Technical 32 Ford steering
Discussion in 'Traditional Hot Rods' started by Jack Lysne, Jul 17, 2020.
  1. Jack Lysne
    Jack Lysne
    Got myself a great little deuce that I'm working on. Just looking for some suggestions.
    This girl has a little bit of a shake to the steering wheel at low speeds.
    It has a Pete & Jakes dropped axel, with a vega steering box. I've checked and had the tires balanced, front end alignment checked, new king pins and bushings, tightened steering box, new lower steering column bearing, checked every nut and bolt and bushings. Still has a little shake to it. This can't be typical for this kind of suspension. Anyone have this kind of trouble?
    Any thoughts?
  2. flatford39
    flatford39
    What is the condition of the tires?? Problem at low speed makes me think tire problem.
  3. GordonC
    GordonC
    What kind of wheels? A bent wheel maybe? Can you swap front to rear to test it? Someone will eventually come on here and say use a steering damper so I might as well get it out of the way. I leave that choice up to you though as there are fans on both sides of that argument.
    26 T Ford RPU likes this.
  4. alchemy
    alchemy
    Radials or bias? Is there a panhard bar or a dead perch? Is there a steering dampner? What's the toe-in?
    ekimneirbo and AULIZ like this.
  5. Jack Lysne
    Jack Lysne
    Tires are almost new. Radials. It acts like tires, nor wobble or out of round. Wheels straight. Has pan hard bar but no damper. Toe-in is ⅛" total.
    Maybe damper is the answer.
    Different sizes front to back, might be tough to swap.
  6. Jack Lysne
    Jack Lysne
    Thanks for your thoughts. On a smooth road, runs straight and smooth.
  7. Blues4U
    Blues4U
    from So Cal
    Have you had the wheels/tires balanced?
  8. Jack Lysne
    Jack Lysne
    Yup Rebalanced and aligned.
  9. Cree
    Cree
    from Montana
    What's the caster set at? Cheat it down a wee bit and see if that helps? Common wisdom seems about 6 degrees, but I run a granny-steer 4 degrees on a 32 chassis and it doesn't wander or bounce..
    bchctybob likes this.
  10. jimgoetz
    jimgoetz
    If you could get a hold of another set of wheels and tires to put on and try it would tell you if that was the problem. I've had radial tires with a broken belt that acted like that.
    trollst likes this.
  11. Need a picture.
  12. 4ty
    4ty
    Stock wishbone or split, rubber ball?? Try a little less toe in. Pitman arm tight??
    Paul in CT
  13. the flatlander
    the flatlander
    toe in...steering box,...tighten u bolts on ft. spring....turn rotors / true drums...steering linkage...tighten perch nuts....good luck
  14. continentaljohn
    continentaljohn
    What the condition of the steering box any slop ? So when you turn the steering wheel any play in the front end components?
  15. dana barlow
    dana barlow
    from Miami Fla.
    1. Y-blocks
    Photo of your front end showing spring,shock,shackles,rim off set n tire,would help others make ideas 4 U.
  16. solidaxle
    solidaxle
    from Upstate,NY
    You mentioned you checked every nut and bolt. Did you get the front end off the ground. Grab the tire at the top and bottom and see what moves? Grab at 9 o'clock and 3 also.
  17. solidaxle
    solidaxle
    from Upstate,NY
    To answer your last question. My 32 does not shake, even with bias tires.
  18. chucka
    chucka
    Yes to having this trouble - - - me, for the last couple of years, After much checking, tightening switching wheels/tires, etc think it's finally solved. Yep, wheels and tires! All the wheels I've ever had on the car were steel aftermarket, a couple of which turned out to be "bent" but nothing seemed to work. Recently tried on a set of aluminum wheel/tire combos a friend pulled off and it went down the road great! So - - - A new set of quality tires on my most recent steel wheels and a very good balance job by an experienced tire expert and it's fine. I've come to the conclusion that just because the guy says "they're all balanced" doesn't always mean they're balanced WELL. Just my experience for what it's worth.
  19. Garpo
    Garpo
    Wheels may be balanced, but how good is the brake drum balance if it is a drum set up. I put new (Chinese) drums on and found that balance was way off. Spin the drum without the wheel a few times to see if stopping point is random.
    I had to remove a lot of metal to get close to balance.
    ekimneirbo, X38 and HemiDeuce like this.
  20. AULIZ
    AULIZ
    That is rather normal with straight front axles if not have panhard or steering shock.
    Ackerman steering is change if not original axle, spring, steering arms.....
    I have had that problem with my grey 1932 5w coupe (5" dropaxle, A-ford front support, mono leaf, 40 spindles).
    I changed little higher front tires, warmed and turned steering arms little more to car centerline. After that no shaking anymore.
    I had same problem with olive green roadster. Original heavy axle, original steerinbox,... I just had 40s sspindles/steeringarms, drop spring.... and shaking sometimes when low speed and bowls on road.
    Never solved problem. didnt want to install panhard or steering damper.
    Other 1932 fords no shaking even have same kind of parts used.....
    I think, You can check ackerman steering and measure it.
    You can also check that You have good tie rod ends and steeringbox. No extra backlash or just increase panhard or steering damper
    Aulis
  21. Frank Manzullo
    Frank Manzullo
  22. Frank Manzullo
    Frank Manzullo
    The best balance ever was a friend who had a brake shop and used the old type of spin balancer on his pro street car for drag racing. I had a '88 Olds wagon that no matter what I did, it still shook, we found the two front and left rear wheel's bad. It was cool how he did it. Once the balancer was on the wheel, he spun it till the hood shook then he made the adjustment by looking across the hood, when it stopped shaking, bingo, smoot as a lake. He even after took it to 120mph. The big Olds never shook again. His reasoning, static balancers are for the wheel and tires, but the spin finds any problem in the whole wheel system. It could be a drum, brake, axel, and I wasn't going to dispute a guy who takes a car 150 mph down the strip every Sunday. The only goof I made was not buying the spinner when he sold out the shop. You probably can find them, but it takes some training to use it. I'm going to run it past my rod buddies and all chip in and buy one for the club.
    Another amazing thing that happened was on my '32 5 window with new Cooker's bias ply whites. I felt the back tires shaking, jacked it up and the rear left had a wobble up and down, I knew the wheel from a late model Ford were perfect.so, I called Cooker and she said rotate your wheels around two lugs, I paused and almost laughed. I did what she said and alas, no wobble! And to think we didn't think women knew about rods! Try it.
    One more story my buddy with a '49 Merc with a wobbly front end on new Cookers, we pulled them, brought them to a tire shop, mounted them on the static machine and spun them by hand, wow they looked like foot balls. A call to Cookers and Corky had them to him in a few days. Several years later my new '32 roadster had the same problem, again Corky was great. Tires can come out of the mold unround.
    Hope all this gab helps, the '32 comes out of storage tomorrow!
    PONTNAK123 likes this.
  23. One issue that always gets missed is sloppy perch bolts in the axle or flogged out axle bores, this allows the axle to rock and steers one side on bumps of any size and mostly on the drag link side....when bad enough you get Death Wobble. JW
  24. wstory
    wstory
    from So Calif
    Cut your losses. Install a damper.
    NJ Don likes this.
  25. There has to be a cause, best find out what it is and correct it. JW
  26. Bump, any conclusion with the steering issue?? JW
  27. Happydaze
    Happydaze
    When is someone going to post up the usual ' I hate threads that ask questions but the resolution is never known' or the other about the op never responding or returning?
    Chris
  28. ekimneirbo
    ekimneirbo
    What speed does it shake..........and does it go away as speed increases? You might get or make a tool to check the balance of the rotors/drums like they use for motorcycle wheels. Doesn't have to be this elaborate, just something simple and cheap to find the heavy side (if any) on drums and rotors.
  29. Andy
    Andy
    It may be loose king pins. The lubrication is supposed to be avery 1000 miles.
    Loose ones will cause shimmy.
