Technical power steering issues
Discussion in 'The Hokey Ass Message Board' started by FANTM58, Mar 15, 2024.
  1. FANTM58
    FANTM58
    OK guys, I just installed a Volvo 160 steering
    box in my 49 Shoebox. and the pump is from
    a 65 Fairlane. SBF powered.
    I just started it and the steering wheel is
    jerking back and forth violently? when idling.
    it seems to be timed with the idle.
    what’s going on ?
    3quarter32 likes this.
  2. Doublepumper
    Doublepumper
    from OR-WA, USA
    Hoses plumbed correctly?
    winduptoy and 3quarter32 like this.
  3. ROADSTER1927
    ROADSTER1927
    Hoses are backwards probably!
    winduptoy, footbrake and 3quarter32 like this.
  4. miker98038
    miker98038
    ^^^^^ backwards. At least when I did it.
    winduptoy and footbrake like this.
  5. FANTM58
    FANTM58
    OK I’ll check it out.
    I thought it only plumbed one way with the
    high pressure fitting size ..
  6. 325w
    325w
    Might be air. The time I crossed hoses it spun like crazy. Glad I didn’t have hands on wheel.
  7. FANTM58
    FANTM58
    OK here’s a thought , i’m not familiar with fords.
    would a 1965 Fairlane engine rotate the same direction as a 5.0 ?
    If so, would this possibly be the issue ?
    pump turning backwards ??
  8. doug3968
    doug3968
    Did that to a Corvette once, scary reachng in to shut key off behind wildly oscilating steering wheel.. In my case it was reversed hoses that caused the issue. Easy error to make with a slave cylinder power ***ist, which I guess your isn't.
  9. bobss396
    bobss396
    The pump may need a reducer to cut the pressure down, these are common items, easily found. Do some research first to see if others have run across the same issue with the swap. Do the hose thing first.
  10. RodStRace
    RodStRace
  11. FANTM58
    FANTM58
    OK i’m stumped ?
    there’s no air in that lines. and this Volvo
    box has 2different size banjo fittings on it.
    I’m ***uming the larger one is High pressure ?
    my set up had a pressure line made up
    that only fits to the larger banjo fitting on the
    box.
  12. FANTM58
    FANTM58
    here’s the pump side
  13. TCTND
    TCTND
    High pressure line is probably the smaller one. The low side needs to flow the same amount at a lower pressure hence the larger bore.
  14. wheeldog57
    wheeldog57
    Haha. . . . Power steering
    bobss396 likes this.
  15. RodStRace
    RodStRace
    https://streettechmag.com/2015/03/25/shoebox-ford-tech-installing-a-volvo-gearbox-in-a-49-51-ford/
    "the Series 160 unit is for you, which is basically the same box as the 140, but with an added power-***ist case bolted on the input shaft side."
    Okay, this is a power ***ist. I'd say the issue is the add-on box at the top. Either the valving is wacky or as others have said, the hoses need to be swapped.
    What happens is the valves sense a left turn and applies fluid (wrongly) to the right turn side, then abruptly senses a right turn and applies (wrongly) to left. Violent side to side steering action.
    More info
    https://www.borgeson.com/instructions/999062.pdf
  16. FANTM58
    FANTM58
    OK I’m getting somewhere. Farman offers an adapter kit to convert to AN fittings.
    they appears to both be the same. mine are different
    sizes, and the premade lines i have are made so that
    the high pressure connects to the larger port.
    witch seems to be backwards ? maybe my
    box has been modified ?
  17. brando1956
    brando1956
    Take your lines to a hydraulic repair shop. Equipment dealers or large parts stores usually have hydraulic hose and fittings and the crimping machine to make hoses. They will likely be able to make a hose. If your existing hoses are long enough, you might get away with cutting the fitting off and crimping on a new one. They might also have adapters that would work.
    Is your Volvo pump metric? If so, you need to make sure the threads match. Keep that in mind if you order the adapters you mentioned. There's enough foreign stuff around now so it's usually not hard to find metric fittings.
  18. Oneball
    Oneball
    As mentioned earlier the larger port is the return. It has to flow the same volume as the feed but at a lower pressure.
    Desoto291Hemi and bobss396 like this.
  19. ekimneirbo
    ekimneirbo
    Can they just switch the fittings on the steering box ends?
    I recently needed a custom hose for a late model pump, the small one.........to run to a hydroboost set-up. Bought a premade hose with fittings on both ends. Figured I'd then have the special long fitting for the pump and could cut the hose and make a new tube and fitting for the opposite end.
    Apparently the Weatherhead brand was the go-to for the proper crimp style fitting, and most companies that make hoses don't carry them anymore. I went to a place that does tool repairs and they told me they wouldn't do it because of liabilities and they didn't have the parts anyway. Sent me to the nearby Parker store. They didn't do that style of fitting, and they had also bought out the store that used to do Weatherhead and converted it to Parker. They sent me to another place that I never found. I then stopped at the NAPA store, and they still did Weatherhead.......BUT, they were out of the fitting needed and didn't know if/when they might get some. Sent me to another NAPA store that did a lot of hoses because they were in a farming area. Nope, no Weatherhead......BUT directed me to another small company that was only about a mile from my house. They couldn't help either.
    So I gave up on that idea and bought another ready made hose with longer metal ends and I was able to cut the metal tube (unlike before when I cut the rubber hose). The metal part had a straight section as it exited the hose. I cut the metal tube off and removed the fitting. Then I put the fitting I needed back on the metal tube and made a push connect type bead at the end.........then tube benders to reform the tube as needed. Worked out great.
    The premade hoses are available from Rock Auto or Amazon. On Amazon you can see the shape of the hose but length is a guess........but its a lot cheaper than getting a hose made from scratch.
  20. nobby
    nobby
    is it pumping foamed oil
  21. FANTM58
    FANTM58
    The problem was what most people were saying.
    the lines were backwards. I could not see this
    due to the fact that my lines were already made up
    to fit the box with the the different sized banjo
    fittings. I could not see past that not realizing
    that they were made incorrectly. i’ve Ordered
    the correct fittings 16 and 18 mm to 6an fittings
    and will be having a new 6an 90 installed on my
    pressure line and return.
    Thanks for all the input, much appreciated!!
  22. nobby
    nobby
    put a cooler in the return, as that box is rather close to the exhaust?
    FANTM58 and Desoto291Hemi like this.
  23. FANTM58
    FANTM58
    Alright guys I have it working great. I ordered
    some fittings for the box 14mm to 6an and 16mm to 6an. then had a new hose made for high pressure line. All Good!! Thanks for all the great input..
  24. RodStRace
    RodStRace
    Thanks for coming back and posting a resolution!
