Technical Gas gauge question
Discussion in 'Traditional Hot Rods' started by halfsack, Mar 31, 2024.
  1. halfsack
    halfsack
    Ok fellas, on my 49 ford coupe, when it was my dad's, he had the car fully rewired for 12v. I am finishing the job currently. I added a ground to the sending unit being it has a poly gas tank, and I have a 12v to 6v reducer from Dennis carpenter. All said and done, there is 5 gallons of gas in the tank, and when I turn on the key, the gauge goes up to 3/4 tank. I followed the wiring diagram from the green book and I have the positive on the correct post and the sending unit wire on the corresponding post as well. What could be my issue? No smoke show so I did something right at least. Lol. Thank you!
  2. Doublepumper
    Doublepumper
    from OR-WA, USA
    I'm no experto_O ***uming the float height is correct for the tank, possibly the sender resistance value (ohms), is incompatible for use with that fuel gauge...? Wiring sounds correct, from what you describe. Good luck!
    deucemac and clem like this.
  3. wheeldog57
    wheeldog57
    Dumb logic- 5 gallons=1/4 full and you are showing 3/4 full. Maybe swap wires. . . .
  4. halfsack
    halfsack
    20240329_174042.jpg I am no wiring genius by any means but I believe this is correct from what i've researched. Thankfully nothing went up and smoke when I powered everything up. Lol
    osage orange likes this.
  5. Hotwyr
    Hotwyr
    You mention it's a poly tank, so aftermarket. Is the sending unit compatible with the gauge?
    osage orange, warbird1 and JohnLewis like this.
  6. JohnLewis
    JohnLewis
    I'd make sure the sending unit is right for the tank. If you look up the poly tanks they list 17 gallon capacity- deeper than stock. Looks like they have a recessed area for the sending unit, but you never know how correct that is.
    osage orange and BJR like this.
  7. BJR
    BJR
    This.
    osage orange, Texas57 and warbird1 like this.
  8. If you remove the sender but leave it electrically connected, you may be able to bend the float arm to suit the tank, and adust it while someone reads the guage.
  9. PotvinV8
    PotvinV8
    If you can't get it sorted, this might help you out.
  10. piker
    piker
    Tanks inc (sells gas tanks and accessories) has a inline device called Meter Match that lets you calibrate sender with gas guage. This might help.
  11. Mike Miller
    Mike Miller
    When doing a 12 v conversion on a car with a 6v gage and sender I use a small voltage regulator from a late 50s to mid 60s ford, Mopar in those years also used them. It,s a small rectangle on the back of the instrument panel that feeds 6 to9 volts to the gages and works by a bi-metal spring with contact points that open and close to regulate the voltage. DSCF4445.JPG
    deucemac likes this.
  12. d2_willys
    d2_willys
    from Kansas
    What kind of voltage reducer are you using? If it is just a resistor, that is the problem. You need to use a solid state reducer, otherwise the voltage at the gauge will be higher than 6v. Check for 6v at the gauge.
  13. tim troutman
    tim troutman
    some good advice here yes with the sender out of the tank and the wires hooked up'move full to empty & watch the Guage. if it wont work out of the tank no amount of adjusting the float will make it work; next you will have to adjust depth & length of the arm may have to cut it of & rebend the L on the end or curve the rod, if using the ford type pulsating reducer I believe you need to check volts with a ****og meter as a digital won,t read
  14. halfsack
    halfsack
    It is the one from Dennis carpenter that you can use with multiple gauges instead of using the rundt style for each gauge. I hooked it up per instructions and via green book for the positive post and post for signal from sendingnunit. 20240329_174042.jpg
  15. 4wd1936
    4wd1936
    from NY
    Corvette Central and possibly others supply an adjustable resistor to be installed in the sender wire for a temperature gauge to adjust the gauge position. I have found it will work for a fuel gauge also.
  16. BJR
    BJR
    If the gauge will not read correctly when you test it out of the tank, it probably has the wrong ohm range for the sender that doesn't match the gauge. See chart below. First number is empty, second number is full reading.
  17. chopolds
    chopolds
    from howell, nj
    ^^^^^^^ This. Most aftermarket gas gauge senders are made for the GM Ohms range. Unless specifically ordered for another range.
  18. ekimneirbo
    ekimneirbo
    from Brooks Ky
    So, another guess from an admittedly electrically challenged individual........Isn't the ground on the Ford 6volt stuff............positive? Is it possible to reverse the connections and get a 1/4 instead of 3/4 reading?
    JohnLewis and osage orange like this.
  19. wheeldog57
    wheeldog57
  20. Oneball
    Oneball
    The fuel gauge doesn’t care about direction of current flow only the magnitude, reversing the polarity won’t make any difference to the gauge reading.
    deucemac, dirt t and halfsack like this.
  21. halfsack
    halfsack
    I'm just going to get a new sending unit from shoebox central. It's for 6 or 12v , made for the poly tank and will work with original gauge
  22. BJR
    BJR
    That should fix it.
  23. warbird1
    warbird1
    To get the gauge to read mostly correctly on my '40 with a poly tank I had to throw the aftermarket sender away. They are not compatible with an original Ford gauge. Then made an adapter to go from the modern flange on the tank to the old Ford sending unit and installed a NOS sender. It took a lot of fooling around with the float arm, float and the adjustment on the sender but I have a fuel gauge that works pretty well from Full to 1/2 and is very accurate below that where it counts...
    The Dennis Carpenter voltage reducer has worked well for me.
    RMR&C and winduptoy like this.
  24. dirt t
    dirt t
    Mike do you have a part number for that wizbang?
    Thanks
    Terry aka dirt t
  25. BJR
    BJR
    Or you could build a voltage reducer yourself. I did and put them on my 49 Buick. Been working for 5 years now.
  26. halfsack
    halfsack
  27. RodStRace
    RodStRace
    Before you bolt it all together, try a dry run on the new sender. Run the feed and connect a ground jumper. Hold it straight up (empty) then flip it over so the float is at the top of it's travel (full). Verify it's making the gauge read properly. Understand the tank can limit travel and that some bending/adjusting may be needed.
  28. halfsack
    halfsack
    Thank you. The car is going in tomorrow to get the exhaust hooked up and dumps installed.
  29. deathrowdave
    deathrowdave
    from NKy
    I ran into an issue on 48 truck , I used voltage reducer fame 60s era Furd all the same car and truck . Remember 6V system was + ground 12 V system is - ground
  30. RodStRace
    RodStRace
    Resistance doesn't care which direction, only diodes do.
