whats the perfect rake for 32
Discussion in 'The Hokey Ass Message Board' started by elroy, Aug 31, 2012.
  1. Jeem
    Jeem
    Alliance Vendor
    Say no to protractors.
    Protractors are great for finding angles. Matching angles. Setting up components.
    Great rake is the happy by product of the "eye".
  2. deucetruck
    deucetruck
    from Missouri
    Man, I love your tub !!! Killer!
  3. Jimmy2car
    Jimmy2car
    from No. Cal
    Here is mine. Maybe not perfect for all, but perfect for me
    3 1/2" dropped axle, 26" front tire, 30" rear
    LTM75110 likes this.
  4. Its a catch because you need to set a bunch or **** up before you can get the eye happy.
    Think about all the other stuff that needs to be happy.
    All that stuff needs to work with the rake
  5. Jeem
    Jeem
    Alliance Vendor
    You're right, of course. My point is just, final rake is something that you set up by eye and then build the suspension accordingly. Mock it up at it's ideal, and then have at it with protractors and other measuring devices to make that happen.
  6. CheatersPete
    CheatersPete
    From my point of view
  7. 327-365hp
    327-365hp
    from Mass
  8. Ned Ludd
    Ned Ludd
    Here is my formula, derived from looking the "eye" in the eye and working back from there:
    Measuring perpendicularly up from the flat, middle bit of the bottom of the frame rail, the tops of all the tyres should be around the mean of the front tyre height and the rim diameter.
    The greater the big-to-little ratio, the steeper the rake. Equal tyre diameters mean a level stance.
    This isn't the only way for a car to sit, but it will give you that look.
  9. Exactly.
    The mock-up stage is the most fun part of the build. Your brain and your creativity are running at maximum RPM. Once you get it "right", then you have to open up the wallet, and the fun meter drops back a few notches.
    X-cpe likes this.
  10. Abomb
    Abomb
    For a Coupe, It'll fit.
    Since you're building a truck, you can probably get by with this one though...
  11. ratrod0
    ratrod0
    Hotrod rake
    wicarnut likes this.
  12. NealinCA
    NealinCA
    Here's my two attempts.
    32 with fenders...
    32 without fenders...
    Neal
    LTM75110, wicarnut and 5w32 like this.
  13. 5w32
    5w32
    5" magnum axle , mono leaf spring
  14. Tattoozzz
    Tattoozzz
    My 32. 18" wires front/rear. Rear tire is 33" tall. Front tire is 28" tall.
  16. PONTNAK123
    PONTNAK123
  17. John Stimac
    John Stimac
    Had lots of 32's, but thought this one was just right. Tire size plus the setup was perfect IMG_7387.jpg
    38 Hump, PONTNAK123, wicarnut and 3 others like this.
  18. wicarnut
    wicarnut
    tinmachine, ekimneirbo and PONTNAK123 like this.
  19. Corn Fed
    Corn Fed
    Here's my '32. Go the other direction.
  20. dirt car
    dirt car
    from nebraska
    The forward rake is right at home on 32's be it a high-boy or full fender version, never could get overly enthused of the use of the narrow axle on a full fender car, something needed when going to extremes, just me I suppose...
  21. Brad Ley
    Brad Ley
    About this much looks right to me.
  22. JimSibley
    JimSibley
    In my opinion, each car needs its own rake. It is all in the eye! My cars all hve a rake that I like, but none are the same. IMG_1362.jpeg IMG_0553.jpeg IMG_2271.jpeg
    427 sleeper, clem, PONTNAK123 and 2 others like this.
  23. 56don
    56don
    Better wear a seat belt or you could fall through the windshield on that one !
  24. noboD
    noboD
    Jim, Sibley, that orange car looks like a Hot wheels car. Killer!!
    56don and JimSibley like this.
  25. xix32
    xix32
    The Karl Orr car
  26. Frames
    Frames
    img218.jpg Adjustable front spring perch. Coil-over rear. Set the rake you want. Even raise or lower it for car shows or cross country. Never mind the axle drop or the tire size. I like 4 degree.
  27. pineknot4
    pineknot4
  28. DDDenny
    Odd looking 32!
  29. 32s just scream skirts and tail dragger stance
    Moriarity likes this.
