Projects The “truth” roadster build
Discussion in 'The Hokey Ass Message Board' started by wandi harry, Feb 24, 2023.
  1. wandi harry
    wandi harry
    This a car l brought a while ago. Credit to the previous owner and bodywork guys as it’s a really nice body which needs minimal work.
    Original cowl and doors with a repro steel rear.
    I am going to run the ch***is it came with but will have to box it due to engineering requirements down here.
    It’s already stepped up a little at the rear and running a dropped original front axle. AB17F14F-41C1-430F-9F5D-71E48E7B6232.jpeg
    Stogy, Ziggster, Greenblade and 7 others like this.
  2. wandi harry
    wandi harry
    I am planning to build it simple, not to shiny but sort of dependable , hey maybe like it’s owner.
    I have never had a car before worthy of a name apart from the normal names like “you p.o.s “or “pile of **** “ but l had a few mates around having a few jars and the discussion turned to what l paid for the car and do you tell the missus the truth?
    Anyways there was plenty of banter about telling the truth or not and it sort of stuck. 7A808FEC-DE5A-4186-ADE7-B89DE82E6A71.jpeg
    Stogy, Ziggster, deadbeat and 8 others like this.
  3. wandi harry
    wandi harry
    Will be running a 39 box with f1 style pedal ***embly and mechanical linkage.
    I used a splined shaft from a mower deck which l was welded to the clutch shaft ,some machining involved but really simple.
    It gives you plenty of scope to position the clutch actuator lever in the desired position
    I did this on my 36 , works well 80F6F25D-EC40-415B-B6DA-0AF27F7CF7EF.jpeg 57AAAF32-CB14-449B-90D2-85C2E98BC1F5.jpeg D54B9DCE-2101-4E86-8B07-D2601CAD4904.jpeg [
    Stogy, Ziggster, deadbeat and 6 others like this.
  4. The real "truth" is that it's a hole in the pavement to pour money into!!
  5. X-cpe
    X-cpe
    The unfillable hole.
  6. wandi harry
    wandi harry
    Some progress
    Seat belt mounting points
    Seatbelts will be a requirement for registration on this one
  7. wandi harry
    wandi harry
    Frame horns were knocked around generally so l am in the process of fixing them up
  8. wandi harry
    wandi harry
  9. wandi harry
    wandi harry
    Ripped the guts out of the fuel tank and going with this IMG_4604.jpeg IMG_4645.jpeg
    Stogy, Ziggster, Greenblade and 11 others like this.
  10. wandi harry
    wandi harry
    Back into it
    Going to run a tandem m/cyl with remote reservoir accessible through boot/trunk.
  11. brady1929
    brady1929
    Great roadster.
    Stogy, chryslerfan55 and wandi harry like this.
  12. 56Packard
    56Packard
    from Phoenix AZ
    Enjoying the pics!
  13. Bandit Billy
    Bandit Billy
    I call my chap the truth, CUZ WOMEN CAN'T HANDLE THE TRUTH! :cool:
    Nice work on the roadster! Cool gauge insert.
  14. wandi harry
    wandi harry
    Was thinking of retaining the original cross member but l don’t think it will be required
  15. wandi harry
    wandi harry
    Stripping frame down to sandblast
    I was bouncing around the idea of not blasting it in an effort to try and retain its patina/history /vibe but the reality is by the time l have boxed it and welded up excess holes what’s left of the old paint will be a mess .
  16. wandi harry
    wandi harry
    Back into it again
    Dragged the ch***is table down from the loft , got it might as well use it.
    Frame is in really good condition as far as rust but did have a reasonable bow in it , measured 5/16 in the middle, l have taken most of this out with a bit of “tweaking “. Heat and pulling.
    Get it straight, fill some holes then box it
  17. wandi harry
    wandi harry
    Bouncing around all over the place but it will all come together
    Trying to come up with a new option for the torque tube centre bearing, experimenting with modern centre bearings
  18. wandi harry
    wandi harry
    IMG_6725.jpeg IMG_6634.jpeg IMG_6458.jpeg The splined coupler was totally screwed
  19. wandi harry
    wandi harry
  20. wandi harry
    wandi harry
    IMG_7601.jpeg Really happy with the gauge panel, poor man’s options, el cheapi gauges , popped of the gauge gl***es and put a cooler logo on them
  21. wandi harry
    wandi harry
    Making a start on preparing body for paint
    Lots of surface rust, l found the heavy rust actually came of cleaner than the lightly rusted
    All came of reasonably easily with the wire wheel,
    Whatever you do when you use these things l highly recommend using appropriate safety gear, at the very least safety gl***es.
    IMG_7618.jpeg IMG_7616.jpeg IMG_7617.jpeg IMG_7620.jpeg IMG_7622.jpeg IMG_7623.jpeg
  22. wandi harry
    wandi harry
    Had a mate machine up the axle housing bearing surface so we could fit new sleeves/ hub bearings
    Of course the housings had been pulled out of straight when the spring perches had been welded on. So he got the housings straight before commencing machine work.
    Thanks Glenn , your work probably needs its own thread.
    So the actual ***embly and set up of the rear end was reasonably straightforward and not as daunting as l thought it could be.
    So l am now just mocking it up in the ch***is to check that the modified (shortened) tube and drive shaft are the correct length.[/ATTACH] IMG_9034.jpeg IMG_9040.jpeg IMG_9042.jpeg IMG_9043.jpeg
  23. wandi harry
    wandi harry
    so while I was messing around with shortened drive shaft I thought it may be worthwhile checking it for straightness and of course one end was out .015 thou , which could not be great for the roller bearings in the torque tube or the u/j on the back of the gearbox. Through heating and quenching I was able to get it down to .003 which I can live with, I know quenching is probably not the best and .003 is not perfect but I'm going with it.
  24. patsurf
    patsurf
    what is wrong w/ either of those factors??
    Stogy and chryslerfan55 like this.
  25. wandi harry
    wandi harry
    I just figure if that solid drive shaft isn’t running true the roller bearings it runs in will get flogged out as well as pinion and u/j
    Thoughts ?
  26. alchemy
    alchemy
    No need for an additional bearing towards the rear of the torquetube since the pinion will hold the shaft where it needs to be. And no need for an additional bearing towards the front since every torquetube already has one there from the factory.
    Only reason the midpoint bearing was added in the later 30’s was to prevent the whipping that the smaller diameter bar they used for the driveshaft was gonna give at those long lengths.
  27. wandi harry
    wandi harry
    My dodgy drawing is not accurate enough, that rear roller is further forward, as out of factory, was just trying to convey my thoughts on a bent drive shaft.
  28. wandi harry
    wandi harry
    IMG_9113.jpeg IMG_9122.jpeg Big milestone for me is putting the body back on the ch***is for hopefully the final time.
    As mentioned earlier l decided to go with a remote fill master cylinder, l think l should have just gone the normal/ standard route and used just a standard under floor master cylinder accessed by a removable floor panel. I have ended up with a combination of hose and tube from master cylinder to reservoir with way to many joins, l could possibly have just used hose for the whole run but would still have had a number of joins . Note : there is a specific sae rated hose to use in an application like this .
    Anyways l am very happy to be at this stage of build, looking like a car again and making progress.
    Clutch hooked up and starting on bleeding brakes.
  29. ronzmtrwrx
    ronzmtrwrx
    That’s gotta feel good to reach that point. Looking great. You’ll be blasting down the road in no time.
    Stogy, wandi harry and chryslerfan55 like this.
  30. Tim
    Tim
    from KCMO
    Awesome man :)
