Technical 350 turbo 153 tooth flexplate question
Discussion in 'The Hokey Ass Message Board' started by clips221, Sep 25, 2016.
  1. chinarus
    chinarus
    from Georgia
    I have a 153 side by side starter OptimalPost.JPG - just trying to tap the infinite wisdom of the Hamb and save the few strands of hair...
    Thanks for pointing me the right direction
  2. 19Eddy30
    19Eddy30
    from VA
    pic of converter looks correct , when converter is slid all the way back to the pump typically 1/8 to 1/4 gap .....
    A """153 tooth""" flexplate / flywheel use the straight across
    ( holes on same side )
    ((168 are diagonal)))
    Metric bolts with a
    """ Oem production Mini style starter """
    use the metric ""Headed Bolt Head)
    The head is Mitric
    The threads are 3/8 -16 ,
    "" NOT """after market mini starter ))
    """Standard """ Big motor starters use
    SAE headed bolt head with 3/8-16 threads
    The Starter NEEDS to match Flex plate
    Bolts need to match starter USED
    No matter what transmission Used !!
