Hot Rods Top Banana Style Slingshot Dragster- Marty Strode-Chris Kopp.
Discussion in 'The Hokey Ass Message Board' started by Marty Strode, Apr 7, 2024.
  1. As always, Marty nice work!
  2. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    I always forget to put down the cardboard until AFTER I drip cutting oil and chips all over the floor!
    What is that hole spacing gadget called? I'm going to need one shortly but can't remember the name.
    chryslerfan55 and Tim_with_a_T like this.
  3. Marty Strode
    Marty Strode
    On the RH side, yours has a metal tag with HEF stamped on it. It is similar to the model RAN. Mine is a RAT, that has a longer case, and wider / stouter gears.
  4. tomcat11
    tomcat11
    I could use one too. That is a real time saver. Going to search around to find one.
  5. Just Google Aircraft tool supply and then search rivet layout tool. There's several different styles and they are very inexpensive.
  6. Sandcrab
    Sandcrab
    Adjustable rivet spacer. Try aircraftspruce.com, they are a reliable source for specialty sheet metal tools and supplies.
  7. Marty Strode
    Marty Strode
    Another name is Rivit Fan.
    brEad and chryslerfan55 like this.
  8. RodStRace
    RodStRace
    I too was drawn to that nifty tool, and then thought "I bet he made it".
    Glad to hear others caught it and that it's available to us that don't have a fully equipped machine shop.
  9. Marty Strode
    Marty Strode
    Bruce, if you use Kool Mist, it is water soluble, and cleanup is a wet sponge.
  10. tomcat11
    tomcat11
    I bought some Cleco's and other Rivet tools from
    https://www.aircraft-tool.com/
    They have the Rivet Fan and a Mini version and a ton of other neat tools.
    OFT likes this.
  11. Marty Strode
    Marty Strode
    On a project like this, there is always a wait for parts, to see if you are going the right direction before moving on to the phase. The wishbone bungs, header flanges and tire rod came today. So I turned a small weld prep on the bungs and machined some stainless pieces to fit the lower wishbones. I also took a few minutes to slick up one of the header flanges. Now I can cut and fit the upright posts, and brackets at the rear wishbone mountings. IMG_0293.jpg IMG_0294.jpg IMG_0295.jpg IMG_0296.jpg
    HEMI32, OFT, Dean Lowe and 9 others like this.
  12. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    MARTY,
    What is your method for 'slicking up' the header flange? Flap Wheel?
  13. Marty Strode
    Marty Strode
    Bruce, I have a coarse and fine belt sanders side by side. A quick trip around with both, followed with a 320 DA on the both surfaces, they come around. Flap wheels would do it, just not as fast.
    brEad, chryslerfan55, bymanr and 3 others like this.
  14. Marty Strode
    Marty Strode
    IMG_0313.jpg I got up with the chickens, and was able to get the rear radius rod brackets tacked in place. I bought some tapered bungs from Speedway, and they worked out great. IMG_0297.jpg IMG_0298.jpg IMG_0302.jpg IMG_0304.jpg IMG_0305.jpg IMG_0306.jpg IMG_0309.jpg IMG_0310.jpg IMG_0311.jpg
    HEMI32, OFT, brEad and 16 others like this.
  15. Marty Strode
    Marty Strode
    I got the tubes in the seat area, fit and in place, this will allow me to sit lower. I had a sample front roll bar hoop that I have used for years. It's exhaust tubing, and works very well, to determine the final product. IMG_0314.jpg IMG_0316.jpg IMG_0318.jpg IMG_0319.jpg IMG_0320.jpg IMG_0321.jpg IMG_0323.jpg IMG_0324.jpg IMG_0325.jpg
  16. ratrodrodder
    ratrodrodder
    from Boston
    Great work as always Marty, and thanks for documenting it all for us. If a name hasn't been decided on yet, I'd vote for Second Banana...
    BTW, you're giving @Dave G in Gansevoort all kinds of ideas about another project (that's not a complaint, just letting you know your influence at least makes it as far as the east coast) :)
    brEad, chriskopp and chryslerfan55 like this.
  17. AmishMike
    AmishMike
    Love this build, u do great stuff on all your builds. Will u add a 2nd over head for NHRA or just the one to copy original? Cat going crazy watching baby quail run around?
  18. y'sguy
    y'sguy
    from Tulsa, OK
    Nice work on a cool subject. I'm going to enjoy watching.
  19. Marty Strode
    Marty Strode
    Mike, it will be a 5 point, to certify at 7.50. I have a dozen cats, 6 outside. I don't dare feed the quail, or the cats would kill them. I really enjoyed the quail, and for those who haven't seen them, here is the video.
  20. Marty Strode
    Marty Strode
    Did a check on roll bar height. I still have a 1" thick board, and some padding under me, and without the sheet metal liner wrapped around the inside, it looks like I can fit the cage within the*****pit cover. IMG_0327.jpg IMG_0328.jpg IMG_0333.jpg IMG_0339.jpg
    HEMI32, OFT, brEad and 12 others like this.
  21. Stan Back
    Stan Back
    One picture shows the hoop on the right side about 6 inches from the tire. Another shows it about 2 inches. What gives? I guess it's the angle of the dangle.
  22. Marty Strode
    Marty Strode
    It's got to be the angle, as I held it steady and didn't move much.
    porkshop likes this.
  23. tomcat11
    tomcat11
    Marty, just curious why you tied the rear radius rod brackets to only the upright and bottom frame rail as opposed to making the brackets a little taller with a bend at the top back toward the upper frame rail and welding them on 3 sides instead of 2. Would that not make the pick up point stronger? Or was that how the original was built?
  24. Marty Strode
    Marty Strode
    Without any braking forces, and no chuckholes in the pavement, strength is not an issue. Notice how lightweight, things got by the late 60's, on an old Fuller Car, I used to race. The original TB, was totally different, in that the chassis was rectangle tube, with the radius rod bracket, hanging below the rail. 2012-09-14 164046.jpg
    HEMI32, brEad, porkshop and 7 others like this.
  25. Marty Strode
    Marty Strode
    On another note, I shipped the axle to get dropped this morning, and the NHRA Inspector is coming Wed afternoon. That way I can proceed with confidence that it will pass the certification.
  26. spanners
    spanners
    I didn't notice you doing 'Vroom Vroom' noises while sitting in the*****pit.
    OFT and porkshop like this.
  27. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Man....This is incredibly Fantastic... so much talent ..... Just wicked.
    porkshop and 57 Fargo like this.
  28. Marty Strode
    Marty Strode
    Jeff, the real talent will begin, when Chris starts on the body. Thanks !
  29. Marty Strode
    Marty Strode
    I reserve those moments when no one is around !
    OFT, porkshop, raven and 5 others like this.
  30. ratrodrodder
    ratrodrodder
    from Boston
    Is it mostly justly idling in the pits, or are you doing WOT passes down the strip? :D
    brEad likes this.
