Introducing my Fuel Coupe-styled Tudor
Discussion in 'The Hokey Ass Message Board' started by Just Gary, Sep 18, 2006.
  1. Dino 64
    Dino 64
    from Virginia
    Oooh chrome !! Looks fantastic, they did a great job !
    So it should be a roller soon :)
  2. I finished the fuel tank & floor while waiting on the chrome axle.
    I cut & glued thin rubber pads (leftover bits of a '55 Chevy anti-squeak kit) to the tank's mounting tabs to reduce noise.
    Floorboard tops & bottoms are satin black epoxy.
    I ground down portions of the edges and stitch-welded them to the sub- and cross-rails.
    Then repainted the weld beads and sealed remaining seams with black silicone.
    It took almost one full 10.1 oz tube.
    BTW, welding the floor *after* the body was painted was a hassle.
    But it was a conscious decision, because the body needed to be as light as possible when rolling it to my backyard "spraybooth". Not an excuse, just an explanation.
    Now to the front-end! :D
  3. Tim
    Tim
    from KCMO
  4. Dino 64
    Dino 64
    from Virginia
    Go Gary go !! Heading for the finish line !! Look’s good ;)
    Just Gary and lothiandon1940 like this.
  5. Excellent!! Excited for you as you head for the finish line. Hope to see it in person....Don.
  6. the violator
    the violator
    What an awesome build, and an excellent color choice!!!!!!!!!
    loudbang and Just Gary like this.
  7. Thanks for the compliments, fellas. :)
    20240404_181011.jpg 20240404_180949.jpg 20240404_180854.jpg 20240404_180540.jpg
    Do other cars' bolt holes seem to move ever so slightly during the time between disassembly and reassembly?:confused::mad:;) 20240404_181737.jpg 20240404_181154.jpg 20240404_181340.jpg 20240404_181454.jpg
  8. Dino 64
    Dino 64
    from Virginia
    It’s got ‘the stance’ !! :)
  9. goldmountain
    goldmountain
  10. fastcar1953
    fastcar1953
    Looks great. Only question is the drag link looks like it is lying on hairpin.
    Just Gary likes this.
  11. Yeah- there's a 3/8" gap between them.
    A bunch of tasks still need to be done; alignment, cotter pins, yada yada yada. I might move the tie rod & drag link to on top of the spindles.
  12. Tim
    Tim
    from KCMO
    Wowza!
    I was just talking about “the old ford dance” last week. I had a part that I had numbers by each hole. It fit together perfect but you had to put the bolts in in a specific order lol.
    take it off, look at it, go to put it back on and none of the holes match lol tale as old as time.
  13. chevy57dude
    chevy57dude
    1. Maryland HAMBers
  14. 05snopro440
    05snopro440
    Sorry if this is a repeat of info posted, what size are those rear tires?
    That stance has me drooling. Looks awesome!
  15. So rad @Just Gary ! Can't wait to see it in person.
  16. Man, that looks great sitting on the chassis !
    Sharpone, mad mikey and Just Gary like this.
  17. Absolutely stunning Gary.:) I to hope to see it in person. This is very exciting.;)
  18. wrenchbender
    wrenchbender
    Wow that thing looks awesome but I have one question…… when are you installing the blower lol
    Sharpone, raven, chevy57dude and 3 others like this.
  19. Jeff Norwell
    Jeff Norwell
    MODERATOR
    @Just Gary ... this Hotrod came out wonderful... checks every box.... so well done.
  20. WOW! Jeff gave his approval as well, you should be very proud Gary. Any updates?
  21. That's because your "Den of Iniquity" was one of my inspirations.:cool:
    Sharpone, brEad, D-Russ and 5 others like this.
  22. I trimmed some welting to fit between the firewall, dash and cowl pieces.
    It took two hours to align and tighten Henry Ford's "Cowl Clamps from Hell": :mad::rolleyes:
    Kids' old soccer socks protect the steering column during installation.
    Stock top column clamp halves are both satin black, so they disappear.
    I gotta replace those modern TS & Flasher switches. Any ideas?o_O
    "Clear anodized aluminum" -colored powder coating looks a bit plastic-ish, but not bad.
    Sharpone, AHotRod, brEad and 14 others like this.
  23. The37Kid
    The37Kid
    Nice detail, painting the boxed rail section black. One of those "Nobody will ever notice" details that true craftsmen apply to most things.
    Sharpone, brEad, D-Russ and 8 others like this.
  24. Tim
    Tim
    from KCMO
    The stick on welting is genius after I pulled mine apart and all that worn thin cardboard bs dropped out I wasn’t really sure what I wanted to replace it with. Good idea. As is the socks over the column.
  25. Tim_with_a_T
    Tim_with_a_T
    Love the dash. Nice work.
  26. BigJoeArt
    BigJoeArt
    PROGRESS! I love it.
    This is my favorite picture so far.
  27. More parts.
    20240506_214646.jpg 20240509_200723.jpg 20240506_213210.jpg 20240509_194158.jpg
    To contrast with the black interior, I pillaged my scrap bin for a white B&M shifter handle, a stainless steel fender washer and a Mooneyes hat pin.
  28. 19Eddy30
    19Eddy30
    from VA
    Very Nice , Maybe in afew more months, I will have to break my habit and come sit beside your
    Fuel Sedan??!! Gary you know a few miles from your house on 50 towards the county line there are some stripes on the Road .
    Very , Very Nice touch to your Ball ;)
