Projects Something from nothing. 29 roadster build
Discussion in 'Traditional Hot Rods' started by wheeldog57, Oct 8, 2016.
  1. Chop50
    Chop50
    Your roadster is lookin good!
    Raced my Shoebox at Winterport 22, Vintage Drags 23, then down to Fall Out in Glastonbury in Oct. 23.
    Sure I will bump into you at some point. Lots of nice folks at the events.
    Steve
    NoSurf and wheeldog57 like this.
  2. wheeldog57
    wheeldog57
    Fabbed and tinkered the throttle linkage.
    Worked a few times then it broke. My weld on the pedal shaft let go and front carb shaft concentric snapped at the same time. That was yesterday.
    Today I cleaned and re-welded the shaft and it broke too. I have a spare Model A throttle set up so I cut it up, made the return spring work with my custom set up, and soon I will clock and attach the pedal. I shimmed, moved, drilled, and pinned the front carb thing so fingers crossed that will work smoothly now. 20240407_185850.jpg 20240407_190548.jpg 20240407_195235.jpg 20240407_195256.jpg 20240407_194026.jpg 20240407_200908.jpg
  3. Pinewood
    Pinewood
    @wheeldog57 Cool car and fun thread that I discovered tonight!. Gear Drive (lakeheaders.com) has cast aluminum offset breather tube that looks a lot better than old rusty exhaust tube.... Otherwise lookin good!
    wheeldog57 and Outback like this.
  4. wheeldog57
    wheeldog57
    Math is not my strong suit so I'm looking for some help calculating displacement on my new flathead.
    1950 Ford big truck 8BA
    3.1875x3.75=239ci
    Now bored .100=23.9 more which makes
    262.9ci yes? No because 239 is bore and stroke. I was told it's 255 but I'm sure someone here knows how to calculate.
    Thanks in advance
    Nailhead A-V8 likes this.
  5. lamaison
    lamaison
    from Canada
    wheeldog57 likes this.
  6. 42˚18'N 83˚09'W
    42˚18'N 83˚09'W
    Ron,
    It is 255
    D
  7. wheeldog57
    wheeldog57
    Thanks guys! Really looking forward to hearing this motor. I've gotten quite a bit done. I check tasks off the list but create more tasks every night. Ignition wires are from a former Camsnapper **** Edgerly
    He was a local circle track driver and a lot of fun to be around. 20240414_201459.jpg 20240414_201515.jpg
  8. wheeldog57
    wheeldog57
    D****d some pleather, unsure about the color. Does it clash or look ok? I have enough to do the whole interior. 20240414_205558.jpg 20240414_210050.jpg
    Here’s the formula if you want to figure it out the HAMB way, traditionally!
  10. wheeldog57
    wheeldog57
    Been fiddling with the motor for the last few nights, put a known good distributor in and BAM! It lit right off! Sounds tough too 20240425_175951.jpg
  11. wheeldog57
    wheeldog57
  12. patmanta
    patmanta
    from Woburn, MA
    I ran into this with my Offy intake as well. I ended up clocking the whole works to the p***enger side. I have not yet found any reference as to why Offenhauser did their intakes like that.
    I would imagine you're at about 270 cid there. Did you opt for EAB heads over the aluminum ones? I'm running EABs too. My block and the heads got surfaced. I'm running an Offy triple with two 97s & an 81 for primary with the 3.75 crank 0.030 over. It makes good noise. I have the linkage set up so I can tighten one set screw to go from progressive to non-progressive. I just picked up an EAC & another set of EAB heads as well for a roadster my buddy & I are collecting parts for. That combo's probably the hottest you can get with stock stuff I'd say so I'm excited to hear yours run!
  13. wheeldog57
    wheeldog57
    Hey Pat, happy to hear your pile of parts is moving!
    Yes I am running the EAB heads so far. Offys are at the machine shop currently.
    Come hear it at Oxford, Me. Memorial day weekend
    brEad and patmanta like this.
  14. wheeldog57
    wheeldog57
    Got some more tasks checked off the list today after working and the Kingpins season opener show. Made a gasket for the top of the oil filter housing, mounted the radiator, made new radiator support rods, fabbed up a choke actuator I robbed from a 94. Had to make my own collared screw (tedious but kinda fun because it worked), fabbed up front to rear choke rod. Got a lot done today, yes! 20240505_175146.jpg 20240505_175155.jpg 20240505_175258.jpg 20240505_182011.jpg 20240505_182912.jpg 20240505_191005.jpg
  15. wheeldog57
    wheeldog57
    Crazy at work so I find peace in the hideout. Got the new dash and gauges installed last night 20240509_205139.jpg
  16. wheeldog57
    wheeldog57
    Been crazy at work and my whole family showed up to paint my garage yesterday so I've been prepping all week after work. Wiped out but still got some **** done today. Going up to Oxford, Maine for this weekend racing the roadster. 1/8th mile drags, swap, show, etc. Really looking forward to it. Have a list to get done before Thursday 20240519_171051.jpg 20240519_185414.jpg 20240519_194912.jpg 20240519_195005.jpg 20240519_202524.jpg
  17. wheeldog57
    wheeldog57
    New motor required grill to be moved forward a little, I like to run a hood so I hacked some "shell extensions". Made up an ignition wires holder upper that doubles as a throttle spring holder.
    While breaking in the cam the water pumps leaked pretty bad so hopefully I can grab a pair tomorrow
    Jeff34 and brEad like this.
  18. wheeldog57
    wheeldog57
    Snagged a pair of water pumps today at Millworks hot rod shop in NH. Great guys and they have what I need always! 21009.jpeg
    tb33anda3rd, brEad, Okie Pete and 2 others like this.
  19. wheeldog57
    wheeldog57
    Swapped out water pumps after work, after removing and cleaning the carb on the lawn mover, mowing said lawn, belts back on and tight. Fire it up and front carb leaked for a minute but stopped (wtf) ran it through a good heat cycle, set timing, set idle. 17-18" steady vacuum, 190*, oil @ 28psi, battery charging, rumpy idle 17163388688214982164873335234861.jpg . I have a stiffie
  20. wheeldog57
    wheeldog57
    First time out in quite awhile. First test drive went well, I need a smilectomy. Runs strong but some tinkering required when I get it off the trailer at the drags tomorrow. 20240522_172437.jpg 20240522_171855.jpg
  21. wheeltramp brian
    wheeltramp brian
  22. wheeldog57
    wheeldog57
    A Boner, tb33anda3rd, Silva and 4 others like this.
  23. wheeldog57
    wheeldog57
  24. Jeff34
    Jeff34
    How are you addressing crankcase ventilation? Hidden PCV?
  25. I mean, just because the car is from 1929, doesn’t mean your tent has to be. Good god, man!!!
    brEad, SuperKONR, 69fury and 2 others like this.
  26. wheeldog57
    wheeldog57
    @Jeff34 the oil fill has a breather cap, good so far
    Jeff34 likes this.
  27. Jeff34
    Jeff34
    Thanks! I was hoping that would be enough but wanted to check with someone who has done just that
  28. wheeldog57
    wheeldog57
    Been having a blast with my new motor. Made 7 p***es today, got eliminated in 3rd round (by Jarod's wicked T) clutch is going away I fear but I'm still having fun 20240524_164204.jpg 20240524_192435.jpg 20240525_165814.jpg 20240523_173337.jpg
  29. wheeldog57
    wheeldog57
