1948 Chevy Longhorn project
Discussion in 'The Antiquated' started by Blue 52, Mar 30, 2024.
  1. Blue 52
    Blue 52
    Here’s the start of a work truck project. I picked up a 1948 Canadian Maple Leaf truck summer of ‘22 to replace the ‘52 3100 that I regretfully had to sell. It came as a cab and front clip sitting loosely on an off topic 3/4 ton frame. I used my 1/2 ton as a work truck so I was looking for something a little heavier.
    Toms Dogs likes this.
  2. Blue 52
    Blue 52
  3. Blue 52
    Blue 52
    The 52 before I sold it, the 48 when I bought it, and a picture of my 48 that I found on the internet before I owned it on it’s original ch***is.
    down-the-road likes this.
  4. Blue 52
    Blue 52
    I started the project by fixing the grill and adding some inner fenders that the previous owner had disposed of. At that point I discovered the difference between the 1/2-1 ton and 2 ton and larger trucks. I formed a 14 gauge floor to fit the frame, dropping the body about 5”. I discovered why the ch***is isn’t a common one used, but I will have a 3/4 ton Chevy when done rather than a 1/4ton.
    Okie Pete, RMR&C and down-the-road like this.
  5. Blue 52
    Blue 52
    07D6F0AA-F86D-4D5B-8DBC-FA1F74BB4101.jpeg 9388DC9C-3267-4808-8538-C5C4A1DBEEB3.jpeg Last spring I saw a truck bed trailer out in a field, so I talked to the owner and he gave me his rotted out trailer. A box of a 54 Chevy. Not quite the right year, but the price was right so I grabbed it before he changed his mind. The floor was rotted and fenders a bit rough, so it was perfect for my work truck.
    Okie Pete, set me on fire and RMR&C like this.
  6. Blue 52
    Blue 52
    Now the dilemma. When I put a box side on the truck frame the rear wheel wasn’t centred in the wheel well. So I posted in -“Ad big truck rear fenders”…I wanted the 9’ box but ended up cutting it down by 4”.
  7. Blue 52
    Blue 52
    After shortening the bed, I moved on to something I was a little more comfortable with-stretching wood. I picked up some cheap oak this summer and almost had enough boards long enough for the bed, so I “stretched” a piece to work for one of the outside boards. I also welded bolts to the bottom of the metal strips between the boards so I’m not bumping things over the bolt heads in the box. This was worked on over this last fall and winter.
  8. Blue 52
    Blue 52
    D2DA1BB9-C319-47D2-B054-D25D20824E90.jpeg B3D8531F-4013-4729-9629-CB22A2EFF0FE.jpeg 911339D0-1A74-4DEE-B5E9-F9813416294A.jpeg F8CC86F5-0017-438C-8910-409B6E4E31A3.jpeg One of the challenges of putting this body on a larger truck ch***is was the width of the box. I figured that since the front fenders were an inch wider then the half tons already, and the rear fenders were rough, I tried splitting them and adding a strip. While I was at it I took an inch out of the rear fenders to give them a larger opening and added to the front fender opening to make it smaller. The rear openings were 30” ant the front fender opening was 36”. Not exactly the same now but much closer.
  9. Blue 52
    Blue 52
    1BB35635-6231-435F-911C-66055961DD2F.jpeg 305CC004-D394-4137-B5C6-B59CE392BEB5.jpeg 63C22420-A98D-4546-8B84-A823C7E83A5E.jpeg 42CD40FC-0B76-4154-AA3D-0FDBBBB2037C.jpeg 1F798201-2AD3-4D7A-B70F-7BDE5C812326.jpeg 9C72030C-F608-49EA-B10F-3B720B6FDCD7.jpeg 3CB25A69-E2EC-4290-9B8B-516FB6DD66B6.jpeg 6F19427F-A434-4928-8AFD-513F766386A6.jpeg Last weekend it was time to address the cab, the belt line had some rust holes that needed attention. Though I was ok with the regular cab, I really wanted a deluxe cab with comer windows, so when I came across a cab without a serial number, I grabbed it.
    First task was to dismantle the cab and save the metal. Then I gave my truck a haircut. Followed by fitting the five window skin to my cab.
    Oh… and sharpen drill bits over and over as I drilled out a mul***ude of spot welds.
    BigRRR, Okie Pete, 302GMC and 6 others like this.
  10. Quite a transformation, winter is long in Saskatchewan.
  11. Greg Rogers
    Greg Rogers
  12. Blue 52
    Blue 52
    78E8B8E8-E8A6-49F8-9229-5176A9C7CD14.jpeg Thanks. Unfortunately the winter is disappearing before my eyes and the yard and garden work of summer looms ahead.
    Trying to get rear axle finished up before it sits for the summer. With the help of an experienced mechanic friend, we are changing the rear gears from 4.11 to 3.42 for little more relaxed highway driving.
    down-the-road and Okie Pete like this.
  13. So what does the longhorn in the ***le represent?
  14. Blue 52
    Blue 52
    I’ve seen a few chevys from early seventies with the longhorn designation for a long box. Since I’ve owned a short box, I liked the term longhorn for the 8’6” box. Also since it is badged as a maple leaf (or two ton) I liked the idea of a longer box heavier duty truck. I’d like to get some custom decals for the hood that say maple leaf with long horn underneath
  15. Longhorn will be unique. I wasn’t sure if we should be expecting horns on the hood or what exactly.
  16. Blue 52
    Blue 52
    image.jpg image.jpg Patched in p***enger mirror mount, now to do the one on the drivers side. I’ve spent a few hours here and there over the last few weeks welding up all the spot welds around the windows. Feels like an unending process.
  17. Toms Dogs
    Toms Dogs
    from NJ
  18. 1930artdeco
    1930artdeco
    from Lynden, Wa
    Neat transformation and great metal work! Just curious-on the diff case is that a crack in the upper right portion?
  19. Blue 52
    Blue 52
    Thanks. That’s a sharp eye. I took a closer look and it’s a bit of gasket that needs to be cleaned before we seal it up. Still waiting on a few parts before it’s ready.
  20. Blue 52
    Blue 52
    90C00DDF-4FB7-4037-A586-02714D450763.jpeg since it is badged as a maple leaf (or two ton) I liked the idea of a longer box heavier duty truck. I’d like to get some custom decals for the hood that say maple leaf with long horn underneath
    Here’s a preview ready to be printed.
  21. Blue 52
    Blue 52
    4E7C39F2-34BA-465F-A082-64D743A0309D.jpeg 57EFFE24-1EA3-46E8-9ADC-6B12DF976DEC.jpeg It’s hard to believe that it’s been a year and a half since I last posted. The truck mostly sat dormant over last winter with a new born needing dad’s attention, and many other projects taking precedence.
    This spring I managed to weld in a clutch/brake pedal ***embly and oil the bed wood. Then I managed to book a week off work and go hard on the truck to free up the shop for a family gathering.
    1952henry and Okie Pete like this.
  22. Blue 52
    Blue 52
    Removed cab on my week off to finish floor and firewall and to work on the ch***is. Built a bracket for a hydraulic clutch slave.
    down-the-road, BigRRR and Okie Pete like this.
  23. Blue 52
    Blue 52
    09D1B0EF-8C5F-41E6-8C1B-BD26DC477452.jpeg F99EFCB3-2C90-45D4-84D5-A91941049D89.jpeg B6703AC2-DE22-49DC-8C58-367D8B92941D.jpeg Patching more holes and some help with rust paint on bottom of cab
  24. Blue 52
    Blue 52
    74847A70-D739-4794-A662-231255E316E0.jpeg 926805A9-3322-4949-873B-4B89381CC624.jpeg 9C6CA54C-5B96-4BCC-AED8-14D7E62994BE.jpeg ***embling bed, some direct to metal urethane on cab and bed sides, and putting cab back on frame. This is no show truck, the paint went over dents and smoothed welds. Unfortunately at this stage in life I don’t have time for a show truck. My goal is to fix holes, make it a uniform color, and get it road worthy so I have a work truck. Maybe when my littlest one is 16 she can help me make it pretty.
  25. Blue 52
    Blue 52
    0C2F9AC7-8DC2-48E7-8C2A-E79CC5472098.jpeg FB6F830B-9E76-43A8-853B-8A4D2A6D2C03.jpeg C7DFF79E-1756-42D0-B587-361C73CD79C2.jpeg Bed ***embly, front clip back in place and bed put on.
  26. Blue 52
    Blue 52
    88565897-0FBC-47DA-A6CF-7607753F3B22.jpeg 7144ED38-0542-4F43-B0ED-86A670B3133E.jpeg 6872691A-52FD-4DB3-AF27-EA9565E8FDC0.jpeg Finally load up all the extra parts in the bed and roll it out of the way, clean up the shop and get ready for the family.
  27. Blue 52
    Blue 52
    ABCFFFAC-BA53-4CCE-ACE5-956459EA7B85.jpeg 92FD96EB-A824-4520-B034-E630D8420594.jpeg Being that the truck started its life as a two ton, there was no fuel tank in the cab so one was added to the rear frame. I’ve always hated the fuel filling spot cut through the floor of the bed and I came across someone who put the filler in the rear fender. So I gave it a try.
  28. 1952henry
    1952henry
    Nice project! I enjoyed reading through it.
  29. You are heading into another winter hope you get some shop time.
  30. Blue 52
    Blue 52
    I’m sure hoping so! My oldest used my blue 52 4 years ago. I would like to have it running for my sons grad this coming June. He’s got some artistic talents so I’d like to have him pull some pin striping on the truck.
