Technical Hard chop: sitting on the chopping block
Discussion in 'Traditional Hot Rods' started by 65standard, Feb 21, 2024.
  1. 65standard
    65standard
    Next the other corner and then that long 5/8” gap across the cowl.
    31chevymike likes this.
  2. Outback
    Outback
    from NE Vic, Oz
    Lovely work, thanks for walking us through what you are doing, such a nice job!
    Nostrebor and 31chevymike like this.
  3. RICKY~RICARDO
    RICKY~RICARDO
    from Milwaukee
  4. 65standard
    65standard
    DDB76123-348C-43CC-87D7-FB40821C9277.jpeg 6436633E-C83D-4C9E-B1E3-620881998ED9.jpeg Starting to work on filling the cowl gap. Test fit the roof skin to get a look at the profile. Everything is coming along smoothly and easy.
    I’m no Bobby Walden, but I like my technique on a heavy chop.
  5. hotcoupe
    hotcoupe
    Bobby Walden is probably taking notes!
    Tom
  6. 65standard
    65standard
    970A31AF-18C3-44FB-9957-66D64049AE06.jpeg D3C63FEA-312B-4BBA-B808-F5D036A4BD58.jpeg Very different look
  7. impala4speed
    impala4speed
  8. anothercarguy
    anothercarguy
    Great job...fun to follow along on your progress and process! What's the purpose/story on the yellow spray painted legs and floor?
    Outback likes this.
  9. Motorwrxs
    Motorwrxs
  10. Dang the un-chopped version looks goofy now
    redzula, rpm56, 65standard and 8 others like this.
  11. flamedabone
    flamedabone
    Unchopped early Fords look like a tractor cab.
    -Abone.
  12. 65standard
    65standard
    Working on filling the cowl gap 12” at a time. I aligned the metal with a couple of bolts and washers. Then cut a strip of 19ga and scribed it to fit the gap. 8E64227A-15AB-4B9D-8372-AA0B2E76D722.jpeg 97E2F334-A0F7-48C0-B53C-AEF269140FAB.jpeg
  13. 65standard
    65standard
    4A15032F-6C15-45DF-966B-7E4A4E4A522C.jpeg EF1B649B-C9FE-413F-8DF0-D278C84AE1AB.jpeg C6923EC7-4120-49DA-A4EB-EEC90CE76B54.jpeg D6AA1120-33D9-4459-AD63-2E11C9E52D4B.jpeg Tack welded it in
    Then fully welded
    Next I knock the top of the weld down close to the parent metal. Then the long process of hammering and dolling the weld to restretch it. Finally, comes the filing and planishing to even it up.
    I don’t want to grind any of the parent metal away. I would rather fill with lead than to keep grinding the weld down til it disappears.
  14. 65standard
    65standard
    A5E5F5BF-4D95-4617-887F-2462C78AD949.jpeg Continue filling the cowl gap.
  15. AmishMike
    AmishMike
    In pictures always looks to me as windshield section higher then rest of cowl. Is it the picture, my eyes, or do you hammer down as weld or?
  16. 65standard
    65standard
    I guess it looks like I bashed it down in the picture but I didn’t. I will try to metal finish the panel. I don’t want filler.
  17. pprather
    pprather
    It looks like the suicide doors will attach with two hinges per side.
    Do the hinge pins still align, so there will be no bind?
    Nice progress.
    tb33anda3rd and 31chevymike like this.
  18. You and your fancy 19 gauge
    phhhhtttttttt:)
    I’ll get some one day
    Maybe
  19. tomcat11
    tomcat11
    Really nice metal work. Night and day improvement on the look. Thank for sharing the details.
    65standard and 31chevymike like this.
  20. 65standard
    65standard
    I only removed the middle hinge so the doors should still swing like originals
    31chevymike, porkshop and lucky ink like this.
  21. pprather
    pprather
    Understood, easier to align two hinge pins than three.
    31chevymike and Fordors like this.
  22. 65standard
    65standard
    3CCDD12A-1DC0-4D39-8BC0-98B10310AC8F.jpeg Half the cowl is filled.
  23. Beautiful. Magic.
    Looks like welding that narrow strip puts a lot of heat in one area. But you're keeping it from warping.
    Might be too much to ask, but I will anyway. Any chance of you doing a short video of the process? I'd love to see your technique. Especially the hammering. For our education. Perfectly okay if you're not up to it, there are plenty of other hammer-welding how-to videos. But the proof is in the pudding, you make good pudding, and I think we might be able to learn something from you just by watching. I know I would.
    Keep up the awesomeness.
    Outback and 31chevymike like this.
  24. 65standard
    65standard
    I won’t post welding on here. Too many different opinions on how I need to do it.
    Welding the strip on the cowl isn’t anything special. I can say is get it tacked in and aligned up perfect before welding.
    There is no such thing as warpage from welding. What is actually happening is the weld shrinks from the heat and that shrinkage may pull and distort the metal panel near the weld. Do not try to fix that distortion. Just re stretch the weld with a hammer on dolly technique and the distorted metal will relax and fall back in shape.
    I’ve seen more panel ruined from grinding heat than welding.
    I learned my metal skills from Peter Tommasini. He took me under his wing and showed me hands on how to move metal. He sells DVDs on how to do these things.
  25. 65standard
    65standard
  26. 65standard
    65standard
    43E3D8C3-6E49-4DD5-A79A-F7C0704ACE3C.jpeg After the cowl work, I’m onto the back window and corners.
  27. L. Eckart
    L. Eckart
    That chop looks so good!!! Thanks for sharing your method although I dont have the talent to pull it off I really enjoy seeing the process and your skills.
    porkshop, 65standard and 31chevymike like this.
  28. gimpyshotrods
    gimpyshotrods
    If you sand down your 18ga panels before you spray primer, or apply filler, you made your own 19ga.
  29. hotcoupe
    hotcoupe
    Peter Tommasini is a great guy and terrific metal shaper, how did you happen to get in that situation where you were able to learn from a master? I was able to work with him for a few hours on two days, and I learned a lot.
    Tom
    Don't know how that highlighted paragraph got in there.
    Cali4niaCruiser likes this.
  30. HOTRODNORSKIE
    HOTRODNORSKIE
    I like your use of turn buckles on the bracing good idea.
    65standard, RodStRace and 31chevymike like this.
