Technical What are you working on?
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 18, 2022.
  1. 29A-V8
    29A-V8
    from wyoming
    that looks like my bench, full of junk and no room to work on anything.
    mad mikey and anthony myrick like this.
  2. 29A-V8
    29A-V8
    from wyoming
    I think the same thing is happening to me
    seb fontana likes this.
  3. The aftermath
    mnjeff, enloe, saltflats and 7 others like this.
  4. swade41
    swade41
    from Buffalo,NY
    Ha ha ha
    enloe, mad mikey and Johnny Gee like this.
  5. choptop40
    choptop40
    Played with a 50 Desoto grille installed in the 1949 Dodge , was surprised it fit recessed into the opening like a glove....Pics coming...
  6. sidewayzz69
    sidewayzz69
  7. 1pickup
    1pickup
    Started to convert a 1bbl oil bath air cleaner to fit on a 2Jet. PXL_20240324_204438075.jpg
    enloe, saltflats, 29A-V8 and 9 others like this.
  8. squirrel
    I've been working on the hard part...ordering parts to hop up the Corvette. Heads, cam, clutch, etc.
  9. 427 sleeper
    427 sleeper
    What are you thinking of running for heads @squirrel?
  10. squirrel
    Trick flow aluminum. The small ones.
  11. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Is what I read correct!? $1100 more for the bigger heads? As in each!
  12. Dan Hay
    Dan Hay
    Trying to make sure the wheel is centered before locking down the crossmember IMG_7056.jpeg
  13. 427 sleeper
    427 sleeper
    Presumably the Double Hump's w/o the bolt hole's, or am I way off base?
    scotty t likes this.
  14. squirrel
    that's what I meant to get, but I ordered the wrong ones! doh. so sending back for the right ones.
    Ordering parts is difficult
  15. 427 sleeper
    427 sleeper
    Technology... Pfffffttt!!! Easier my ***... LOL!!!
    scotty t and loudbang like this.
  16. Johnny Gee
    Johnny Gee
    from Downey, Ca
  17. 0NE BAD 51 MERC
    0NE BAD 51 MERC
    My buddy Gary told me you sold the Chevy 2 last week, having need to go faster withdrawals already ??
    saltflats, Tickety Boo and squirrel like this.
  18. squirrel
    Well, that and a lot of money in the bank this week
  19. DDDenny
    Johnny Gee likes this.
  20. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Yes sir. Yourself and @lumpy 63 had me set up with brackets. Gave a chrome one away to a friend and now the last one is going in the 57.
    loudbang and 427 sleeper like this.
  21. pila38
    pila38
  22. swade41
    swade41
    from Buffalo,NY
    I put 2 hrs in on that M/T valve cover I avoided the other day, still a few belt sander marks in there but I've got the majority worked out.
    That was 360 degrees of belt sander, all the way around the damn thing !
  23. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Alternator conversion done. Had to weld lower pivot brackets forward hole up since the bolt centerline did not match up then drilled a new hole. Also made a new adjuster bracket. Looks ok (made it to resemble the original one). Think I’ll rework it if the hard angle bugs me enough. IMG_2605.jpeg IMG_2606.jpeg IMG_2607.jpeg IMG_2609.jpeg IMG_2610.jpeg IMG_2612.jpeg IMG_2616.jpeg IMG_2617.jpeg
  24. Frames
    Frames
    Picked up the small pieces from a production chrome shop. Only nickel and chrome. No copper. Look great great. I prepped. Some bead blasted, Some 400 girt finished and some polished. $225.00. 2024-03-29 13.10.26-1.jpg 2024-03-29 13.10.26-2.jpg The hairpins, ladder bars and 38 tube axle are at a custom chrome shop.
    enloe, 61Cruiser, Tickety Boo and 5 others like this.
  25. saltflats
    saltflats
    from Missouri
    Why no copper?
    enloe and mad mikey like this.
  26. choptop40
    choptop40
    1950 Desoto came with 2 grille sets.. got curious and recessed one into the 1949 Dodge opening..Fit perfectly.. Bottom mounting holes are a snap. Uppers just require some mounting tabs.. I like the way it looks 50CE0749-85CF-48B3-9500-55B2DC562390.jpeg 03BA73E4-42F5-4244-892D-C71F56FC72F7.jpeg
  27. Black_Sheep
    Black_Sheep
    I finished reworking the alternator mounting, belt alignment is much better…
    rod1, scotty t, Tickety Boo and 5 others like this.
  28. nochop
    nochop
    from norcal
    Playing with this heater while my car is in the paint shop. The t-stat controller works with the computer fan….yay, IMG_6616.jpeg IMG_6617.jpeg IMG_6899.jpeg IMG_6900.jpeg IMG_6901.jpeg IMG_6645.jpeg IMG_6646.jpeg
    rod1, ERguitar, osage orange and 11 others like this.
  29. choptop40
    choptop40
    Different angle… 1950 Desoto grille recessed into the 1949 Dodge grille opening....... 55E9DD72-EC26-431B-8838-02DA2DB5F019.jpeg
  30. 67drake
    67drake
    from Muscoda WI
    IMG_1132.jpeg IMG_1128.jpeg IMG_1124.jpeg Still waiting to get my distributor back for my ‘62 Mercury. Rebuilder said the cam lobes were really worn bad and he’s fresh out of parts distributors for that. So I wait.
    Spent the day clear coating some metal vacuum lines after cleaning. Finished rebuilding the carb, and wet tested it. Bent a new fuel line from pump to inline filter, as the old one was just rubber. Then took the 2 speed outside and pressure washed it after blocking off anywhere water could get in. It was NASTY gunky,turned out OK, but looks rough in the picture as it had been painted black years ago.
    saltflats and osage orange like this.
