Technical Holley 4150 Metering Gaskets
Discussion in 'Traditional Hot Rods' started by KKF6, Mar 15, 2024.
  1. KKF6
    KKF6
    I have a 4150 with dual metering bodies, but can't figure out which gaskets I need. Pictures or part numbers of the proper gaskets would be appreciated. 20240315_183518.jpg 20240315_182824.jpg The first picture is the primary and the second is the secondary.
    Deuces likes this.
  2. squirrel
    A governed carb off a 61 ford truck, eh?
    KKF6 and Truckdoctor Andy like this.
  3. squirrel
    I don't know what gasket set 4-26 is called now...
  4. squirrel
    KKF6 and Deuces like this.
  5. Balljoint
    Balljoint
    With that fuel transfer tube it looks like an 1850 Holley carb. Get the p/n on the carb and you should be able to call Speedway, Summit or Jegs and get some gaskets for it. O’Reiley Auto parts might even carry them.
    KKF6 likes this.
  6. squirrel
    List number is 2348. Good luck finding it listed at a parts store...my 50 year old Holley book says it's obsolete.
  7. Doublepumper
    Doublepumper
    from OR-WA, USA
  8. KKF6
    KKF6
    Haha, that's the exact year.
  9. KKF6
    KKF6
  10. KKF6
    KKF6
    Balljoint and Deuces like this.
  11. squirrel
    The carb has a Ford part number, which begins with C1T, which means 1961 truck. And the governor...
    Deuces likes this.
  12. KKF6
    KKF6
    I didn't know that, and none of the local parts stores or Ford forums could figure that out.
    Deuces likes this.
  13. squirrel
    Ford part numbers are easy. The first 4 digits tell you what vehicle the part was first used on. C means 1960s, 1 is the last digit of the year, T is truck, E is Engine.
    KKF6, Deuces, Balljoint and 1 other person like this.
