Projects 31 Plymouth Business Coupe
Discussion in 'Traditional Hot Rods' started by 340 Power, Nov 13, 2014.
  1. 340 Power
    340 Power
    from NW PA
  2. 340 Power
    340 Power
    from NW PA
    Just finished pressure washing after pulling the body. There are some changes coming to this build.
  3. What are your thoughts about some changes?
  4. 340 Power
    340 Power
    from NW PA
    After almost 10 years from starting this project, my goal is to finally finish it this year. Got the upper rear shock mounts installed and added a 19 gallon fuel cell instead of using the original tank.
  5. RMR&C
    RMR&C
    from NW Montana
    Great to see you still working on it!
    340 Power and 31chevymike like this.
  6. 340 Power
    340 Power
    from NW PA
    It's been a long time coming.
    oliver westlund and 31chevymike like this.
  7. It's GREAT to hear from you - figured you possibly sold your Plymouth and very happy that you stuck to your guns and committed to getting her DONE!!! Some pics I enclosed on my build - hopefully to keep you motivated as well as myself!
    Body off with mock up hemi removed to finish new brake lines.jpg Detail view of MC with new brake lines, proportioning valve, residual valves, etc..jpg Front end view with complete disc brake system from So-Cal, new brake lines and front hoses.jpg Full frame shot with body off, showing detail of frame strengthening.jpg Passenger view of Complete brake assembly.jpg Rear view of detail of new brake lines  with x-member.jpg Winter's Quick Change view of new brake lines.jpg
    bostonhemi, 340 Power and rusty1 like this.
  8. 340 Power
    340 Power
    from NW PA
    I removed the trunk floor today due to the shock mounts being in the way. The floor originally stepped down over 1 1/2 inches so it has to go. Set the grill shell height. The 32 grill didn't fit quite right and some modifications were needed. At the end of the day I fit the first sill plate on the car. An older gentleman on here sent me some aluminum pieces that are close to the original design. I'll complete the other side and bolt them on tomorrow.
    burl, oliver westlund and 31chevymike like this.
  9. Progress feels GREAT, doesn't it?
    340 Power likes this.
  10. 340 Power
    340 Power
    from NW PA
    New trunk floor is in. I completed the grill shell and set the headlight stands today. I also managed to con my oldest son into getting my dash ready for gages. He's almost finished.
  11. RMR&C
    RMR&C
    from NW Montana
    Looking good!
    I would love to find a PA or even a PB grille/shell for mine and ditch the Ford one
    31chevymike and oliver westlund like this.
  12. oliver westlund
    oliver westlund
    Heck yeah! Makes me feel really good seeing you flying on this thing! Enjoying the updates!
  13. Just my opinion and 2 cents, but I believe that you should consider dressing up your hemi with more "period" hot rod equipment, Moon or Edelbrock finned valve/timing covers in either chrome or polished aluminum, etc. Hot Rod carburetion like Strombergs/Holley 94's or 97's with frogmouth chrome/or aluminum Edmunds air cleaners in multi-carb setups like dual quads, tri-power, Man-A-Fre 4 deuces, 6-twos with progressive linkage, etc. Your motivation is showing strong - keep up with your progress!
    oliver westlund likes this.
  14. Hemi Joel
    Hemi Joel
    from Minnesota
    Wow, your coupe and mine are almost twins! This is the first I've seen this thread, it looks like you're making really good progress now. Good luck with it. Here's a picture of mine so you can see how similar they are. I think the only thing I noticed different is the grill shell.
  15. Yeah Joel, that's what I'm talking about! Speaking of grill shell, which one do you have, pic is a bit dark to see well... Re-take these pics with better focus and detail and post them on here ASAP!
  16. Hemi Joel
    Hemi Joel
    from Minnesota
    OK, I'll post some pics and give some detail. When I was mocking it up, the radiator had to be too far forward to fit the Hemi. I didn't like the proportions. So I put the radiator where it looked best, then recessed the firewall to move the engine back. Then ditched the belt drive water pump and fan. I used a Mezzeire electric pump mounted on the bottom tank of the radiator, it is hardly noticeable. Then I used an electric fan off a chevy HHR with all the factory shroud ripped off because the blades look more like a vintage fan than the slender, curved blades of the aftermarket fans. I'm very happy with the result.
    Kreepea_1, burl, 31chevymike and 2 others like this.
  17. Hemi Joel
    Hemi Joel
    from Minnesota
    THis pic shows the fan and water pump, and how close the radiator is to the engine. HEMI.jpg
    burl, Kreepea_1, 31chevymike and 2 others like this.
  18. Hemi Joel
    Hemi Joel
    from Minnesota
    I used a dual gas tank set up in the trunk. a 17 gallon for pump gas and a 3 gallon for race gas.
    31chevymike and 340 Power like this.
  19. Hemi Joel
    Hemi Joel
    from Minnesota
    Since this car gets raced as well as street driven, my objective were NHRA legal, light weight, simple, reliable and safe, with aesthetics and tradition a strong consideration as well. The ****pit is very spartan. I used a Wilwood triple master cylinder set up. 2 for brakes and 1 for the clutch. A steering column tilter from a 4x4 shop, a simple aluminum tube for a column, and a 48 Plymouth steering wheel.
    Here is a shot of the grill shell before a welded in the expanded metal grill and before the radiator was painted.
    I went with an aluminum radiator to save weight. I have a new copper/br*** radiator that came with the car that I can part with if you need one.
    If you want any more details, let me know.
    burl, 31chevymike, 340 Power and 2 others like this.
  20. 340 Power
    340 Power
    from NW PA
    I have a complete extra shell and grill for a 32 pb.
  21. 340 Power
    340 Power
    from NW PA
    I'm actually considering an electric fan.
    31chevymike likes this.
  22. 340 Power
    340 Power
    from NW PA
    Didn't take any photos today but front shock mounts are in and shocks on them. Primed and seam sealed the trunk and front floor pan. I also worked on the plywood that will go behind the bucket seats. So in closing I'll post my 32pb grill collection not including the one in the car. Work continues... 20240331_170427.jpg
    31chevymike, Hemi Joel and RMR&C like this.
  23. 340 Power
    340 Power
    from NW PA
    Painted the remaining 2 floor panels today. Then I mocked up the windshield frame for latching hardware from a model A Ford since I had no original parts. I'll swap out the bolts with carriage bolts and make a couple shims for behind the thumb screws when it's ready to go in for the last time. 20240406_131138.jpg 20240406_131153.jpg 20240406_154719.jpg 20240406_154635.jpg
  24. 340 Power
    340 Power
    from NW PA
    Today's progress was the battery box. With it complete I can drill the floor for fuel lines, and battery cables. 20240407_173128.jpg 20240407_173119.jpg
    31chevymike and roadwarrior84 like this.
  25. 340 Power
    340 Power
    from NW PA
    Working towards finishing the inside. I had to shorten the storage behind the seat because of the fuel cell. It's pretty shallow ( about 3 inches deep) but I didn't want to just lose it. It will still be big enough for the cell phone, and a firearm. Most of my gages arrived today so I had to shove them in there to get a better look at where all my money is going!!! The smaller gages are 2 5/8". You can't buy a compete set and the cost of all 6 is pretty disheartening but they look nice. 20240408_153154.jpg 20240408_150705.jpg
    roadwarrior84, RMR&C and 31chevymike like this.
  26. 340 Power
    340 Power
    from NW PA
    Finished the bucket seat mounts today. All I have left inside is building the steering column mount. After that the body can come off one last time before painting. Due to the fact this car has sat for basically 6 years incomplete, I'm going to scuff and repaint the frame as well as the engine getting a do over. I want everything looking fresh when it's finished. 20240410_162115.jpg 20240410_162145.jpg
    RMR&C likes this.
  27. 340 Power
    340 Power
    from NW PA
    I made sure when building the mount for the grill shell that it was semi adjustable so in the event I could possibly find a decent hood it would be close to the proper positioning. Today I spoke with Rootlieb about a brand new hood. Their catalog doesn't have one listed for a 31 PA coupe. They do however have the design and for about a 6 week wait I can put a new hood on this car. Lots of guys run without a hood but my personal preference is to have one on the car. I suppose that's part of the reason I haven't dressed up the hemi. But the main reason is I love the original look of it the way it is. 20240410_160639.jpg 20240410_160342.jpg 20240410_160503.jpg
    RMR&C likes this.
  28. RMR&C
    RMR&C
    from NW Montana
    Are you going to run a full hood or just the top?
  29. 340 Power
    340 Power
    from NW PA
    I'm only running the top. The valve cover front corners stick out just enough to be a problem with side panels. The new hood is a single piece and doesn't have a center hinge point.
    RMR&C likes this.
  30. 340 Power
    340 Power
    from NW PA
    My shop time is shortening. I'm back to my full time job, and my hobby business is needing attention so things may slow down trying to wrap things up before paint and re***embly.
    A visit in March to my son's shop in NC I saw how easy it was to fit an alternator to this hemi. They are way more reliable than the old generators so I ordered a one wire chrysler alternator and mounted it this morning. 20240421_105244.jpg 20240421_105235.jpg
    Hemi Joel and 31chevymike like this.
