Technical 32 Ford Roadster - what is this thing and what do I do with it?
Discussion in 'The Hokey Ass Message Board' started by SDS, Apr 5, 2024.
  1. SDS
    SDS
    Making the interior for my 32 Ford roadster (Brookville body).
    There are already a set of interior door handles, around mid-door. Can't figure out what the square shaft (please see photo) is for???
    I've looked at a lot of photos of similar hot-rods and there is nothing in that position - do guys just cut that off? I imagine I can put another handle on there, but have no idea what would fit on that square drive shaft and threaded hole.
    Thanks~
  2. Isn,t that a original inside lock ? Little lever fits on there, i think. See if it turns with a adjustable plier or good fitting spanner. It will just click a little, not really turn.
  3. Jim Bouchard
    Jim Bouchard
    Could it be that the outside door handle is a reproduction and the shaft is made “long” to accommodate different door thicknesses and a stock handle would be not protruding inside and you would need to cut off the extra “tail”
    clem, uncle buck, Carter and 4 others like this.
  4. When you say tail are you talking about the handle mount or something else?
    ekimneirbo likes this.
  5. Jim Bouchard
    Jim Bouchard
    The square shaft of the handle that is sticking out past the register on the latch
  6. hightower611
    hightower611
    Mark it flush and cut it off. I had to do the same on my car.
    Easier to not make a mess by removing it. Then you can make the cut nicer with no rough edges.
  7. BUT WHY DID HENRY PUT IT THERE. He did not put it there just to be cut off
    Ben
    seb fontana likes this.
  8. 05snopro440
    05snopro440
    Henry didn't, Brookville did. :p
    Carter, Oneball and clem like this.
  9. 05snopro440
    05snopro440
    What happens if you turn it?
    clem likes this.
  10. hightower611
    hightower611
    For those who haven't been through this, the arrow shows where on the latch that the outside door handle feeds through. And the line shows the excess length that a re-pop door handle shaft needs to be cut. latch.PNG latch.PNG handle.PNG
    clem, uncle buck, Carter and 3 others like this.
  11. alchemy
    alchemy
    Same handle for 33-34 roadsters. Maybe they require a longer shaft?
    lothiandon1940 and hightower611 like this.
  12. xix32
    xix32
    That handle is the same as a `30 or `31, they had the longer shank , for the inside handle to attach to .
    If it was a real model"A" version it would have a drilled and taped hole down the center to attach the inside handle to .
    Carter, The37Kid and lothiandon1940 like this.
  13. Deuce Lover
    Deuce Lover
    Alchemy is correct.The 33 roadster and phaeton's had a longer shank wit h a threaded hole at the end which was used to attach the inside handle. 29-31 Model A roadster and phaeton's had that same feature but shaft was was shorter I believe. 34 roadster and phaeton's had a different outside handle.
    micksmith and lothiandon1940 like this.
  14. lothiandon1940
    lothiandon1940
    Multiplicity of applications.:D
    Carter, Johnny Gee and Tow Truck Tom like this.
  15. One size fits all. Economy of manufacturing.
    Carter, lothiandon1940 and Johnny Gee like this.
  16. Johnny Gee
    Johnny Gee
    from Downey, Ca
    ^^^^^ One can only wish.
    lothiandon1940 likes this.
  17. ClayMart
    ClayMart
    And Henry would've surely approved of that . . . ;)
    Johnny Gee likes this.
  18. SDS
    SDS
    Always better safe than sorry...
    THANKS GUYS !
