Hot Rods Want to Cap off a Speedo Connection
Discussion in 'The Hokey Ass Message Board' started by Deyomatic, Mar 18, 2024.
  1. Deyomatic
    Deyomatic
    from CT
    This is the threaded part of my speedometer on the back of the transmission...I am going to go with a GPS Speedo so I want to cap this off. It LOOKS like it's 18 threads per inch (if my math is correct) and I measured 0.823" in diameter in between the threads...
    I have no idea where to find a cap for this.... Is this a pipe thread? What am I looking for?
    Thanks.
  2. tb33anda3rd
    tb33anda3rd
    maybe cut an old speedo cable and weld it closed?
    vtx1800 and AVater like this.
  3. Bugguts
    Bugguts
    Mine has a rubber cap with a small hose clamp holding it on. Turbo 350.
    Worked well for the last 8 years now.
  4. Marty Vanin
    Marty Vanin
    Find a frost plug and put it in the hole in the trans.
    Bob Lowry likes this.
  5. oldiron 440
    oldiron 440
    Use a rubber freeze plug, on my 727 mopars I use br*** freeze plug.
  6. RodStRace
    RodStRace
    What they said, unless it's a chevy. Then just glob it with Orange RTV!:p
    Desoto291Hemi likes this.
  7. BamaMav
    BamaMav
    from Berry, AL
    Parts stores sell rubber “ crutch tips ” in the do it section. Get an ***ortment, slip it on, should fit snug, hose clamp to make sure it stays in place.
  8. Harv
    Harv
    from Sydney
  9. pprather
    pprather
  10. Deyomatic
    Deyomatic
    from CT
    I will take a photo of what the trans side looks like later and post. I think the guy that rebuilt it has it plugged.
    It’s an oddball- AMC (Ford) T-150 with a Lay**** de Normanville overdrive…
  11. Deyomatic
    Deyomatic
    from CT
    Thanks for the tips. My "crutch caps" will be here tomorrow and I plan to use those...but now that I have it back together and bolted up there isn't much room at all from where the ladder bars attach. I could weld it closed, I suppose.
    Should I remove the plastic speedo gear from inside? What about snipping this cable off completely?
