Hot Rods 39 Ford Trans throw out bearing question
Discussion in 'The Hokey Ass Message Board' started by walls, Apr 13, 2024.
  1. walls
    walls
    Do I have the wrong one? Or is there a mix/matched part here?
  2. alchemy
    alchemy
    Your carrier is backwards.
    BJR, Algoma56 and AVater like this.
  3. 19Fordy
    19Fordy
    The above post is correct. Watch this video.
    Make sure clutch release fork is seated properly and don't overstretch the little spring.
    Bing Videos
    Algoma56 likes this.
  4. krylon32
    krylon32
    from Nebraska
    2065 bearing is the right number, got several on the shelf. Turn the hub around. press on the bearing with the bearing surface toward the PP, put just a dab of white grease on the bearing retainer, install and hook the spring.
    Algoma56 and seadog like this.
  5. walls
    walls
    I feel stupid that it was on backwards. I really need to get some manuals.
    Thanks for the help.
  6. krylon32
    krylon32
    from Nebraska
    One other thing, make sure you have the radiused side of the fork against the hub not the flat side.
  7. 19Fordy
    19Fordy
    Krylon makes an EXCELLENT point of importance.
  8. BJR
    BJR
    You are correct sir. :D
  9. walls
    walls
    Got it….And hopefully last question
    I ***ume the fork should be contacting hub on the flat area and I either have mix matched parts or I’ll need to grind a bit off one or the other to make fit correctly.
    Am I on the right track?
  10. krylon32
    krylon32
    from Nebraska
    Your on the right track. A couple times over the years after I used up all the NOS Ford forks I could find (I used to buy a 100 at a time) and Job Lot closed their doors some of the aftermarket forks were to narrow and didn't fit. Since they were cast I had to grind slightly to fit. If your fork is a gennie it's forged and can be bent.
  11. BJR
    BJR
    Grind either the fork or the bearing carrier.
  12. walls
    walls
    Thanks guys
  13. 19Fordy
    19Fordy
    Check to see if the part number of the clutch fork is 48-7515.
    The inside dimension between the two fork arms should be 2 and 1/8 in.
    I have an extra fork if you need one.
  14. krylon32
    krylon32
    from Nebraska
    Right now I have 50+ forks in stock that have been checked for width and honed for proper shaft fit.
