Technical ***April 2024 Banger Meet Thread - Don't Be Fooled Accept No Substitutes***
Discussion in 'Traditional Hot Rods' started by Jiminy, Apr 1, 2024.
  1. winduptoy
    winduptoy
    Like looking at a Winfield is some respects
    Outback likes this.
  2. Kevin Pharis
    Kevin Pharis
    from Califunny
    Yup! Yur lookin at the CAD model of my S-B Winfield throttle barrel (cut in half of course), with an additional sleeve that would reduce down to an A or AA size. Since my pair of B’s turned out to be waaay too big I have been contemplating different options to reduce air volume without abandoning all the effort spent so far. Confident that these could be made and tested in a weekend, rather than the 100’s of hours it would take to create new carb bodies, manifolds, etc…
    winduptoy and Outback like this.
  3. walls
    walls
    In my mind, I’m thinking 32 spring perches with an extension bolted and welded.
    We’ll see once I get all the parts.
    Outback and winduptoy like this.
  4. walls
    walls
    Decent day. Got the engine and trans together and in the frame.
    Bolted the intake and carbs on cause I couldn’t help myself.
    modelacrazy, GuyW, Jiminy and 6 others like this.
  5. Stovebolt
    Stovebolt
    I was thinking about @walls build, and my own dilemma of wanting to run a dropped axle with mechanical brakes.
    Looking at my axle, the track is narrowed due to the drop. The brake actuator rods head inwards, what looks like enough that they will interfere with the original model A shockers, even if I use shorty dog-bones.
    so my question is - has anyone narrowed the brake actuators so that they keep their position relative to the shockers? To do this, they must be narrowed between the perch bolt bolt-hole and the spindle.
    Thanks
  6. Outback
    Outback
    from NE Vic, Oz
    mvee33, The37Kid, 40 Olds and 2 others like this.
  7. Like that!
    winduptoy likes this.
  8. jim1932
    jim1932
    IMG_6034.jpg Is this running split exhaust manifolds? It looks like and exhaust pipe running straight down where the stock Carb would be, but it also looks like one manifold (although it is kind of hidden).
    This is John Bean's car taken from "The Duke Hallock Story" https://patganahl.com/2022/05/02/the-duke-hallock-story/. It says it is a cragar head. I have seen them in this period with a lake header, this one looks like one manifold with two pipes?
    winduptoy and The37Kid like this.
  9. 5280A2
    5280A2
    Based on the intake manifold that sure looks like a flathead setup. Also exhaust sure looks like a split manifold or an additional center outlet. Fun to try to figure out what we're seeing!
  10. ALLDONE
    ALLDONE
    love it...no issues so far... seems to double the hp with that and the 2 to 1 header split dual exhaust... IMG_1296 - Copy.jpg IMG_1297.jpg IMG_8346.jpg IMG_8807[8523].jpg IMG_8808[8524].jpg IMG_8810[8526].jpg
    mvee33, Jeff34, winduptoy and 4 others like this.
  11. ALLDONE
    ALLDONE
    0.30 above the block works...
  12. 4BangerDean
    4BangerDean
    2FORCEFULL and Outback like this.
  13. Outback
    Outback
    from NE Vic, Oz
    4BangerDean and 2FORCEFULL like this.
  14. ALLDONE
    ALLDONE
    don't know a lot about the engine, just what i've personaly seen.. the motor is a "B",.. 125 over bore, insert bearings. balanced crank. lightened flywheel.custom oil pump, all new stuff inside. I put the FSI dist,.. we split the exhaust 1&2-3&4 to dual lake pipes...the trans is a 39 syncro 2nd and 3rd with an electric over drive
  15. Outback
    Outback
    from NE Vic, Oz
    4BangerDean likes this.
  16. Outback
    Outback
    from NE Vic, Oz
    img_3_1713265367404.jpg img_1_1713265290166.jpg img_2_1713265347557.jpg img_1_1713328089180.jpg This is my mates manifolds/filter ***y fitted
  17. BLACKNRED
    BLACKNRED
    That is pretty neat.
    Outback likes this.
  18. winduptoy
    winduptoy
  19. Outback
    Outback
    from NE Vic, Oz
    Not mine, but a friend just up the road, haven't been able to get him on here.
  20. Making ssllooww progress
    J
  21. 4BangerDean
    4BangerDean
    Looks like an engineering masterpiece. Please share what we are looking at and what it’s going into. My guess is landspeed racing.
    Outback likes this.
  22. Well, it is an example of glacial speed engineering....
    B block, C crank modded, B rods with inserts, TRW 283 pistons.
    This was an untouched Gemsa Morales casting for the head.
    I moved the valve locations and put in 2-1/16" intakes, 1-5/8" ex.
    The SOHC is a one off design, Brierley cam with Jag buckets and special springs.
    Intake is Hilborn 1-11/16" modded for EFI.
    Not for Bonneville, is going in my tan '30 street coop.
    Nader said unsafe at any speed, this one will be unsafe even while parked!
    J
  23. walls
    walls
    Weekend 3 of putting stuff together.
    Not bad. Waiting on some 32 spindles to come in the mail.
    Plan is to chop it about 5”
    Crazydaddyo, GuyW, Stovebolt and 7 others like this.
  24. The37Kid
    The37Kid
    [​IMG]Are the exhaust manifolds custom made or can they be bought somewhere? They look great!
    Outback likes this.
  25. Nah, leave it tall and buy a top hat.
    G Baese, GuyW, The37Kid and 6 others like this.
  26. wuga
    wuga
    Maybe if it was channeled and was running a hemi, you might want to chop it, but as a banger it is perfect.
    Warren
    Crazydaddyo, Outback and winduptoy like this.
  27. Outback
    Outback
    from NE Vic, Oz
    The manifolds are fabricated, I posted some pics in last months thread, made in a similar way to the inlet manifold, hrs of work in them! img_4_1710471687303.jpg
    GuyW, The37Kid, winduptoy and 2 others like this.
  28. set me on fire
    set me on fire
    1929 ford tri-motor was in town...I heard destiny calling when she few overhead and cast a shadow in my back yard.
    G Baese, Crazydaddyo, Outback and 4 others like this.
  29. wuga
    wuga
    Just saw this, maybe someone posted before:
    ‘Elliot Ness' (Actor Robert Stack) used to race a Model A roadster out on the dry lakes of California. Banger has a Cragar head, Bell Auto intake with dual Winfield carbs and a Mallory distributor.
    Warren
    G Baese, GuyW, Outback and 6 others like this.
  30. Tumblin' Dice
    Tumblin' Dice
    from Las Vegas
    So, I have a squeaky pilot bearing in my A motor that I would like to change out (along with TO bearing, etc.) this summer. Reading through Fordbarn suggests that a worn transmission input shaft is extremely common with a pilot bearing worn enough to squeak. This leads to the need to sleeve the shaft and have everything turned down to a sliding fit with no slop as when new, with an unworn input shaft.
    Wondering if anyone has ever actually encountered this, and is this something I should expect to have to do when I pull the trans out?
