Hot Rods Project X project
Discussion in 'The Hokey Ass Message Board' started by Utahvette, Feb 22, 2024.
  1. Utahvette
    Utahvette
    Just by chance, I was looking through a 1967 copy of "Honest Charley's " catalog last night and found just about everything aftermarket that was used on the "X" car at this point in time. If you multiply all those prices by 9 1/2 you get pretty close to current prices. That 3-barrel carb would be $952.35!!! People tend to look back with rose-colored gl***es thinking things were so much cheaper in the past but the reality is they still cost a lot even then. Nobody was giving anything away.
  2. Utahvette
    Utahvette
    Scored a correct heater control panel today. One small step closer. DSCN4242[1].JPG Screenshot 2024-03-13 201453.jpg
  3. Johnny Gee
    Johnny Gee
    from Downey, Ca
    I like the basic set up over the Deluxe.
    Sharpone likes this.
  4. Moriarity
    Moriarity
    SUPER MODERATOR
    I enlarged the pics for you, always hit "full image" when posting.... Love this project....
  5. Going on be fun watching you put it all together.
  6. Utahvette
    Utahvette
    I sold the aluminum door panel kit and a spare front apron for $310. Down to 18,690. Still have the race engine. Beginning to think it might be a tough sell. Part of the problem is we don't have a race track around here anymore ( they sold out to build warehouses) so whatcha gonna do with a 14 to 1 compression race engine. I just need to be patient. I'm close enough to the Vegas or Boise Idaho tracks that someone could make a day trip to pick it up if they bought it.
  7. nrgwizard
    nrgwizard
    from Minn. uSA
    E85 street mill... :D .
    Marcus...
  8. Or just drop the compression to 11:1, rebalance and run it on pump gas!
  9. Utahvette
    Utahvette
    Believe me, I've tried to justify using the engine, but the approximately 15 grand the things worth would finish the car with money left over.
    Sharpone, 427 sleeper and elgringo71 like this.
  10. Utahvette
    Utahvette
    I've just about got this dis***embled as far as it need s to go. At this point it's a matter of some body mount bolts and the brake lines to get the body off so I guess I'm gonna pull it off. It will sure make it easier to restore the rear suspension. The previous owner installed a nice ladder bar set up and moved the rear springs to under the frame. All that needs to be changed back to stock and it would be so much simpler with the body off. Cutting, grinding and welding while laying under a car is not as much fun as it sounds. DSCN4307[1].JPG DSCN4308[1].JPG DSCN4309[1].JPG DSCN4310[1].JPG
  11. chevy57dude
    chevy57dude
    You'll be in a really good position to install a spring pocket kit while the body is off.
  12. TFoch
    TFoch
    Awesome project! Looking forward to following along!
    Sharpone and Deuces like this.
  13. 55 gasser pickup
    55 gasser pickup
    from utah
    Been wondering about this thing.Thanks for the update Rex
    Outback, Sharpone and Deuces like this.
  14. Utahvette
    Utahvette
    Scored a polished Edelbrock C427X intake and coil bracket recently. Baby steps. Already have the Valve covers and one A.C. breather. Still looking for another breather and a Holley 3 Barrel carb. Good swap meet season is coming. 16.jpg DSCN4320[1].JPG
  15. Utahvette
    Utahvette
    Big Day! I pulled the body off. I'm a one man show so I had to improvise how to lift this thing without a 2 post lift or hoist of some sort, and with no help from anyone else. First I removed the doors and trunk lid to reduce weight. Then after removing all the body bolts(only broke two off), undoing the E- brake cable and the lines off the master cylinder, all that was left was the steering. The previous owner had adapted a rag joint to the box so it was simple to disconnect from there. With my plasma cutter I built an extension for my cherry picker out of one of the previously removed frame outriggers for the roolbar. Using a 4x4 fence post and experimenting with balance points, it turns out it is at the front of the back window opening. Making sure I positioned the cherry picker so it wouldn't be rolling over any cracks in the driveway, I placed the fence post through the car and centered the extension on the beam. It balanced perfectly and lifted right off. Pretty slick! I would estimate I only lifted it about a foot or so to clear the frame to remove the body sideways. I did have to take off the rear tires to gain additional clearance. Only took about 3 hours total. I know it's "hillbilly engineering" but necessity is the mother of invention and it did work after all. Now to chop out that nice ladder bar setup and put the springs back out board of the frame like original. DSCN4331[1].JPG DSCN4326[1].JPG DSCN4327[1].JPG DSCN4328[1].JPG DSCN4329[1].JPG DSCN4332[1].JPG DSCN4333[1].JPG DSCN4334[1].JPG
  16. 55 gasser pickup
    55 gasser pickup
    from utah
    You have been busy!. I however have been picking at that big block, i think next week i will be shoe horning it in my car. Call if ya need a hand.
    -Brent-, Outback, Sharpone and 4 others like this.
  17. phat rat
    phat rat
    Utahvette, I'm a one man operation myself and your hoisting is similar to what I do except I have adjustable metal clamps with eye bolts on my 4 x4 and use chain over the top. I built a new much longer arm for my cherry picker that has a upright of 15". The original arm is just under 3 ft long. The new on is 81" long with the upright back 45" from the front. Too be on the safe side I wrapped the end of the tube on the picker with some 1/4" strap to prevent any splitting. I also built a piece onto the bottom back to hold counter weight if needed. I can easily lift bodies and truck cabs off my trailer now
  18. Utahvette
    Utahvette
    Just sold the slicks to a "no prep" racer. He has a race this weekend and couldn't get new ones here in time. Down to $18,490
  19. Lone Star Mopar
    Lone Star Mopar
    Great project Man ! I appreciate you sharing it with us.
  20. Utahvette
    Utahvette
    Through the power of the H.A.M.B. I was offered a Holley 3 barrel for a good price. It was kinda crusty but had good bones, mostly. DSCN4378[1].JPG DSCN4381[1].JPG
  21. Utahvette
    Utahvette
    The good thing was it was complete. The bad was the base was cracked. This gave me a great opportunity to try my aluminum welding rod. After V-ing it out and filling it with rod, It really gives the impression it's gonna work. DSCN4383[1].JPG DSCN4384[1].JPG
  22. Utahvette
    Utahvette
    I did add a vacuum take off for the distributor that was nonexistent. It only had provisions for ported vacuum and that's not the best for the street. DSCN4385[1].JPG DSCN4386[1].JPG
  23. Utahvette
    Utahvette
    With the carb rebuilt and detailed, mocking up the top end of the engine gives a little encouragement. I even made up a matching fuel line with those stupid spring clamps and used the correct plugs in the manifold. Magazine pictures compared to what I have so far. I think it's going to be OK. carb.jpg 1`4.jpg
  24. Utahvette
    Utahvette
    I may be getting a little ahead of myself here but I have this beautiful fly-eye air cleaner that might get used. They were all the rage back then. There are no pictures of the car with an air cleaner so why not? DSCN4391[1].JPG
  25. Utahvette
    Utahvette
    Sold the MSD distributor for $325. Whittling the cost down now to $18,165. Picked up a manual tuning radio and a aftermarket coil that when painted black will look correct. Got a pretty good deal on a pair of lower fender patch panels at the swap meet today for $50. I was just going to cut and patch the fenders but for $50 I couldn't refuse. Got some leads on a seat and rear bumper that could work out. We'll see. DSCN4422[1].JPG DSCN4421[1].JPG DSCN4420[1].JPG
  26. chevy57dude
    chevy57dude
    Ever see an am radio where the numbers decend instead of ascend? Here's mine.
  27. Black Panther
    Black Panther
    from SoCal
    Neat project. That radio was an aftermarket deal intended for that car possibly, thats why it fits so well. Some cars back then came radio delete...so the aftermarket stepped in. Ive even seen those kind of radios for first gen Camaros and even cars into the early 70s. Generally they were Motorolas.
  28. NoSurf
    NoSurf
    Very cool.
    Sharpone and chevy57dude like this.
  29. Anderson
    Anderson
    The only thing better than this project is if someone restored the original. It's so far gone...
    This is very exciting.
