Vintage Sun Tune Up, Testers, Scopes, Analyzer, Distributor Thread
Discussion in 'The Hokey Ass Message Board' started by Flathead Johnny, Oct 14, 2013.
  1. Paul
    Paul
    Editor
    found this Snap On unit at an antique store today for a reasonable price, plugged it in and heard it struggle, very nearly bought it anyway..
  2. INVISIBLEKID
    INVISIBLEKID
    from Gilroy,CA
    Finally got my 820 fired up! A few bulbs out in the meters, which is no bigee...... The screen actually warmed up, and started to show, but only on raster........(flat line)I let it sit for a while, 15 mins, and then it blew the breaker strip...... I reset the breaker on the machine, and now it instantly pops........ Something is worn/touching.....I haven't dug into it yet, and only a visual dig in first.........Looks cool, and have all the accessories, but id'e still like to get the screen up and going........Before I electrocute myself, i'll be asking..........;)
  3. hotrodderhaag
    hotrodderhaag
    I picked up this Sun 400 and cabinet.. unfortunately I gambled and it doesn’t work. The unit will spin the dizzy. No flash. And non of the gauges work .. I installed a D and AA battery in the panel. And the tach will pull the needle to the left when you put it into calibrate . Aside from Paramont , is there anyone who’s good with these to help diagnose it ?
    winduptoy and cactus1 like this.
  4. hotrodderhaag
    hotrodderhaag
    This unit came from a high school shop cl***
  5. G-son
    G-son
    from Sweden
    "Condenser resistance"? What would be the function and purpose of that?
  6. Hotwyr
    Hotwyr
    My 504 dist machine has developed a clunking, knocking noise. Belt and drive cone are ok. Any thoughts as to where I might start looking? Thanks
  7. ClayMart
    ClayMart
    There's bound to be some bearings in that drive ***embly. Considering the minimum age of those machines, any grease in them may have solidified or gotten some dirt in them.
  8. Hotwyr
    Hotwyr
    Thanks. I guess I'll just to have to tear into it. It's weird it was ok the last time I used it and started making noise. Guess that's how it goes.
  9. ClayMart
    ClayMart
    Is the noise there all the time or only when a distributor is mounted or not mounted?
    o_O
  10. Hotwyr
    Hotwyr
    Noisy any time the distributor drive is rotating. Distributor installed or not.
  11. ClayMart
    ClayMart
    This might be something to look into.
    http://paramountd.com/parts.html
    Scroll down a little from the top of the page and check out the "Idler Wheel Kit". Sounds like the rubber on the wheel can deteriorate and develop flat-spots which could make it rumble and growl.
    chopnchaneled likes this.
  12. Hotwyr
    Hotwyr
    Thank you. I'll check it out. Wasn't quite sure where to begin looking.
  13. jaracer
    jaracer
    That comes from someone cranking the speed control without the motor running. It puts a flat spot on the wheel that rides on the drive. That was one of the fist things we were told never to do.
  14. N72727
    N72727
    from FRANCE
    Le Mans 24 Hours 1966.
  15. winduptoy
    winduptoy
    Paramount was OK to deal with...I purchased some parts from him to fix my free machine....earlier than anything he had listed.
    The LED conversion is wonderful ....your old neon one probably is beyond repair.. the conversionn was pretty straight forward to install
    To get the tach to work you need to have car battery voltage in addition to the dry cells...
    I decided just to use an external tachometer that I had and knew it's condition. I had a very nice old 12V DC power supply that I use in place of the car battery
    His belt and drive wheel was good quality
    Good luck
    cactus1 and stillrunners like this.
  16. gregsmy
    gregsmy
    from Florida
    I was cleaning out a storage area and decided to drag out my Allen E137 distributor machine. I bought it around 87 or 88 from a local Sanford & Son type place. I was 18 or 19 and just thought it was cool and probably didnt pay much more than $20-40 at the time. I remember playing around with it a little, but not knowing anything about what to do with it. At some point I found a chrome, dual point, Mallory (I think) distributor and stuck it in there and thats how its been ever since. At that time the strobes all worked along with the gauges and vacuum.
    Now that I am older and wiser I am not going to plug it back in until I do some repairs to the wiring and replace the capacitors. It looks like the capacitors where replaced before as they dont fit in the original holders. My plan is to just clean it up and hopefully make it functional again then figure out what I want to do with it.
    Anyone have any manuals or information on this model? I have hunted around and found a few pieces of things here and there, but nothing specifically for this model. It doesnt look like the Allen equipment has the following that the Sun equipment has.
  17. jaracer
    jaracer
    You might be able to find Allen literature under the Rotunda name. Allen provided test equipment for Ford dealerships under that name. Sun had a better sales and service network than Allen. Both are quality, period test equipment.
    stillrunners likes this.
  18. stillrunners
    stillrunners
    from dallas
    Old Hangtown Speedway....Uncle took me there back in the late 60's when he was helping Frank out in the pits.....one of the few that guys still running a GMC motor.....still have the program som where...
    choptop4 likes this.
  19. gregsmy
    gregsmy
    from Florida
    I looked around for Rotunda and didnt find anything that matched. I have some information about operation of it and think I could figure the rest out. Looking more for some service information and wiring schematic. Not looking to "restore" it, just clean it up and repair the wiring that needs addressed. Here is a pic of it.
  20. 1930artdeco
    1930artdeco
    from Lynden, Wa
    Just adopted these two for winter projects. Anyone know what model as I have so I can find a manual for them?
    Mike
  21. bctexas
    bctexas
    Hi Mike! Nice looking units! The model should be listed on the metal tags attached to the machines. The Distributor tester looks like a "MDT" that appears in the June 1952 catalog, and the Motor Tester appears in the same catalog as Model MMT - "Master Motor Tester". Here are the four relevant catalog pages:
    Interesting to note that someone in the deep dark past hand wrote on the Master Motor Tester page "1949 model". Also interesting to note that $750 in 1952 (the cost of the Master Motor Tester) is the equivalent of $8,900 today. That was quite an investment back in the day!
    Happy Motoring!
    ClayMart likes this.
  22. stillrunners
    stillrunners
    from dallas
    Dang.....that motor tester looks just like mine I lost in my storage fire - hit by lightening.
  23. N72727
    N72727
    from FRANCE
  24. 1930artdeco
    1930artdeco
    from Lynden, Wa
    Wow, N72727, that is a neat shop! What truck is that?
    mike
  25. N72727
    N72727
    from FRANCE
    It's a Renault.
  26. patsurf
    patsurf
    we are ALL jealous--very cool!!
    cactus1 likes this.
  27. In_The_Pink
    In_The_Pink
    Saw these today inside the Wisconsin Auto Museum in Hartford, WI:
    stillrunners, loudbang, egads and 5 others like this.
  28. This one was gifted to me yesterday. Seems to work (well lights up and neeedles move anyway.) I have yet to hook it up to anything. Date on the manual is 1975. IMG_8100.jpeg IMG_8101.jpeg
  29. patsurf
    patsurf
    well-the pic taken in the dark....and your expression 'gifted' is suspect...!
  30. The pic is in the dark because I turned the overhead lights off to better see the machine lights? And gifted because it was given to me by my pal @2muchstuff so not sure what you’re implying?
