Projects Mild custom '51 Pontiac Chieftain
Discussion in 'The Hokey Ass Message Board' started by PhilA, Nov 4, 2019.
  1. Getting road grime on it just means youre using it right
  2. PhilA
    PhilA
    Fitted a new muffler, much less headache inducing on the highway.
    Season of photogenic mornings is here.
    Phil
    treb11, bchctybob, brEad and 11 others like this.
  3. PhilA
    PhilA
    Just been driving about. Went to the Balloons & Boulettes festival yesterday, got to hang out with a bunch of other people which was fun.
    Weather remained nice so I went out for a short drive last night.
    Need to dig in and start on some work on the engine soon.
    Phil
    Rhinotoyz, 67drake, Woogeroo and 9 others like this.
  4. bchctybob
    bchctybob
    Don’t you just hate the damn bugs? Out here where I live the poor car gets pelted with bugs all year round and sometimes it’s just crazy how many bug carc***es you have to scrub off the front end.
    PhilA and loudbang like this.
  5. vtwhead
    vtwhead
    In FL during luv bug season the car would be black in about a half hour if you were running to the east coast across the swamps. Have to stop half way and get the first layer off the windshield just to see the road. Baking soda and hot water would remove them quickly so long as you did not let them bake on in the tropic sun. Fun times!
    bchctybob, PhilA and loudbang like this.
  6. PhilA
    PhilA
    Hot, hot, hot.
    All the windows rolled down, out on the highway.
    Phil
    bchctybob, fyrffytr1, brEad and 4 others like this.
  7. Johnboy34
    Johnboy34
    from Seattle,Wa
    fyrffytr1 likes this.
  8. TrailerTrashToo
    TrailerTrashToo
    Evaporative coolers only work in dry air. Phil is on the coast, the air is already saturated with moisture.
    brEad, PhilA, Woogeroo and 1 other person like this.
  9. PhilA
    PhilA
    Sadly yes. Here, those do nothing but get moldy in summertime.
    Idling with the A/C on my newer pickup will drop about a pint of water on the ground from the evaporator drain in fifteen minutes. The dew point is always near the ambient temperature here this time of year. 65% rH feels arid.
    Phil
    bchctybob, fyrffytr1, brEad and 2 others like this.
  10. PhilA
    PhilA
    Car's still here. Still going places.
    Phil
  11. fyrffytr1
    fyrffytr1
    If you don't get them off soon they will eat into the paint! I don't drive my OT GTO when they are swarming here in south Georgia.
    bchctybob, vtwhead and PhilA like this.
  12. PhilA
    PhilA
    Coaxed the starter into life. Really need to do something about it.
    Went get milkshakes. It's running okay but it's definitely grumpy from being sat up.
    Still, looks good sat on the driveway. Currently managing an eclectic collection (the green one being the reason I've not been posting much here, it's been taking to the time and money).
    Phil
    bchctybob, Mtn Goat, Ford52PU and 5 others like this.
  13. JD Miller
    JD Miller
    A little Ospho and couple squirts of Rustoleum rattle can and your good to go !... :D
  14. PhilA
    PhilA
    Yeah.
    I tried ignoring that and so far it hasn't fixed itself...
    bchctybob and Woogeroo like this.
  15. PhilA
    PhilA
    Out and about, today.
    A small meetup in town for breakfast. Not many people showed because there was another event they all went to.
    A little scenery to stare at on the way on from there into the city.
    Traffic queue as far as the eye can see. Got stuck for an hour in that. They were digging the whole road up to install culverts.
    Still, it was nice to drive through the city. Lots of thumbs up, yells, thumbs up and generally positive vibes.
    To Do:
    adjust brakes
    valve job
    brainstorm the gearbox because it gave me neutral instead of 4th twice in hot traffic.
    But, that was 120 miles round trip, a mix of highway and city. I held 60 mph up the bridge over the Mississippi on the Interstate, p***ing other cars who had no idea you gotta push on the gas when you go uphill. Nothing like a 74 year old car p***ing up modern traffic...!
    Phil
  16. bchctybob
    bchctybob
    I know you have kept your Pontiac mostly stock but have you considered tapping the transmission and incorporating a liquid to liquid heat exchanger to stabilize the fluid temperature? You are familiar with the transmission so you would be able to identify an outlet and a return. You just need an exchanger with radiator water on the other side to give the transmission fluid a steady operating temperature. Then figure which transmission fluid works best at that temperature.
    brEad and loudbang like this.
  17. PhilA
    PhilA
    I have and I have experimented; there's something at fault internally that's intermittent. It might be my fault in the rebuild. I have a couple theories I'm chasing, the most likely leads to the transmission coming to pieces again.
    Phil
    brEad, pvfjr, bchctybob and 3 others like this.
  18. PhilA
    PhilA
    I guess, to clarify, the oil viscosity past 20W makes no difference unless it's very cold; the only change that makes is the 2-3 shift is a bit slow.
    The primary theory I have is the clutches are intermittently leaking too much oil.
    The oil delivery sleeve is new, the rings are new but the drums themselves were good used parts. I replaced the clutches and steels and at the same time fitted new annular rubber seals.
    If the rings are leaking because the drum surfaces are worn, but when I back off the throttle it causes things to shift inside axially and seal better then that could be it.
    I have avoided one workshop manual test so far because it's horribly messy, and that is to pull the valve block off the gearbox body and apply compressed air pressure to the p***ageways that lead to the bands and clutches. Operation and leaks can be checked for. If I pull the lower pan off I can apply force to the drums radially and axially in place and check if that causes excessive leaks also.
    Something like that where the valve body can only flow a limited amount of oil and things are all out of wack because of that is a possible reason- if clutch 1 is leaking then it would cause at least a couple of the things it does.
    Phil
    dogwalkin, brEad, y'sguy and 5 others like this.
  19. pvfjr
    pvfjr
    Thanks for providing the continued updates, Phil. I always read every one, and have enjoyed learning a bit from your journey.
    PhilA likes this.
  20. Pontmerc
    Pontmerc
    from Finland
    Testing with air it is important to know that if you put 100psi and clutch engage, its not a sign its good.
    Testing with 15 psi will show you real deal.
    Been there, done that.
    bchctybob, pivir123 and PhilA like this.
  21. Rob Mawdsley
    Rob Mawdsley
    New to the site and this has probably been answered before:
    Just coming to the end of restoring this monster and will be changing the Hydramatic gearbox oil soon, it's only done 43,000 miles but at 75 years old I think it's about time to use new stuff.
    I've got a barrel of this, opinion please.....
    PhilA and bchctybob like this.
  22. vtwhead
    vtwhead
    @PhilA would likely know best. He will chime in here soon.
    bchctybob and PhilA like this.
  23. PhilA
    PhilA
    @Rob Mawdsley will that work? Yes. Will it leak? Yeah. You'd need to do a full flush and then another change after driving it a thousand miles or so to make sure you get all the old oil dregs out- the type A gets very very sticky when sat up for a long time and in thin film or around the sides of valves and such. Once the valves start moving the new oils have significantly superior detergent qualities and will eke out all the dirt that's been hiding in the old oil in crevices and corners. You may find the oil changes get a little more rough with this because it's a lighter grade oil.
    When changing the oil I would strongly suggest dropping the lower pan, as the drain hole leaves about an inch of oil in the bottom. You will need a new gasket. RTV doesn't work on these because when parked the oil level is well above the top of the pan once the torus drains down. New gaskets are available (cork style which compress well to take up the flex in the steel pan against the case).
    My suggestion is the Hydrostatic drive oil that Caterpillar/Deere/Case/Allison etc use in their plant machinery, specifically for that and not just regular hydraulic oil (they both work but regular hydraulic oil lacks the anti froth additives that high speed transmissions require, particularly the Hydramatic as it has no windage tray- open the lid on the power steering reservoir of a car after it's been running a while for an example why). It should be SAE 20W. I use J20A+ but any plant machinery place there should stock that or an equivalent. A full change is 11.5 liters.
    Phil
  24. Rob Mawdsley
    Rob Mawdsley
    Thanks for your reply.
    I checked out the requirements for Caterpillar/Deere/Case/Allison etc., and the stuff I've got already meets their spec's including anti-foam and other additives.
    In 1993, GM released new Dexron-III fluid which is backward-compatible with transmissions using earlier Dexron fluids. Dexron is a registered trademark of GM but is now manufactured by others under licence. So all looks good.
    I just need to get the gasket.
    Rob
    PhilA likes this.
  25. PhilA
    PhilA
    It's international, but Fatsco have been great to deal with for my transmission. Worth investigation.
    bchctybob likes this.
  26. Rob Mawdsley
    Rob Mawdsley
    I looked at them but the shipping was $60 for a $11 gasket. Found a UK supplier who has them for £23 shipped (Rolls Royce parts)
  27. PhilA
    PhilA
    Glad you found that. I wasn't thinking that RR used them, so good catch.
    Phil
  28. Rob Mawdsley
    Rob Mawdsley
    I know it's off-topic but I'm looking for an oil bath air cleaner and an external sun visor
  29. PhilA
    PhilA
    eBay.
  30. PhilA
    PhilA
    Cold snap today.
    Nice and toasty warm once it's up to temperature.
    Phil
    brEad, bchctybob, dogwalkin and 7 others like this.
