Technical School me on spoon pedal throttle linkage to dual strombergs
Discussion in 'Traditional Hot Rods' started by tarheelrodr, Mar 31, 2024.
  1. tarheelrodr
    tarheelrodr
    First, the specs: 34 pickup with original spoon pedal assembly mounted on firewall with dual 97s (direct linkage on drivers side) atop slingshot intake.
    Searched for the steps on how link my spoon throttle pedal to dual 97s but can’t find what I need. I’ve got a pile of accelerator linkage rods to chose from but how do I:
    chose or fab a correct length rod? How does this set the pedal orientation for the drivers foot and range of motion for acceleration?
    Do I need a single rod from pedal assembly to the front or rear carb or use a rod between carbs and then link to center of this rod from pedal assembly (see last picture)?
    2Blue2 and winduptoy like this.
  2. Tim
    Tim
    from KCMO
    Your plan for tying the carbs together and linking it from the center seems correct from what I normally see.
    In my 46 I used the stock pedal which has a similar Z bar with a spring but to get it to connect to the throttle linkage on the drivers side I cut the upright off and welded it to the other side. So now it’s more of a T than a Z but acts exactly the same.
    Then I just connected the dots with solid rod cut to length and threaded for the quick release ball joints like your showing in your last photo.
    tarheelrodr and winduptoy like this.
  3. BJR
    BJR
    You need to narrow the firewall linkage or bend it so it lineup with the ball connection on the passenger side of the carbs. You can connect it to either the front or back carb, since they are connected together on the drivers side. Make the connecting linkage long enough that when the spoon is floored the carbs are wide open.
    clem, tarheelrodr and winduptoy like this.
  4. banjorear
    banjorear
    I'm in the process of replacing the heads so don't mind the mess, but this is what I did. Narrowed spoon pedal to fit the Model A firewall. Linkage rod to rear carb. Stromberg linkage on the other side tying them together. Linkage .jpg Linkage 2.jpg
  5. winduptoy
    winduptoy
    Looks like you have the bell cranks on the carbs on the back side. This ties the two together....good!
    Now all you need is a linkage from your foot throttle to either one of the carburetors on the other side. No reason to tie them together on both sides.
    As mentioned, you can bend/cut/lengthen/massage the foot throttle arm to align better with the carburetor bell cranks.
    You can also bend an offset or dog leg into the rod you use to connect the foot throttle to the carb.
    I used the quick release ball sockets from a stock linkage, cut to length and gas welded it back up.
    Hope this helps...
    Tim and tarheelrodr like this.
  6. continentaljohn
    continentaljohn
    I found a rod that was pretty close to hook up to the spoon pedal. I also have a setup like yours on the other side of the carbs. You’ll see guys cut and weld to get the correct length image.jpg image.jpg
    Speccie and winduptoy like this.
  7. tarheelrodr
    tarheelrodr
    Looks like I have an extra hole in the firewall underneath the pedal assembly. Am I missing a part of the pedal assembly? Am I missing some sort of bushing under the red primered cup covering part of pedal assembly?
    just above the pedal spoon I see a little knob that appears to be for a spring to attach?
    last pic shows mock of linkage to measure for a single linkage rod. IMG_0789.jpeg IMG_0788.jpeg IMG_0787.jpeg
    2Blue2 likes this.
  8. banjorear
    banjorear
    Some commercial spoon throttle assemblies (not sure what year that started) had two circular supports. It's possible your's did or someone installed on at one time. You can still modify your's if you'd like.
    winduptoy and tarheelrodr like this.
  9. I'd leave the linkage on the left side as you have it (make sure both carbs are sync'd) and make a new rod from the pedal arm to the front carb (less angle than rear carb).
    The connection on the inside was for the the original hand throttle.
    No bushing, the cover holds the housing down and the pedal shaft turns inside the housing.
  10. alchemy
    alchemy
    That knob on the pedal inside is what separates a 32 pedal from the others. Adds a $100 to the price.
    winduptoy likes this.
  11. TCTND
    TCTND
    Any of these suggestions will work, but from a mechanical perspective attaching the linkage to the rod that connects the carbs is the better choice. You'll get less throttle shaft wear and easier synchronization.
    winduptoy and alanp561 like this.
  12. Tim
    Tim
    from KCMO
    The 46 style throttle has two of those heim joint looking bolts to hold it to the firewall instead of one single like you have shown. Maybe it had one of those at one point? I’m not familiar with 32 stuff enough to say your missing one or not
  13. tarheelrodr
    tarheelrodr
    interested in this idea. I suppose this would mean modifying my pedal assembly so that linkage ball is sticking up on drivers side? How would I attach to the carb rod?
  14. TCTND
    TCTND
    Looks like the setup in your last pic would work fine if you trimmed off the excess. You wouldn't need (and shouldn't have) the linkage on the other side.
  15. BJR
    BJR
    Just make a correct length link from the pedal ball to the ball on the passenger side of the front carb and be done with it. Been done hundreds of times, you are over thinking it.
  16. AngleDrive
    AngleDrive
    from Florida
  17. That's a good one above ^^.
    I was going to suggest something like that. 2 ends and some bar stock, using a bigger piece of bar stock (with a set screw) to make a slider over the linkage for adjustment. That's the good thing about these cars, you can make whatever you can think of as long as it works properly.
  18. Marty Strode
    Marty Strode
    Speedway sells all of those pieces.
  19. continentaljohn
    continentaljohn
    As for your extra hole both my 33-34 firewalls don’t have that hole. image.jpg
  20. j ripper
    j ripper
    from napa ca.
  21. Screen Shot 2024-04-03 at 10.48.02 PM.png Screen Shot 2024-04-03 at 11.05.37 PM.png As for the EXTRA hole, those are likely B MOTOR cars that had the LONG throttle shaft as the carburetor was WAY off to the right side of the engine.
    I set my throttle up to pull off the front carb and aligned the throttle pedal ball end to be perfectly in line with the carbs and not pull at off angles.
    62pan likes this.
