Projects Mid Life Crisis 62 Vette
Discussion in 'The Hokey Ass Message Board' started by squirrel, May 12, 2023.
  1. [ Maybe there's a good reason, which I'm too dumb to realize?[/QUOTE]
    Like a fox!!
    Ben
  2. sidevalve8ba
    sidevalve8ba
  3. 38Chevy454
    38Chevy454
    My 37 Chevy Ute still has the original 216 engine and related fuel system. It has a metal hard line from the mech fuel pump to the carb, about 30 inches worth. I was getting vapor locking. I split lengthwise some 3/8 rubber fuel line and wrapped the hard line from the pump to the carb. Secured with some zip ties along the path, it is obviously not stock, but looks fairly decent. It seems to have cured the vapor locking, at least the small amount I drive it since the fix has not had recurrence of the problem.
    But sounds like Jim added the phenolic spacer and that his problem is more heat soak related. But insulating the fuel line may also help.
    porkshop likes this.
  4. Utahvette
    Utahvette
  5. squirrel
    Deuces, 41 GMC K-18 and porkshop like this.
  6. Los_Control
    Los_Control
    from TX
    A really easy way to run a return line is to use the wix fuel filter.
    Simply has 2 outlets, one smaller then the other for the return line. Just run it back to the tank and patch it into the vent line or filler tube .... A filter and 6' of rubber fuel hose could be a quick get me by to get home and make it better.
  7. ***Area-51***
    ***Area-51***
    from Ohio
    ^^^^^^^^ interesting, never seen one before
    porkshop and Deuces like this.
  8. squirrel
    I'm not having vapor lock...
  9. patsurf
    patsurf
    the thread tangent that refuses to die!
    porkshop, bobss396 and squirrel like this.
  10. Los_Control
    Los_Control
    from TX
    Might be time to install a Dodge flathead 6 in it .... would have the fuel line running right over the top of the exhaust manifold and supply you with all the vapor lock you want .... might even improve your ET times ..... :rolleyes:
    porkshop and squirrel like this.
  11. MAD MIKE
    MAD MIKE
    from 94577
    Jim, did you install a lifter valley baffle?
    porkshop and 41 GMC K-18 like this.
  12. squirrel
  13. squirrel
    I guess all my fixes work, or it's just too cold. No fuel percolation issues now
    Tickety Boo, Deuces, drdave and 17 others like this.
  14. squirrel
    and when it warmed up, it started acting up. But then it cooled off again (weather), and now it's fine.
    I'll keep plugging away at it.
    Also got some inspiration today, and a new intake from scottyt....
    I'll scan the rest of the article too.
    Tow Truck Tom, brEad, WC145 and 15 others like this.
  15. RodStRace
    RodStRace
    Like the new avatar, but ya better watch out, lotsa PS hate here.
    Glad ya made it back home, quite the adventure!
    Shame the computer fan and duct didn't do it.
  16. squirrel
    oh, that's not PS...it's bad *** street machine. Notice the tires stick out like they're supposed to!
  17. RodStRace
    RodStRace
  18. squirrel
    yeah...
    On another subject, miles driven, almost 15k on the clock on the Corvette now. Less than a year.
    rod1, enloe, WC145 and 19 others like this.
  19. 28rpu
    28rpu
    It looks like the new avatar is an indication of the next version of this cool hot rod.
    427 sleeper likes this.
  20. squirrel
    heh...I doubt I'll make it that wild, but I'll sure think about what it would take to do it. The tricky part will be figuring out how to put enough radiator in the car. Surgery required, I think.
    and then find an Olds rearend
  21. snoc653
    snoc653
    from Iowa
    Yep looks like a street machine to me. Now if it gets a cage, then it's PS. ;)
  22. DDDenny
    Paris Fish Corvette
    Tickety Boo and squirrel like this.
  23. I see a cage in the black car?
    enloe likes this.
  24. Plenty early vettes with big power/engines so there’s a way to keep em cool. Maybe check with @jimdillon he’s got a bbc in one of his and he knows more than most about the early drag cars
  25. snoc653
    snoc653
    from Iowa
    I see a roll bar, definitely not a cage.
  26. Moriarity
    Moriarity
    SUPER MODERATOR
    Pro street is tubbed and narrowed rear end with wide tires that do not stick out......
  27. 57 Fargo
    57 Fargo
    As @flamedabone says, your a wuss if you don’t!
    427 sleeper, porkshop and squirrel like this.
  28. snoc653
    snoc653
    from Iowa
    So as long as we don't add tubbs we're still just street machines and blowers and jungle gyms are OK? I think the limit should be 6 points or less for the gym to stay out of the misconception of being a PS car. Should I say, I won't if you won't? But, I do hope to run into you on some of these fun adventures. That is what retirement and street machines are for.
    squirrel likes this.
  29. Moriarity
    Moriarity
    SUPER MODERATOR
    just look at the rules here, we focus on 65 and older build styles......
  30. My bad, i sit corrected
