Technical Hard chop: sitting on the chopping block
Discussion in 'Traditional Hot Rods' started by 65standard, Feb 21, 2024.
  1. 65standard
    65standard
    I marked the floor just in case I have to move the car for some reason. I can put it back exactly where it was so it stays level.
    Yes. Many ways to chop a 3w. This one will be a rolling bones style chop. Angled chop with rear window leaned forward 3/4” and whole windshield laid back so I don’t add length to the roof.
    Dick Stevens, clem, Fordors and 2 others like this.
  2. 65standard
    65standard
    C24361FB-EB2A-4B0A-A047-07923CB66AA4.jpeg 65BB5C2A-882C-4817-B4D8-CECCD9770275.jpeg 2D0D76FF-D293-40D4-918A-A6EEE6C839C0.jpeg 4EC61E3A-46D5-4A53-8967-78D53B53E9B2.jpeg Zero pie cuts. Just good old hammer and dolly work to blend the B-pillar. Maybe 15 minutes to move and align the body lines.
    GTHOtrod, GordonC, lucky ink and 17 others like this.
  3. 65standard
    65standard
    C5FE91A0-3790-4763-A851-F69F7AC1C2EB.jpeg 61CCCC99-5925-4AD9-AA98-83E122FD7A57.jpeg How I blended the B-pillars. Start by aligning the door opening edge.
  4. 65standard
    65standard
    Then hammer and dolly to blend them together. Then weld up that seam. 9C3FF73E-4987-4F1F-848B-22DF4F0F4581.jpeg A3ED76A6-CEE1-4BAA-A256-6E99E85E89CF.jpeg 5920D1B6-0BFD-4427-ACD2-A4B122C5BAF2.jpeg 367EA6AD-5C91-45D5-9CEB-14D72B5CC086.jpeg
  5. 65standard
    65standard
    D84B51B6-22F8-44D3-B6DC-89D0C203DBF0.jpeg Or the alternative method I’ve seen done by others. Not sure if one technique is better than the other, but I saved a lot of welding and grinding to blend the B-pillar in.
    Dick Stevens, lucky ink, Tim and 7 others like this.
  6. j hansen
    j hansen
  7. hotcoupe
    hotcoupe
    Looks good, thanx for showing your execution.
    Tom
    65standard and 31chevymike like this.
  8. Happydaze
    Happydaze
    Your b pillar method works for me thus far.
    Chris
  9. Voh
    Voh
    I know there has to be a reason, but why paint the frame post at the floor yellow?
    31chevymike likes this.
  10. Jacksmith
    Jacksmith
    from Aridzona
    Like he said above...
  11. snoc653
    snoc653
    from Iowa
    The craftsmanship in this project is outstanding. And while I recall how chops were done, it is a definite learning opportunity watching this work in progress. Thank you!
  12. The37Kid
    The37Kid
    Very nice, like the turnbuckles on the bracing. Looking forward to seeing the rear corners cut to fit. No cut between door hinges should allow the door fit to be fine.
  13. 65standard
    65standard
    F03D9AE0-E45E-408F-94BF-5B105DCAA79D.jpeg ABDD2503-C978-411E-9A05-622389DB0313.jpeg T******* the windshield surround.
  14. Love the steady progress!
  15. 65standard
    65standard
    44A4F3B6-414F-45E4-911B-DA87B3295981.jpeg Fitting the windshield surround to the body.
  16. 65standard
    65standard
    EC6D08BD-3CBE-4C13-A32A-26C23E933338.jpeg 50E23C46-9406-4057-B066-FC9D2955602B.jpeg Laid back an additional 11 degrees. No pie cut and filler piece. Overlap and trim to fit instead.
  17. 65standard
    65standard
    857BAF7A-5003-41D7-92E4-66CDC68AF4F1.jpeg Still need to reshape the forehead. It’s off because I laid it down 11 degrees.
  18. 65standard
    65standard
    6533FD91-22B7-4DAD-91B7-8094B6675B33.jpeg And then trim the bottom of the A-pillar structure 5/16” to zero. This will eliminate the pie shaped gap and lower the windshield closer to the cowl top. I will still have a 5/8 gap all the way across that will need work.
    Dick Stevens, lucky ink, hfh and 7 others like this.
  19. 65standard
    65standard
  20. Roothawg
    Roothawg
    Neat concept. I like the idea of having a hard surface, for the windshield reference.
  21. Great step-by-step photos so far. Thank you for taking the time to do the photos as you go. Keep the updates coming. Looks awesome.
  22. scoob_daddy
    scoob_daddy
    from Georgia
    *****'n 3w!
  23. I've never seen a rake chop in progress with such detailed photos to show the painstaking work that is involved... Masterful techniques that even most of us have never witnessed here on the HAMB before. Great work Tony!
    What I'm not understanding is where the front of this frame is heading... Subscribed!
  24. 65standard
    65standard
    The front of the frame rails are done. It’s been bobbed and pinched.
    Still tweaking the A-pillars to flow as smoothly as I can make them. I want to keep the stock length along the door tops.
    Any pie cut here will open that distance and then the door tops will need to be lengthened. 6DD3F43D-E97B-438C-8D09-25588FB04CEB.jpeg
  25. 65standard
    65standard
    D5C850AD-7129-4040-8194-7B0926BA42DE.jpeg I’m trying to make my chop as smart as I can to avoid extra work like this.
  26. Man, do I understand that. Homework really pays off.
  27. 65standard
    65standard
    D6E93C0A-42D7-4B5B-AC6B-37A4E23870D4.jpeg E5C04315-6CDA-4BB1-9D23-186D8CEDDF00.jpeg
    The corners will be easy. Just scribe and trim to fit. Here’s a rough idea of where I’m going with the corners
  28. Happydaze
    Happydaze
    You're making this look easy! Ha ha!
    Chris
  29. Yes it does but only if you've never done it before.
  30. The37Kid
    The37Kid
    That shot makes me rethink how I'll cut my Steelback, thanks! Bob
