Technical What are you working on?
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 18, 2022.
  1. saltflats
    saltflats
    from Missouri
    Has a 409 that has been stepped on a little.
  2. swade41
    swade41
    from Buffalo,NY
    I put a couple more hrs in on the valve cover, took it up to 1000 grit, lots of scratches still in it but the novelty of sanding is wearing thin on my back injury.
    I gave it a round of polish anyway, when done these are going to look real good on my blower motor
    enloe, little red 50, rod1 and 21 others like this.
  3. HOTRODNORSKIE
    HOTRODNORSKIE
    Finally got the dual roller timing chain installed on the rocket had to do some modifications. 20240413_152451.jpg
    enloe, WilliD, skooch and 8 others like this.
  4. vtwhead
    vtwhead
    Nice Rocket! What mods were required on the chain? Can't see, but you didn't forget the chain oiler in the front oil galley or the hidden plug in the rear? Watch the 3 leg engine stand. They like to tip over quickly once the heads are on. No stopping them when they decide they want to lie on the floor:rolleyes:
  5. Black_Sheep
    Black_Sheep
    All done underneath the ‘58…
  6. 57 Fargo
    57 Fargo
    Heading home with purchase number 1, ‘56 Dodge parts truck, couldn’t turn it down for $250.
    enloe, Tickety Boo, alanp561 and 11 others like this.
  7. Lloyd's paint & glass
    Awesome brother, does it have the parts you need for your truck?
  8. 57 Fargo
    57 Fargo
    Nothing for mine. Lots of parts are the same but nothing front end related. I’m just a ****er!
  9. chevy57dude
    chevy57dude
    @57 Fargo -
    Good score for a great price. Having "inventory " is planning for the future!
  10. 57 Fargo
    57 Fargo
    I do like my inventory!!
  11. saltflats
    saltflats
    from Missouri
    enloe, Tickety Boo, alanp561 and 13 others like this.
  12. mad mikey
    mad mikey
    ^^^^Now that is a no nonsense, bad *** 409. And yea, looks to be stepped on quite a bit.:);)
  13. chevy57dude
    chevy57dude
    Those Holleys are some serious pieces, along with the intake and heads under 'em!
    enloe, saltflats, loudbang and 2 others like this.
  14. atch
    atch
    I guess not. The hood is worth that isn't it?
    Nice; real nice. I'll probably never own another car that fast but I'm hoping the Model A will be close. Well; maybe not close but at least getting up there.
  15. HOTRODNORSKIE
    HOTRODNORSKIE
    Got a blank cam gear sent to me it was how did that happen thing, had to drill the three cam mount holes then ream the center hole. Yep I now about the stands on these motors. I first built the motor 20 ears ago and never ran it so I check the plugs again just in case.
    enloe likes this.
  16. TA DAD
    TA DAD
    from NC
    I had the Studebaker out for a couple blasts down the highway, got it home and changed the oil and filter while things were nice and hot. IMG_1335.JPG
  17. 57 Fargo
    57 Fargo
    @atch thrre is far more in Parts than what I paid for sure. It was someone’s project, has an LA motor in it with some interesting fabrication happening!
  18. Frames
    Frames
  19. Frames
    Frames
    Boxing a complete 274 C I D 2024-04-09 18.57.11.jpg 2024-04-12 13.42.18-1.jpg 59A going to an American in Scotland for his 34 coupe
  20. IMG_7428.jpeg IMG_7429.jpeg Little Truckdoctor and I are working on the 12 volt conversion job on our 50. We got it running and Chandler got the headlights swapped out. We also got the alternator installed and wired up with a working indicator light. Next up, turn signal installation. I bought kits to make the front park lights into turn signals and I got 1157 bases to install into the original style taillights.
    enloe, Oneball, 57 Fargo and 9 others like this.
  21. 1pickup
    1pickup
    Finished product:
    Those are clouds reflecting in the Ford Semi-gloss engine enamel. Didn't care if it was perfect anyway, as I'm going for an older look. You can't tell from looking at it, but there was quite a bit of work to go from oil bath to paper filter. I got 2 of these (early 50s Chevy truck?) for $20. Cut up the worst one first. Planning to take the Performer intake & Q-Jet off a 350 & install this on a 2Jet sitting on a cast iron manifold, along with some script valve covers. Will need to figure out a PCV though. Maybe drill into the intake.
    enloe, Tickety Boo, Oneball and 5 others like this.
  22. fastcar1953
    fastcar1953
    One door almost back together. Working on drivers side next. IMG_20240416_230305966.jpg
  23. swade41
    swade41
    from Buffalo,NY
    Between 4 doctors appointments over the last 2 days I was able to get the other valve cover polished, again not perfect, but good enough.
    Probably keep on task and finish them up, ventilate for breathers, cut the oil drippers, touch up a couple spots, make gaskets for breathers.
    enloe, Voh, rod1 and 12 others like this.
  24. Lloyd's paint & glass
    Look at you man!! I'm excited to see you guys :cool:
    enloe and Truckdoctor Andy like this.
  25. Looking GOOD!
    If you have not done so, contact Newport Engineering for an electric wiper motor. You will not be sorry. Night and day difference.
    Ben
  26. pila38
    pila38
    Working out floor and pedal placement, soaked toe board parts in citric acid solution.
    enloe, 1pickup, Oneball and 4 others like this.
  27. fastcar1953
    fastcar1953
    @swade41 I'll be glad when you finish my valve covers. They will look great on my engine. Let me know when you ship them. :D:p
  28. gene-koning
    gene-koning
    That parts truck looks better then my 49 did when I started on it! And I paid almost 2 1/2 x what you paid for yours. I did get a ***le though.
  29. 57 Fargo
    57 Fargo
    Paperwork is no problem here.
