Technical Best flowing air cleaners for dual carb flathead?
Discussion in 'The Hokey Ass Message Board' started by Busmania, Apr 14, 2024.
  1. Busmania
    Busmania
    from Denver
    I was warned about the frog ones but I had them on hand and put them on. I couldn’t even make it around the block before I had to take them off. What do yall recommend? Function is probably more important than looks!
  2. G-son
    G-son
    from Sweden
    Good air cleaners are generally big air cleaners. The filter needs a lot of surface area to both flow well and clean well.
    Bill's Auto Works likes this.
  3. Bandit Billy
    Bandit Billy
    I don't run air filters, just bug screens and scoops on my flathead.
    lostn51, Toms Dogs, hfh and 1 other person like this.
  4. Busmania
    Busmania
    from Denver
    Love that one. Thought about making a custom one like that but it’s low on the priority list. I’ll look into that style. Thank you.
  5. Busmania
    Busmania
    from Denver
    I thought about doing that. I am still
    Running the bug screens. Maybe I’ll just remove the “filter” and run like you do.
    Bandit Billy likes this.
  6. HEATHEN
    HEATHEN
    from SIDNEY, NY
    If you like the looks of small air cleaners, buy a couple K&N filter elements for them. A friend had a '39 Ford coupe with a stock 59A in it, and couldn't figure out why it ran so poorly...it was the cheap clogged Mr. Gasket air filter.
    19Eddy30 likes this.
  7. Unkl Ian
    Unkl Ian
    Size matters.
    alanp561 likes this.
  8. Hillbilly Werewolf
    Hillbilly Werewolf
    I have a pair of the O'Brian Truckers tall filters for my Plymouth, only running one till i install my dual intake. It is the same diameter as the small ones, but much taller. Under the mesh is a k&n style oiled cloth filter. It seems to flow plenty of air for the RPM my flathead sees, I felt like i could feel a difference over the standard 4" louvered filter that came on the car.
    Dan Hay likes this.
  9. Joe H
    Joe H
    If you look here, https://wixfilters.com/Lookup/FilterBySize.aspx filters are by size. When you click on a filter you like, most show the cfm of the filter. Figure out how much air you need, then you will know just how big of a filter you must have.
    Paul, alanp561, RodStRace and 2 others like this.
  10. Flatheadjohn47
    Flatheadjohn47
    from Lewes, DE
    I bought a k & n style air filter for a Porsche that had a 3 barrel Weber on each end of the engine.Bought at a swap meet for $20 and made my own bottom and top to accommodate the Edelbrock slingshot intake with 2—Stromberg 97 carbs that I had jetted UP from stock jets(.045) to .048 and ran h-10 champion plugs that had a nice light tan to light brown finish on the plug centers after running on the street and eventually at the drags. My 32 Henry cabriolet fender less hiboy ran 80 in the 1/8 mile with s—10 5 spd,and 3:89 Detroit locker in a nine in ford rear. I would say the length and tallness of the Porsche k & n filter contributed immensely to the overall performance of the less than 250 in flathead. IMG_2414.jpeg IMG_2278.jpeg IMG_2200.jpeg IMG_1737.jpeg IMG_1736.jpeg IMG_1680.jpeg IMG_1395.jpeg
  11. Nice to see another cabriolet - there are not many of us with them!
  12. 28rpu
    28rpu
    My vote for best flowing air filters is K&N. When I built a 327 for my coupe a few years ago I did the calculations for surface area needed for the engine. I found a filter x2 that provided that. I machined the filter housings to fit these filters. I had the engine on the dyno and after the break in and tuning the last pull was with the air filters on. The tq/hp numbers did not change. Sold me. IMG_5214.JPG
    alanp561 and swade41 like this.
  13. banjorear
    banjorear
    Can you post a pict of your frog scoops? Normally, they have no filter. Curious how it was choking out the motor.
    caprockfabshop likes this.
  14. mad mikey
    mad mikey
    K&N, it has been proven time and time again on the dyno. Watch David Vizards video on these filters , he explains how and why they flow so well.
  15. flathead 37
    flathead 37
    Our air cleaners that we offer on our website have proven to have excellent flow. We run k&n elements
    Here is a link to the video where I flow test them
    We have them available on nystromperformance.com
    Made here in the USA
    1930ModelA, swade41, Speccie and 5 others like this.
  16. Ziggster
    Ziggster
    Very nice! Crazy how much the mesh in the frog mouth restricts the airflow.
  17. Petejoe
    Petejoe
    from Zoar, Ohio
    I’ve had good results when using nylon hose material over the carbs mouth and then place a frogs mouth over it to hold in place. They last a long time.
  18. Harv
    Harv
    from Sydney
    Amen.
    Cheers,
    Harv
    mad mikey likes this.
  19. 1930ModelA
    1930ModelA
    flathead 37 likes this.
  20. hipojoe
    hipojoe
  21. 51504bat
    51504bat
    Always like the looks of these. No idea how well they flow
    Ziggster and caprockfabshop like this.
  22. caprockfabshop
    caprockfabshop
    I have the same Grace & Co housings. They ran just fine on my run stand, I haven't tried them under load while driving, but all they have is the wire, so not physically restrictive in appearance. PXL_20221228_225234070.jpg
    Ziggster likes this.
  23. Ziggster
    Ziggster
    Had to Google Grace & Co. Never have come across their stuff (knowingly at least). Really like the copper plated look.
  24. caprockfabshop
    caprockfabshop
  25. This is a setup I'm putting together for my '50 Ford 8BA. Air cleaner dual 94s.JPG twin carbs.JPG
