Technical Tell me what is up with my frame?
Discussion in 'The Hokey Ass Message Board' started by 1942g506, Mar 21, 2024.
  1. 1942g506
    1942g506
    I’ve been working on my 41 sedan and noticed this repair to the front of the frame. Any guess as to what the patch was for? I doubt rust as the rest of the car was super solid. Possibly hit in this area? Does it kill the car in anyway? How would you proceed? Thanks
  2. choptop40
    choptop40
    I think I see a kink in the top of the frame,,,not the neatest welding job as long as it doesn't affect drivability....it could be cleaned up if you wanted redo it...
  3. 1942g506
    1942g506
    You do see a kink, think it was wrecked and a portion was cut out to straighten?
    tractorguy and '29 Gizmo like this.
  4. Doublepumper
    Doublepumper
    from WA-OR, USA
    1PATCH.jpg I'm bored :p
    Budget36 likes this.
  5. 19Fordy
    19Fordy
    What year, make and model is your 41 sedan?
    Looks like a oxy-acet. gas welding job done a long time ago.
    anthony myrick likes this.
  6. Looks like old school torch welding
    Probably repaired a very long time ago
    cool
    Just Gary, clem and firstinsteele like this.
  7. '29 Gizmo
    '29 Gizmo
    from UK
    As stated above, looks like it was bent and the section cut out to straighten it. There looks to be evidence of the kink still on the top if the frame.
    Probably done decades ago as part of a crash repair.
    Worth checking over all the surrounding components (suspension, steering etc) for signs of distortion.
    Automotive Stud likes this.
  8. Happydaze
    Happydaze
    The top hat section, bolts in the web and the independent suspension leads me to believe its a Chevy, but others are similar so can't say for certain.
    Chris
  9. Oneball
    Oneball
    That’s neater than Ford or Chevy factory welding!
    427 sleeper likes this.
  10. millersgarage
    millersgarage
    Unless you are going for The Ridler, leave it
  11. BJR
    BJR
    If it bothers you grind it down so it looks better and paint it flat black so it blends in.
    Just Gary likes this.
  12. CSPIDY
    CSPIDY
    Check the frame asymmetry (straight and square)
    If it’s good, go with it
    Okie Pete and lothiandon1940 like this.
  13. 1942g506
    1942g506
    Thanks all it’s a Chevy, just wanted to make sure it wasn’t anything detrimental. I guess it gives character.
    Okie Pete likes this.
  14. daliant
    daliant
    I'd be curious to see what's underneath that patch, but like the others said it's been like that for a long time. That ain't no mig weld, probably done with an oxy/acet torch and a coat hanger.
  15. TCTND
    TCTND
    I wouldn't grind it, it's an honest repair. As long as the car can be aligned and drives straight leave it alone.
  16. texasred
    texasred
    from Houston
    measure the frame to see if it's out of diamond, if not forget it
    tractorguy likes this.
  17. 1942g506
    1942g506
  18. BamaMav
    BamaMav
    from Berry, AL
    Grind it smooth, toss some filler on it, paint it flat black and it will fade away out of sight.
  19. lostone
    lostone
    from kansas
    I do this, (not this poor of work though), for a living. So from what I can see, it got hit, wrinkled, then pulled and kind of straightened. They seem to have a cut an access hole in order to go in and work the wrinkle out.
    And from the size I'd say they used a punch to do the straightening.
    It looks like they found a donor piece, covered the hole and welded on the filler piece.
    "IF" I was going to do it that way I would have made an actual flush fit patch and weld, ground, and metal finished it all.
    But personally I've done a bunch hit that way with wrinkles, I work 99% of the wrinkles out, then cut the corner open. I built a couple pry tools out of different width leaf springs that I slide thru the corner slot, pry and hammer dolly the rest of the wrinkle out from the inside. Once I'm happy I work the corner back down to shape, weld up the corner and and grind and dress the corner out. When I'm done the only way to tell I was even there is from the inside where you can see the corner weld...
    It's a dying art that no one wants to learn and all the experience I have and no one interested in learning so I can p*** it on...
    38Chevy454 likes this.
  20. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    cut out the old repair
    straighten what's left
    weld in new patch
    sleep well
  21. spanners
    spanners
    Nah, dial 1800newch***is and it'll be on your doorstep in the time it takes to get a grinder plugged in.:D
