Technical Engine Hoist of your dreams..............
Discussion in 'The Hokey Ass Message Board' started by ekimneirbo, Mar 22, 2024.
  1. ekimneirbo
    ekimneirbo
    x
    Driver50x, SS327, VANDENPLAS and 7 others like this.
  2. lostviking
    lostviking
    My only comment would be was that the smallest winch he could get. 3000Lbs would be a pretty heavy engine, and it's got some multipliers. I'd love to have it. Straight up and down lift rather than the angle you get with a standard cherry picker. Not to mention the fact that it can swivel the engine away from the car/truck. I'd like to build one.
  3. It’s quite extensive, however, with the size of the front tires, it would not fit under a Freightliner, much less a car. Ok, set the car on stands, but I still believe you would have trouble fitting it under a car.
    67drake, 1940Willys, X-cpe and 23 others like this.
  4. nrgwizard
    nrgwizard
    from Minn. uSA
    I'm seeing the same issue w/the big tires getting under anything. Also don't think swinging an engine sideways is going to result in any kind of useful stability. But on soft material, like the sand I have, I could make that work, w/some modification. Seems way too lightweight. Sure looks easier to move around than the one I built out of the racers' plans years ago...
    Marcus...
  5. RMR&C
    RMR&C
    from NW Montana
    Would be useless to me. I'd have to cut it up and rework it
    lostone, LOST ANGEL, Kiwi 4d and 3 others like this.
  6. Needs a banger. Hehe.
  7. mad mikey
    mad mikey
    Might work good for mower's, other then that , I think it's a piece of elaborate ****.
  8. Budget36
    Budget36
    I think it would be a useful shop crane/lift, but as mentioned it falls short on getting it under a vehicle.
    I can see coming in from the side of a PU, grabbing the load. All good.
  9. The 360 degree swivel feature is useless, it will tip over once it turns past a certain point, and that certain point is not very far away. Other's have already mentioned the issue with the tires. An 'A' frame hoist does the same thing.
  10. Jay McDonald
    Jay McDonald
    I would bet that was not built to be an engine hoist but some other specific lifting job, like the hydraulic jack is to break whatever free and the winch to raise it, just a guess.
  11. partsdawg
    partsdawg
    from Minnesota
    Check your local heavy electrical motors rebuilders/rewinders shop.
    They may have a older standby unit.
    That's where I got mine. Better built than the one shown and smaller tires.
    ekimneirbo likes this.
  12. gene-koning
    gene-koning
    Someone thought they had a great idea, built it, found out it doesn't really work as intended, and now wants to pawn it off on someone else, so they can get their money back out of it.
  13. y'sguy
    y'sguy
    from Tulsa, OK
    I like the idea of pulling it behind a vehicle with a hitch.
    As far as the big tires fitting under , yeah that wouldt work for me. I can only hope the come off easy and get replaced with some iron one for the job. At least thats what I would do.
    I have been looking lately on FB marketplace and these things, like everything else have gone way up in price it seems?
    ekimneirbo and 41 GMC K-18 like this.
  14. RodStRace
    RodStRace
    Diesel creek has the dream hoist, but hasn't installed it yet. He just pulled a ***mins with another piece of heavy equipment, but he's got a gantry crane to put in his shop.
  15. AccurateMike
    AccurateMike
    How about this one ?
    Mike
    CSPIDY, Cosmo49, Squablow and 6 others like this.
  16. 41 GMC K-18
    41 GMC K-18
    Paging Mr. Rube Goldberg!
    The ability for stability, has reached the crucial instability zero point !
    Your results, may not be covered by any insurance company !
  17. JD Miller
    JD Miller
    looks like one more overly complicated thing to waste time and money repairing when something breaks
  18. spanners
    spanners
    The other possibility is someone enjoyed creating it.
    alanp561, vtx1800, partsdawg and 5 others like this.
  19. Ziggster
    Ziggster
    Interesting to say the least. If my old engineer brain is working, with the pulley arrangement it would have a capacity to lift 12,000 lb. Yes?
  20. evintho
    evintho
    Not sure about the stability but much, much better!
    ekimneirbo and clem like this.
  21. carolina chevrolet
    carolina chevrolet
    I have a somewhat similar looking contraption for pulling well pumps.
  22. Rickybop
    Rickybop
    Oh good...
    Cuz the ones we've used for the last few decades don't work very good.
    Driver50x and Tow Truck Tom like this.
  23. A 2 B
    A 2 B
    from SW Ontario
    Hey, is that a cup holder on the left side?
  24. tb33anda3rd
    tb33anda3rd
    those cranes are cool.
    this crane solves the "low" issue and doubles as a way to move skids. IMG_1420.JPG IMG_1421.JPG
    Never2low, porkshop, X-cpe and 28 others like this.
  25. silent rick
    silent rick
    3000 lb capacity is reached with one wrap on the drum, with each additional wrap, capacity is reduced, not that the rest of the build looks like it will support a ton and a half. also, most winches of this kind do not have a brake, that is to say when using it to lower the object, it might free spool and hit the ground hard.
  26. 32percenter
    32percenter
    I still use a tree branch
    Driver50x, X-cpe, clem and 7 others like this.
  27. Johnny Gee
    Johnny Gee
    from Downey, Ca
  28. Jalopy Joker
    Jalopy Joker
    reminds me of a TV show with Tim Allen and Richard Karn, of "Tool Time" fame, that had contestants create something mechanical according general parameters of show. Some extreme, some way off base. everyone sees different approaches to a challenge
  29. tubman
    tubman
    Too big and unwieldy. P***.
  30. Fortunateson
    Fortunateson
    pineknot4, tb33anda3rd and ekimneirbo like this.
