rear china wall... never using a Gasket.... I just let it seal up well for 24 hours.... I know this point is mute.. but Learned this the hard way as well.
    All looks awesome.
  19. bobss396
    bobss396
    The Right Stuff is the bomb. Word to the wiser than myself... mask off anything that will be visible after the fact. It is only slightly less offensive than POR15 in the wrong place... :eek:
    Oneball likes this.
  20. Oneball
    Oneball
    That’s how I’ve done it before, but went with sealant and a gasket this time. We’ll see.
  21. Oneball
    Oneball
    It lives!
    Will try and link a vid at some point.
    61Cruiser, bobss396, Aaron65 and 2 others like this.
  22. Oneball
    Oneball
  23. Jeff Norwell
    Jeff Norwell
    MODERATOR
  24. Oneball
    Oneball
    Drivers side exhaust manifold gasket lasted about 10 minutes o_O
    61Cruiser likes this.
  25. Oneball
    Oneball
  26. J. A. Miller
    J. A. Miller
    from Central NY
    Damn, one of those good news/bad news things. I am happy you got it running and bummed that you have repairs to make.
    Keep after it, you will be driving it soon!
    Oneball likes this.
  27. Oneball
    Oneball
    Thanks. Will do.
    Ordered some core plugs and got the PCV properly set up
    Brake booster doesn’t work, pedal is rock hard and there’s air escaping when you press the pedal but not when it’s at rest, which I think means the byp*** valve has failed. It’s also a bit Heath Robinson. Don’t think this is how it left FoMoCo but it is a Ford booster, will have to dig into the parts book.
  28. Oneball
    Oneball
    Drawn a blank on the booster. According to the parts book should be C2AZ-2005-F but can’t find one or a replacement.
    I know people keep telling me how amazing the Ford parts numbers are but they really are gash. Never had a problem with part numbers from VW Chevy BMW Mercedes Maserati Fiat Harley KTM Peugeot TVR Austin MG Jaguar etc but Ford you just can’t find them!! :mad:
  29. ClayMart
    ClayMart
    God, I love this kind of talk! But then my last name is Blackburn, so . . . :rolleyes:
    Didn't realize there was a British equivalent to Rube Goldberg. ;)
    Algoma56 and Oneball like this.
  30. Oneball
    Oneball
    Didn’t realise there was an American equivalent to Heath Robinson ;)
