Technical Help identify
Discussion in 'The Hokey Ass Message Board' started by Jamoke, Apr 8, 2024.
  1. Jamoke
    Jamoke
    Anyone know who made this fiberglass Ford headlight front end for 37 Chevy and can you tell if this is a 39 or 40 Ford headlight
  2. Dan Hay
    Dan Hay
    Those look like 37-39 standard to me. I’ve never seen that front end treatment before, you sure that isn’t a custom glass job?
    lurker mick likes this.
  3. Jamoke
    Jamoke
    I am not sure that's why I am asking I wish I knew I have a problem with one of the buckets
    Dan Hay likes this.
  4. Dan Hay
    Dan Hay
    What’s the issue with the buckets?
  5. RodStRace
    RodStRace
    1939 was last year of headlight bulbs, 1940 was first year of sealed beam headlights.
    https://blog.headlightrevolution.com/blast-from-the-past-sealed-beam-headlamps-history
    That said, if the whole thing is a fiberglass conversion kit it probably is 'like' a 39 or 40, but doesn't directly interchange. Sorry you are getting into it. Here are some pics.
    1939
    https://www.jalopyjournal.com/forum/threads/1939-ford-headlight-rings-wanted.1286817/
    1940
    https://www.jalopyjournal.com/forum/threads/1940-ford-headlight-buckets-and-ring.1194290/
    Seems like these are not 40 with the additional 'stuff' on the top.
  6. Jamoke
    Jamoke
    Buckets are to deep for front tires
  7. fuzzface
    fuzzface
    they look like ones i brought years ago, they were hagan 37-39 ford . someone like a year ago had some listed here for $100 if i remember correctly.
    Bob Lowry likes this.
  8. fuzzface
    fuzzface
    Hagan Brand 1937-39 Ford Fiberglass Headlight Buckets New
    $100.00 plus $20.00 shipping 216-406-6301
    these were posted by hotrodhoodlum in 2022. this is the same set i had.
    RodStRace, pprather and Bob Lowry like this.
  9. pprather
    pprather
    So, it looks like the buckets have been identified.
    It seems, to eliminate the tire/bucket interference;
    1. modify back of bucket, or
    2. Run a smaller diameter tire, or
    3. Raise front suspension, so bucket is above interference area.
    Other ideas?
  10. pprather
    pprather
    I would guess your repro buckets are deeper than a stock bucket, to French the headlight?
    Dan Hay likes this.
  11. Dan Hay
    Dan Hay
    Well, 37 Chevys never had headlights in that location so there’s that. Hard to know if a stock Ford bucket would fix the problem.
    pprather likes this.
  12. RodStRace
    RodStRace
    The power of the HAMB!!!
    I shiver to say it, but modern LED lights are less deep. It ain't kosher here, but if the guy that's tasked @Jamoke to fix is this deep, that might be the quickest, cheapest solution. I hate 'em, but are ya going to go back to stock?
  13. Jamoke
    Jamoke
    Thank you so much HAMB guys are incredible as usual
