Termites and Bowties- Early Chevy Group
Discussion in 'The Hokey Ass Message Board' started by 29bowtie, Jan 7, 2009.
  1. Must have missed that light on your teardrop - enjoy your wiring duties this weekend and keep us posted brother!
    snoop74 likes this.
  2. Looking on the web today and found some repro trunk lid parts from I&I Reproduction. Can anyone with their original trunk lid still intact, looking at my 3 photos, show me your photos of these parts in your trunk lids? Then I can see firsthand what I need to do to modify my rumble lid to make it a trunk lid. Would appreciate this greatly for any help! Thank you!
    TFoch and Six Ball like this.
  3. brokedownbiker
    brokedownbiker
    Definitely following this! I'm going to be doing the same thing, I'm not interested in having the rumble seat, a trunk will be much more useful
    31chevymike and Six Ball like this.
  4. Six Ball
    Six Ball
    from Nevada
    One of the major design elements for my roadster it to preserve the large trunk space. I may need a place to sleep.
    31chevymike likes this.
  5. snoop74
    snoop74
  6. Six Ball
    Six Ball
    from Nevada
    That came out nice!
    31chevymike and snoop74 like this.
  7. snoop74
    snoop74
    IMG_8626.jpeg Thank you sir, the gl*** was a pain. I didn’t hold it long enough and it fell. Luckily it didn’t break
    brokedownbiker, GuyW and Six Ball like this.
  8. 28rpu
    28rpu
    Back in the early '80's I didn't have these parts when I built my coupe. I filled the handle hole and adapted a VW latch with a pull cable to actuate it. A couple of years ago when I was making changes to the coupe I decided to add the handle and latch. I bought these same 3 pieces from I & I. The wood had the holes for the striker plate and latch so that was a no brainer. The deck lid was more difficult but with a little measuring I was able to drill the hole in the correct position. I did have to modify the latch as it was not exactly correct for a '35. The latch was obviously meant to fit a deck lid with an inner steel panel and with the '35 it needed to screw into wood. I also had to sink the latch down into the wood. All in all it worked out great and I'm glad I did it. PXL_20221113_235552956.MP.jpg PXL_20221112_194032794.jpg PXL_20221112_214524842.MP(1).jpg PXL_20221114_003247998(1).jpg PXL_20221114_003256070.MP(1).jpg
  9. snoop74
    snoop74
    Would love to see some more pics of the car in your avi
    Six Ball likes this.
  10. Six Ball
    Six Ball
    from Nevada
    Good to see wood,
  11. Jay Altemus
    Jay Altemus
    My 34 Master body is far from being ready to go back on the frame. Still, I’m thinking about what suspension I want. My 34 frame is missing all of the original suspension and the current front and rear suspension is not allowed here on the HAMB. (If you want to see what is currently on the frame . . . . LINK HERE and scroll to pics right after the grille.)
    I would value some guidance.
    Speedway sells a 49-54 semi elliptical straight front axle which might be similar to what my 34 had originally. Or maybe I should consider a FORD spring behind drop axle with hairpins or 4 bar.
    Go easy on me . . . some of this is new terminology to me and this is my first pre-war hot rod. I might get terms confused.
    For the rear axle . . . I’m completely lost.
  12. Appreciate your photos greatly - have an idea what I need to do... I'm leaning towards adding steel on the top of the rear panel under the trunk lid to make the lid close more solid.
    Six Ball and 28rpu like this.
  13. snoop74
    snoop74
    As much as I'm a chevy guy I did end up running some ford stuff. I'm running a 36 rear spring and a 33-36 front axle. I do like the chevy stuff, but I didn't have any of it and built the frame from scratch. A lot easier to find the ford stuff. Running juice brakes, and 9in as well. I was able to get some of the stuff I needed from RJayspeedshop(rear spring cross member, ladder bars, rear spring perches. Then I got my split bones from carrillo customs. and bought a front crossmember from speedway
    31chevymike, Six Ball and Jay Altemus like this.
  14. 28rpu
    28rpu
    PXL_20210529_045014038(1).jpg PXL_20211102_230026412~2.jpg PXL_20230527_234427464~2.jpg PXL_20231226_031254852.MP.jpg
    rumblegutz, TFoch, cactus1 and 7 others like this.
  15. 28rpu
    28rpu
    I originally built this car with '39 Ford tail lights. (who didn't?) They point to the sky instead of the rear. I always kept an eye in the rear view mirror to see what the person behind me was doing when I braked. More often than not I noticed that they seemed to not see the brake lights. A couple of years ago I decided to make a change for safety. I got some repop '35 Chevy tail light stands and shortened them 2 5/8” and added '33 Ford tail lights. I patched the '39 holes, blended the paint and now am a little more comfortable with the cell phone addicted driver behind me. PXL_20221210_223926836.jpg PXL_20230322_230710749.jpg PXL_20221217_005448273.jpg PXL_20230416_000156334.jpg
    TFoch, Dan Hay, r2c1 and 4 others like this.
  16. Jay, not to worry... As far as the rear goes, the Chevy rear from 1955 - 1964 is all 60", an excellent width for 30's Chevy Hot rods. Since I bought mine, she had a '63 Chevy rear and the spacing between my tire and the rear quarter was excellent and aesthetically pleasing to the eye. And remember, you can adjust the tire spacing (tire to body) by the backspacing of the wheel so the tire is either closer or further away from the rear quarter (figuring for body roll). My new Winters QCR is the SAME width, knowing that I wouldn't have any issues, possibly a small adjustment with a new set of wheels by figuring the backspacing for the most part.
    If you decide to utilize fenders, this may or may not complicate things a bit. I had the original fenders on mine for about a year with no clearance issues of the tire hitting the outside lip of the rear or front fenders. Tire and wheel width is crucial to fenders, both rear and front. Do your internet search, even search the HAMB for better guidance - the members here are infinitely smarter than most, when it comes to hot rod builds. You know where I stand with front end choices... The final choice is YOURS. You can do it Jay!!!
  17. Holy Christ! Your '35 Chevy (Master or Standard) is so straight and clean, the alignment of your doors is exceptional along with the gaps - any car nut BESIDES Chevy enthusiasts checking out your car is going to think that the body is fibergl***! Us Chevy guys know that a repro body was never made for the Standards or Master series...
    28rpu and Six Ball like this.
  18. Six Ball
    Six Ball
    from Nevada
    28rpu, The lights fit the cat perfectly. That thing is beautifully understated. It just says. "Here I am, deal with me!"
    28rpu and 31chevymike like this.
  19. snoop74
    snoop74
  20. snoop74
    snoop74
    31chevymike and Jay Altemus like this.
  21. Six Ball
    Six Ball
    from Nevada
    That is cool!
  22. Jay Altemus
    Jay Altemus
    Just for a laugh.
  23. Six Ball
    Six Ball
    from Nevada
    It is not as funny once you've actually done it. :eek: But still funny.
  24. snoop74
    snoop74
  25. The Roundup is coming real soon - your hot rod will represent us Chevy rods very proudly sir!
  26. snoop74
    snoop74
    Yep, I just have to get the doors done. I’ll make sure I post a picture here before round up.
    Chuck Craig, 31chevymike and Six Ball like this.
  27. snoop74
    snoop74
    31chevymike, TFoch and Six Ball like this.
  28. rusty1
    rusty1
    try a rod that hinges at the bottom right of the opening, that swings up to a hole in inner decklid for a prop,...lots of new cars use this method on hoods.
    snoop74 likes this.
  29. Six Ball
    Six Ball
    from Nevada
    I think my friend still has this. It is a Studebaker part and original for a hood but I think you could make it work. I can probably get you a good deal on it.
  30. snoop74
    snoop74
    $200 or no deal!
