Technical Top hood hardware ?
Discussion in 'Traditional Hot Rods' started by 29plymouthroad, Apr 15, 2024.
Tags:
  1. 29plymouthroad
    29plymouthroad
    I will be installing a top hood to my roadster ( no side panels) does anyone know any good top hood only. Hardware kits for mounting it and keeping it shut nice and tight obviously. Most kits I find are for 3 piece folding traditional hoods. Any links or parts recomedation would be appreciated.. and happy Patriots day from us in M***achusetts
    dana barlow likes this.
  2. Tim
    Tim
    from KCMO
    I’m ***uming it’s a model a?
    either way do a search for hood straps or “running hood top only” there’s loads of threads on this topic.
    in short the two most common answers are making a spring loaded dead bolt of sorts inside the stock hood. Hing loops were the rod used to go.
    or using basically belts to tie it down.
    a third option that I don’t see as much, if your using a stock hood and it’s got the center held down at the cowl and grill as stock I’ve seen people run a bunji or chain from side to side over the engine. One on front one on back
  3. 29plymouthroad
    29plymouthroad
    My car is a 29 plymouth coupe but measurement I took I found several top hoods that will fit I'm just not sure on mounts and what secures it down to the radiator shell and the back at the firewall just looking for simple secure stuff doesn't have to be anything period correct fancy my car is in my profile if you'd like to take a look and if any top hood guys with roadstersnhave any recommendations
  4. Tim
    Tim
    from KCMO
    There should be a little loop or pocket on top of the cowl and on top of the radiator for the center hood hing rod to slide into.
    29plymouthroad likes this.
  5. Tim
    Tim
    from KCMO
    IMG_3374.jpeg I would think it should exist in that dip in the front center of the cowl. If it’s not it’s not a fancy piece you could easily make something that would work fine.
    https://www.jalopyjournal.com/forum/threads/hood-leather.1202660/
    first post that came up when I did a search. I glanced at it and seems to have all the recommendations that crop up when this is brought up so I’d think an answer would be found there :)
  6. BJR
    BJR
    Here is how I held down a 2 piece hood top on a 32 Roadster I am building at work. IMG_2101.jpeg IMG_2102.jpeg IMG_2059.jpeg IMG_2151.jpeg
  7. Bandit Billy
    Bandit Billy
    Leather straps with springs. Been working good for years now.
    Vic Walter, GordonC, The37Kid and 2 others like this.
  8. Andy
    Andy
    I made some L shaped hooks from some 1/8 brazing rod and attached some mono fishing line so they would pull on the side panel hinge loops. It works fine to 100 and possibly more. Cost nothing and has been fine with no maintenance for decades. The mono line is springy.
  9. 29plymouthroad
    29plymouthroad
  10. 29plymouthroad
    29plymouthroad
    That's prob what I'm ginna do but do you have anything at the radiator and top of hood firewall center ?
  11. 29plymouthroad
    29plymouthroad
    That's pretty cool to know.
    hfh likes this.
  12. 29plymouthroad
    29plymouthroad
    Yea I just got that lil dip in the middle and 2 holes. Just wonder what to put there if I ordered a 1 piece top. Seems line a folding 2 piece top maybe the same ? Or easier
  13. GordonC
    GordonC
    I have a center hold down on my 31 A roadster with the stock hold downs on the front of the hood to lock it on. It is a 32 hood modified to fit the A. The last pic shows it mounted. Simple to do.
    20230922_132154(1).jpg 20230922_132147.jpg 20230922_132219.jpg 20221104_171527.jpg
    Vic Walter, -Brent-, Dino 64 and 2 others like this.
  14. carz
    carz
    from colorado
    I've always wanted to use dzuz fasteners.
    RMR&C likes this.
  15. 29plymouthroad
    29plymouthroad
    GordonC likes this.
  16. GordonC
    GordonC
    I should have also mentioned I welded a piece of rod to the center of the hood to go into that receiver on the cowl.
  17. Bandit Billy
    Bandit Billy
    Mine is a one piece hood. I hinged it on the right side.
    GordonC likes this.
  18. Dino 64
    Dino 64
    from Virginia
    Did it with bridle straps of leather, the double D buckle for keeping it tight IMG_6918.jpeg IMG_6907.jpeg
  19. 29plymouthroad
    29plymouthroad
    Dino 64 likes this.
  20. 29plymouthroad
    29plymouthroad
    Do you have any pics under good what your top hood hinge and radiator one looks like
    Dino 64 likes this.
  21. Dino 64
    Dino 64
    from Virginia
    If I understand you, there is no hinge. If you’re more specific I’d be happy to take some pics for you ;)
