Technical Rebuilt 302 has no get up! Help.
Discussion in 'The Hokey Ass Message Board' started by Brandon141, Apr 15, 2024.
  1. Brandon141
    Brandon141
    Just rebuilt my 302-
    90 mustang short block
    Edelbrock performer rpm head (2.02 valves)
    Dual plane intake
    Holley 600 carb
    Summit cam- 512 lift
    1.6 rockers
    Motor starts up and idles great. And revs awesome. But the motor has no get up and go! It won’t even break the tires loose. The tired old stock motor I removed would roast the tires! I am stumped…
  2. RmK57
    RmK57
    Upgrading the heads, exhaust, intake,camshaft could require more ignition timing, rear gear or a different torque converter. It’s all about a total “package” to make it perform to your liking.
  3. Brandon141
    Brandon141
    It won’t even “brake torque “ when warmed up.
  4. Rickybop
    Rickybop
    Try advancing the ignition timing a little.
  5. Kevin Ardinger
    Kevin Ardinger
    Cam super retarded? Exhaust blocked? What compression ratio? What trans? Automatica or manual?
  6. Brandon141
    Brandon141
    It just seems it should have way more HP than the old 89 f-150 all stock motor I removed.
  7. Brandon141
    Brandon141
    Ford AOD trans
    Initial timing 15*
    Deuces and Sharpone like this.
  8. RmK57
    RmK57
    Even a stock ignition curve can make a modded engine be a little soggy off idle, especially with a performance camshaft. What camshaft is in it, exactly?
    chryslerfan55, Deuces and Sharpone like this.
  9. Brandon141
    Brandon141
  10. Kevin Ardinger
    Kevin Ardinger
    Are you sure it’s taking off in low gear? Does it shift through all the gears properly?
    chryslerfan55 and Sharpone like this.
  11. iagsxr
    iagsxr
  12. RmK57
    RmK57
    Camshaft Manufacturers Description:
    Rough idle, wide midrange power band. Requires 2,500+ stall, 9.5:1 and higher compression, and gearing. Bracket race cam.
    Do you have all these requirements? Like I said converter, gear all come into play here.
  13. Kevin Ardinger
    Kevin Ardinger
    That cam card is not legible on my end anyway
    Deuces likes this.
  15. caprockfabshop
    caprockfabshop
  16. Kevin Ardinger
    Kevin Ardinger
    Do you have it wired per that camshaft? Or did you wire it like an 89 F150 if I’m not mistaken they are different firing orders. 89 F150 is 18436572, that camshaft is 15426378.
    1940Willys, loudbang, fauj and 8 others like this.
  17. BJR
    BJR
    Where is your vacuum advance plugged into? Ported or manifold vacuum? Try switching it.
    nunattax and Deuces like this.
  18. Last edited: Apr 15, 2024
  19. RmK57
    RmK57
    It wouldn’t even start with a mis-matched firing order.
  20. Sharpone
    Sharpone
    That’s a pretty big cam for a little 302 I ran a cam with 10 degrees less at .050 in SBC 305 and it was soft on the bottom end. Does the engine respond at 2500 - 3000 rpm does it pull good once it’s wound up? Like was mentioned above Gears and Higher stall converter, was the cam set straight up?
    Dan
  21. Run a compression test. Hold the throttle wide open and 6 revolutions on each cylinder. Was the cam installed dot to dot or degreed? Are you positive it is in correctly? What c.c. is the combustion chamber on the heads? Did you install flat top or dished top pistons? I ran a similar cam in a basically stock 289 years ago and it was weak on the bottom. The flow on your heads is far superior to what I had which should help that situation.
  22. If ya got stock gears and stall: IMG_8422.jpeg
  23. Lloyd's paint & glass
    Your stock engine had low end torque, you built an engine that wants to live above 3000rpm, now you need to adjust everything else, torque converter, rear gears, etc
  24. RmK57
    RmK57
    Put some 4.30’s in it with a 2800-3000 stall converter. That’ll smarten it up…..or change the camshaft.
  25. Brandon141
    Brandon141
    Cam was installed dot to dot. Dist is connected to timed spark port on side of Holley. 10-15 on vacuum gauge.
    The car is sluggish through all rpm range. Doing 55mph and nail the throttle, it’s still sluggish.
    Pistons are flat tops with valve reliefs.
    Heads are 72cc combustion
  26. I've always had the best results on my Fords with the vacuum advance connected directly to manifold vacuum.
  27. RmK57
    RmK57
    The oem heads have 58 cc heads, so if you went to 72 cc with a stock replacement piston you could be in the 8.5/1 or lower cr. If you know the all the specs on your build that could be very helpful.
  28. deathrowdave
    deathrowdave
    from NKy
    Check the vacuum advance arm , are sure it’s still connected to the breaker plate and has not came disconnected . My 302 has x grind , C4 and 3.00 gears . I have no complains in the power dept . , you have to do some fine tuning . Adjust timing to 37* at 2000 with advance connected , let us know how that does for you .
  29. fastcar1953
    fastcar1953
    Even at 55 with tall gears it will make a lot of noise but go nowhere.
    chryslerfan55 and winduptoy like this.
