Projects The Flathead Flathead
Discussion in 'Traditional Hot Rods' started by Jeff34, Aug 30, 2021.
  1. burger
    burger
    I think you're fine with your rear suspension mount. Look at aftermarket frames and how they connect to ladder bars with small diameter round tubing. If you are worried about your design and want to sleep better you could stiffen it a **** ton as shown below with some plate.
    brEad and Desoto291Hemi like this.
  2. Jeff34
    Jeff34
    It's funny, after it was suggested to triangulate more, I went out and made a cardboard template and taped it in the area to the right that you drew. I may do that, but I want to think about other things like exhaust locations etc. before I block that area, or maybe I could incorporate my exhaust hanger into that gusset...hmmm
    AULIZ likes this.
  3. What you're really doing is strengthening the frame with those four "extra" pieces of square tubing. There is no real need to have those front/rear pieces (that come off of your new radius-rod mount.). The radius rods are primarily trying to apply force up or down (due to axle wind-up during acceleration or braking), not forwards or backwards. If you want, you can leave the two 90 degree front pieces, but even those two are not really needed.
    Also, I would typically make a 2 little 1/8" thick "boxing plates" to mount the cross-member to - such that you can tack everything in place, then remove the cross-member and do a full 360-degree weld where it meets the plates, then reinstall and weld the plates to the frame (top and bottom). I like to "step box" the plates in a bit - about 1/4 to 3/8" in on each side - so you have some good original frame material to weld too (and not on the corner).
    This also leaves a space behind the plate for fuel lines (if needed), wiring, etc..
    Outback, AULIZ and Jeff34 like this.
  4. Jeff34
    Jeff34
    Dropped the body back on the frame. Feeling good. IMG_3686.jpeg IMG_3687.jpeg IMG_3690.jpeg
    LCGarage, bymanr, glorydime and 4 others like this.
  5. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Now that's a hot rod! The stance looks great!
  6. Jeff34
    Jeff34
    Thanks, Joey. That means a lot coming from you. Looking forward to our roadsters side by side.
  7. Jeff34
    Jeff34
    Welded up the torque arms today. Made from leftover’40 Ford front wishbone legs. Added the bung and clevis to attach them to the rear radius rods. IMG_3698.jpeg IMG_3697.jpeg IMG_3696.jpeg
    next I’ll make a plate to attach these to the banjo
    LCGarage, brEad, Crusty Chevy and 2 others like this.
  8. Jeff34
    Jeff34
    Got my pedals figured out. Had the body on and off 3 times this weekend to be sure. Also pulled the engine back out and separated the transmission from the engine so I could get a look at the clutch. I’ll have to post the pics later. Too big. IMG_3744.jpeg IMG_3743.jpeg
  9. Jeff34
    Jeff34
  10. Jeff34
    Jeff34
    So, better pics from yesterday. Pulled everything from the ch***is. Separated the engine and transmission (easy). Also removed the clutch and pressure plate from the flywheel. Now I need to figure out if I have the pressure plate and clutch plate rebuilt or replace them, and WHO can do that work.
    Cheers!
    IMG_3736.jpg IMG_3737.jpg IMG_3741.jpg IMG_3742.jpg IMG_3745.jpg IMG_3746.jpg
  11. Jeff34
    Jeff34
    Got my steering box mount completed and tacked in place. Hope to get the pedal ***embly tacked in tomorrow. IMG_3749.jpg IMG_3750.jpg IMG_3751.jpg IMG_3752.jpg IMG_3753.jpg IMG_3754.jpg IMG_3755.jpg
  12. roseville carl
    roseville carl
    as always nice work Jeff
  13. Jeff34
    Jeff34
    Thanks, Carl!
  14. Jeff34
    Jeff34
    Slow progress on the torque arms. Got a spark in my eye last weekend that I had to have removed. Safety gl***es AND a full face shield didn’t work. Getting back on the horse today.
  15. 29Sleeper
    29Sleeper
    from SoCal
    When you go to DMV take along an old photo of an A converted to at PU with a wood box in place of the trunk lid. Explain it had been re converted back to a car when the family sold the farm.......
    Make sure a number on the frame or engine matches the ***le. If not get a bill of sale for the number that;s there and go for a whole new registration. CA will probably stick a state VIN on it but it doesn't matter much on old cars.
    Grumpy ole A and Outback like this.
  16. Looking good Jeff!! I love following your progress. Keep the updates coming!!
    Brian
    Jeff34 likes this.
  17. ZerroHalfcup
    ZerroHalfcup
    Slow progress is still progress. It's looking good, keep it up!
    JalopyJimbo likes this.
  18. Jeff34
    Jeff34
    IMG_3860.jpeg IMG_3859.jpeg IMG_3858.jpeg IMG_3857.jpeg IMG_3856.jpeg Picked up an old gas tank for the roadster yesterday. Not sure what it’s from. Vent, fill, and gauge on the top. Line on the bottom. Cap boss has three bumps on the OD no threads. Seller said it was model T but I’m not so sure. Any help would be appreciated. The gauge seems to move freely when I tilt the tank. It’s 30” long, 10” tall, and 16” wide…
    Any ideas?
  19. Jeff34
    Jeff34
    picture of the whole thing
  20. Jeff34
    Jeff34
    A bit more detail on the mystery tank. I was able to remove the gauge and also saw that there is a pickup tube going down to the bottom of the tank. IMG_3869.jpeg IMG_3868.jpeg IMG_3867.jpeg IMG_3866.jpeg IMG_3865.jpeg
    brEad likes this.
  21. ZerroHalfcup
    ZerroHalfcup
    Is it possible it's from some agriculture equipment? It's super cool either way, hopefully somebody recognizes it.
  22. Jeff34
    Jeff34
    Not a lot of progress lately as work has me all over the world these days. I did get more done on the torque arm, and cleaned up and painted the gas tank. Still don’t know what it’s from, but that’s irrelevant. Should get the steering box mount welded in today as well. I’m off for the next week so hoping to make some good progress. I’ll post pictures later when I’m on my laptop. Phone is *****ing at me
  23. Jeff34
    Jeff34
  24. AmishMike
    AmishMike
    What did u do to clean inside of gas tank?
  25. Jeff34
    Jeff34
    Simple Green and a bunch of nuts and bolts.
    glorydime likes this.
  26. AmishMike
    AmishMike
    Instead of nuts & bolts I use length chain & then smaller dog leash chain
    LCGarage and brEad like this.
  27. Jeff34
    Jeff34
    Great idea! I had some time getting the last of them out of the tank...chain would have been easier.
    Picked up a clutch equalization bar, anti-chatter rods, and a later model E-brake (under dash) ***embly at the swap meet today. Good times.
    J.Ukrop likes this.
  28. Jeff34
    Jeff34
    IMG_3919.jpeg IMG_3920.jpeg IMG_3921.jpeg Last Sunday, I bought a clutch equalizer rod at the Petaluma swap meet. Yesterday and today I modified another ball and mounted it to the frame. Looks like it will do the job.
    J.Ukrop likes this.
  29. Jeff34
    Jeff34
    IMG_3928.jpeg IMG_3926.jpeg IMG_3929.jpeg Also got my new tank float. Attached to the lever arm with a small lock washer. Seems really secure. And I cleaned up the gauge and painted the indicator red.
  30. Jeff34
    Jeff34
    While waiting for more parts, I fabbed up a couple of tank mounts. I’ll put some kind of webbing on them and straps with clamps across the top. Still need to finish welding them and give them a coat of paint IMG_3939.jpeg IMG_3940.jpeg
    glorydime, jaracer, Outback and 4 others like this.
